基于STGIF10CH60TS-L的马达控制电源板解决方案详解
1.2w人已加入
  ST公司的STGIF10CH60TS-L是小型低损耗智能模塑模块(SLLIMM)第二代IPM,包括了ST专有的控制IC(一个LS和一个HS驱动器)和15A/600V抗短路的IGBT, 3.3V, 5 V TTL/CMOS输入,主要用在3相马达驱动逆变器,以及家用电器如洗衣机,空调,冰箱和缝纫机等。本文介绍了STGIF10CH60TS-L主要特性,框图和应用电路,以及1000W马达控制电源板STEVAL-IPM10F主要特性,电路图和材料清单与PCB设计。
  This second series of SLLIMM (small low-loss intelligent molded module) provides a compact, high performance AC motor drive in a simple, rugged design. It combines new ST proprietary control ICs (one LS and one HS driver) with an improved short-circuit rugged trench gate field-stop (TFS) IGBT, making it ideal for 3-phase inverter systems such as home appliances and air conditioners. SLLIMM™ is a trademark of STMicroelectronics.
  STGIF10CH60TS-L主要特性:
  IPM 15 A, 600 V 3-phase IGBT inverter bridge including 2 control ICs for gate driving and freewheeling diodes
  3.3 V, 5 V TTL/CMOS inputs with hysteresis
  Internal bootstrap diode
  Undervoltage lockout of gate drivers
  Smart shutdown function
  Short-circuit protection
  Shutdown input/fault output
  Separate open emitter outputs
  Built-in temperature sensor
  Comparator for fault protection
  Short-circuit rugged TFS IGBTs
  Very fast, soft recovery diodes
  85 kΩ NTC UL 1434 CA 4 recognized
  Fully isolated package
  Isolation rating of 1500 Vrms/min
  STGIF10CH60TS-L应用:
  3-phase inverters for motor drives
  Home appliances such as washing machines, refrigerators, air conditioners and sewing machine
ST公司
图1. STGIF10CH60TS-L框图和引脚配置图
ST公司
图2. STGIF10CH60TS-L应用电路图
  The STEVAL-IPM10F is a compact motor drive power board based on SLLIMM™ (small low-loss intelligent molded module) 2nd series (STGIF10CH60TS-L)。 It provides an affordable and easy-to-use solution for driving high power motors for a wide range of applications such as power white goods, air conditioning, compressors, power fans, high-end power tools and 3-phase inverters for motor drives in general. The IPM itself consists of short-circuit rugged IGBTs and a wide range of features like undervoltage lockout, smart shutdown, embedded temperature sensor and NTC, and overcurrent protection.
  The main characteristics of this evaluation board are small size, minimal BOM and high efficiency. It consists of an interface circuit (BUS and VCC connectors), bootstrap capacitors, snubber capacitor, hardware short-circuit protection, fault event and temperature monitoring. In order to increase the flexibility, it is designed to work in single- or three-shunt configuration and with double current sensing options such as using three dedicated onboard op-amps, or op-amps embedded in the MCU. The Hall/Encoder part completes the circuit. Thanks to these advanced characteristics, the system has been specifically designed to achieve fast and accurate current feedback conditioning, satisfying the typical requirements for field-oriented control (FOC)。
  The STEVAL-IPM10F is compatible with ST ’s STM32-based control board, enabling designers to build a complete platform for motor control.
图3. 1000W马达控制电源板STEVAL-IPM10F外形图(正面)
图4. 1000W马达控制电源板STEVAL-IPM10F外形图(背面)
ST公司
图5. 1000W马达控制电源板STEVAL-IPM10F架构图
  1000W马达控制电源板STEVAL-IPM10F主要特性:
  • Input voltage: 125 - 400 VDC
  • Nominal power: up to 1000 W
  • Nominal current: up to 6 A
  • Input auxiliary voltage: up to 20 V DC
  • Motor control connector (32 pins) interfacing with ST MCU boards
  • Single- or three-shunt resistors for current sensing (with sensing network)
  • Two options for current sensing: dedicated op-amps or through MCU
  • Overcurrent hardware protection
  • IPM temperature monitoring and protection
  • Hall sensors (3.3 / 5 V)/encoder inputs (3.3 / 5 V)
  • IGBT intelligent power module:
  – SLLIMM™ 2nd series IPM (STGIF10CH60TS-L - Full molded package)
  • Universal conception for further evaluation with bread board and testing pins
  • Very compact size
ST公司
图6. 1000W马达控制电源板STEVAL-IPM10F电路图(1)
ST公司
图7. 1000W马达控制电源板STEVAL-IPM10F电路图(2)
ST公司
图8. 1000W马达控制电源板STEVAL-IPM10F电路图(3)
ST公司
图9. 1000W马达控制电源板STEVAL-IPM10F电路图(4)
ST公司
图10. 1000W马达控制电源板STEVAL-IPM10F电路图(5)
ST公司
图11. 1000W马达控制电源板STEVAL-IPM10F电路图(6)
1000W马达控制电源板STEVAL-IPM10F材料清单:
ST公司
ST公司
图12. 1000W马达控制电源板STEVAL-IPM10F PCB设计图(1):顶层
图13. 1000W马达控制电源板STEVAL-IPM10F PCB设计图(2):底层
