315m无线模块怎么接收程序?程序是什么?
无线/传感
31人已加入
下面给大家整理下315M无线模块的接收程序
无线模块
#include
#include "string.h"
//液晶块
#define LCM_RW P3_6 //定义引脚
#define LCM_RS P3_5
#define LCM_E P3_7
#define LCM_Data P1
#define Busy 0x80 //用于检测LCM状态字中的Busy标识
typedef int byte;
typedef unsigned int  word;
void Read_Temp(void);
void mychar(char,char);
void WriteDataLCM(unsigned char WDLCM);
void WriteCommandLCM(unsigned char WCLCM,BuysC);
unsigned char ReadDataLCM(void);
unsigned char ReadStatusLCM(void);
void LCMInit(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void delay(word useconds)
for(;useconds>0;useconds--);
void mychar(char xx,char yy)
DisplayOneChar(0,0,0x54);
DisplayOneChar(1,0,0x65);
DisplayOneChar(2,0,0x6D);
DisplayOneChar(3,0,0x70);
DisplayOneChar(4,0,0x65);
DisplayOneChar(5,0,0x72);
DisplayOneChar(6,0,0x61);
DisplayOneChar(7,0,0x74);
DisplayOneChar(8,0,0x75);
DisplayOneChar(9,0,0x72);
DisplayOneChar(10,0,0x65);
DisplayOneChar(11,0,0x3A);
///////////////////////自定义字符
WriteCommandLCM(0x48, 0); //第一行
WriteDataLCM(0x06);
WriteCommandLCM(0x49, 0); //第2行
WriteDataLCM(0x09);
WriteCommandLCM(0x4a, 0); //第3
WriteDataLCM(0x09);
WriteCommandLCM(0x4b, 0); //第4
WriteDataLCM(0x06);
WriteCommandLCM(0x4c, 0); //第5
WriteDataLCM(0x00);
WriteCommandLCM(0x4d, 0); //第6
WriteDataLCM(0x00);
WriteCommandLCM(0x4e, 0); //第7
WriteDataLCM(0x00);
WriteCommandLCM(0x4f, 0); //第8
WriteDataLCM(0x00);
DisplayOneChar(xx,yy,0x01);
DisplayOneChar(xx+1,yy,0x43);
//写数据
ReadStatusLCM(); //检测忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在这后加小的延时
LCM_E = 0; //延时
LCM_E = 1;
//写指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测
if (BuysC) ReadStatusLCM(); //根据需要检测忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
//读状态
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //检测忙信号
return(LCM_Data);
void LCMInit(void) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号
WriteCommandLCM(0x08,1); //关闭显示
WriteCommandLCM(0x01,1); //显示清屏
WriteCommandLCM(0x06,1); // 显示光标移动设置
WriteCommandLCM(0x0C,1); // 显示开及光标设置
//按指定位置显示一个字符
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
X |= 0x80; //算出指令码
WriteCommandLCM(X, 0); //这里不检测忙信号,发送地址码
WriteDataLCM(DData);
//按指定位置显示一串字符  ***原来的遇到空格0x20就不显示***
unsigned char ListLength,j;
ListLength = strlen(DData);
Y &= 0x1;
if (X <= 0xF) //X坐标应小于0xF
for(j=0;j
DisplayOneChar(X, Y, DData[j]); //显示单个字符
X++;
//5ms延时
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//400ms延时
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
sbit W_IN = P2^1;
sbit W_OUT = P2^0;
unsigned char w_data;  //接收时用于存储两次上升沿之间的时长,发送时存储前半周
unsigned char send_busy = 0;//存储发送时后半周
unsigned char recv_timer = 0;
bit w_stat, last_w_stat;
unsigned char jiffies=0;
void clock_timer(void) interrupt 1 using 1{
if (send_busy){
if(w_data){
w_data--;
w_stat = 0;
}else{
send_busy--;
w_stat = 1;
W_OUT = w_stat;
}else{
w_stat = W_IN;
if (w_stat != last_w_stat){
last_w_stat = w_stat;
if (w_stat){
w_data = recv_timer;
recv_timer = 0;
if (~recv_timer)//if(recv_busy != 0xff)
recv_timer++;
jiffies++;
void clock_init(void){
jiffies = 0;
TMOD=0x02;
TH0=TL0=0x0ce;//12M,50us
// TH0=TL0=0x7a;//16M
// TH0=TL0=0x75;//16.59M
// TH0=TL0=0x72;//17M
// TH0=TL0=0x37;//24M
// TH0=TL0=0x47;//22.1844M, 100us
// TH0=TL0=0xa3;//22.1844M, 50us
EA=1;
ET0=1;
TR0=1;
void init_serialcomm(void)
SCON  = 0x50;       //SCON: serail mode 1, 8-bit UART, enable ucvr
TMOD |= 0x20;       //TMOD: timer 1, mode 2, 8-bit reload
PCON |= 0x80;       //SMOD=1;
TH1   = 0x0e6;       //Baud:2400  fosc=11.0592MHz  :f4
TL1   = 0x0e6;
//IE   |= 0x90;       //Enable Serial Interrupt
TR1   = 1;          // timer 1 run
RI=0;
TI=1;
void serial_out(unsigned char d){
while(!TI);
TI=0;
SBUF=(d);
void send_string_com(unsigned char *str,int strlen)//串口程序
{   unsigned char sum;
unsigned char k=0;
//serial_out(02);
do
{   //sum^=*(str+k);
serial_out(*(str + k));
//serial_out('a');
k++;
} while(k < strlen);
//serial_out(sum);
//serial_out('e');
//等待指定长度的串行数据到达,超时值为每两个字节之间的间隔时间而非等待整个串的时间.
//超时单位为time_out * 100uS
bit wait_serial(unsigned char *p, unsigned char len, unsigned char time_out){
unsigned int time=jiffies;
unsigned char n=0;
do{
if (RI){
p[n++]=SBUF;
RI=0;
if(n==len)
return 0;
time=jiffies;
}while(jiffies-time < time_out);
return 1;
sys_init(){
clock_init();
init_serialcomm();
//发送程序 开始
#define PULS_0_WIDTH 8   //低电平脉宽
#define PULS_1_WIDTH 16   //高电平脉宽
#define PULS_HEAD_WIDTH 8  //前导信号脉宽
#define PULS_START_WIDTH 24  //引导信号脉宽
#define PULS_STOP_WIDTH 8  //结束码脉宽
#define PULS_HEAD_COUNTS 16  //前导信号长度
unsigned char send_buf[16];
#define send_byts send_buf[0] //剩余字节数,发送完后为0
unsigned char sending_byte;  //当前正在发送的字节
unsigned char send_byte_p;  //已发送字节数(含正在发送的字节)
unsigned char send_bit_p;  //当前正在发送的字节已发送位数(含正在发送的位)
#define SEND_PROGRESSING 0x41
#define SEND_FAILED 0x21
#define SEND_SUCCESS 0x31
unsigned char send_stat = 0; //发送程序当前状态,为0时正常
unsigned char head_counts; //前导信号计数器(包括引导信号)
void start_send(){
send_byte_p = 0;
send_bit_p = 0;
send_stat = SEND_PROGRESSING;
head_counts = 16;
#define START_SEND(byts) send_buf[0]=byts;send_byts=byts;start_send()
//发送前应清除send_byte_p,send_bit_p,send_stat,并设置send_byts
//发送过程中可根据send_byts的值得到剩余字节数,根据send_byte_p的值得到已发送字节数.注意,将正在发送的字节当作已发送完毕.
//发送过程中可根据send_stat的值得到发送状态.
//发送完成后,send_byts和send_bit_p的值都为0.
#define SEND_PULS(x) w_data=send_busy=(x>>1)
void send(){
//下面两行在wirless()中已经执行过了,所以无需写上
// if (send_stat != SEND_PROGRESSING)
//  return;
if (!send_busy){
if(send_byts || send_bit_p){
if (head_counts){
head_counts--;
if(head_counts)
SEND_PULS(PULS_HEAD_WIDTH);
else
SEND_PULS(PULS_START_WIDTH);
}else{
if (send_bit_p == 0){
sending_byte = send_buf[send_byte_p];
send_byte_p++;
send_byts--;
send_bit_p = 8;
if(sending_byte & 0x80){
SEND_PULS(PULS_1_WIDTH);
}else{
SEND_PULS(PULS_0_WIDTH);
sending_byte <<= 1;
send_bit_p--;
}else{
SEND_PULS(PULS_STOP_WIDTH);
send_stat = SEND_SUCCESS;
return;
//发送程序 结束
//接收程序 开始
unsigned char recv_buf[16];
#define recv_byts recv_buf[0]  //应收到字节数,由每个包的第一个字节指定
unsigned char recving_byte;   //当前正在接收的字节
unsigned char recv_byte_p;   //已收到字节数(不含正在接收的字节)
unsigned char recv_bit_p;   //当前正在接收的字节等待接收位数(不含正在接收的位)
#define RECV_FAILED 0x31
#define RECV_SUCCESS 0x41
unsigned char recv_stat = 0;  //接收程序当前状态,为0时正常
unsigned char recv_step = 0;  //引导脉冲标志,为0时等待引导,为1时等待数据
#define TEST_PULS(puls_in, puls_type) (puls_in > puls_type - PULS_0_WIDTH / 2 && puls_in < puls_type + PULS_0_WIDTH / 2)
#define HEAD_NEED_RECIVED 8
void recv(){
unsigned puls_width;
if ((recv_stat == RECV_SUCCESS) || !w_data)
return;
puls_width = w_data;
w_data = 0;
#if 0 //输出脉宽
serial_out(puls_width);
// printhex(puls_width);
#endif
if (recv_step < HEAD_NEED_RECIVED){
if(TEST_PULS(puls_width, PULS_HEAD_WIDTH)){
recv_step++;
}else{
recv_step = 0;
}else if (recv_step == HEAD_NEED_RECIVED){
if(TEST_PULS(puls_width, PULS_START_WIDTH)){
serial_out(0xbb);
recv_byte_p = 0;
recv_bit_p = 8;
recv_stat = 0;
recv_step++;
}else{
if(!TEST_PULS(puls_width, PULS_HEAD_WIDTH)){
recv_step = 0;
}else{
//serial_out(puls_width);
recving_byte <<= 1;
if(TEST_PULS(puls_width, PULS_0_WIDTH)){
recving_byte &= 0xfe;
}else if(TEST_PULS(puls_width, PULS_1_WIDTH)){
recving_byte |= 1;
}else{
recv_step = 0;
serial_out(0xaa);
return;
recv_bit_p--;
if(recv_bit_p == 0){ //接收完一字节
recv_bit_p = 8;
//   serial_out(recving_byte); //输出接收到的字符
recv_buf[recv_byte_p] = recving_byte;
recv_byte_p++;
if(recv_byte_p == recv_byts){
recv_step = 0;
recv_stat = RECV_SUCCESS;
//接收程序 结束
#define SEND_DELAY_TIME 20  //防碰撞延迟(单位:毫秒)
unsigned char send_delay = SEND_DELAY_TIME;
#define VALID_PULS_COUNT 10
unsigned char valid_puls_counts = VALID_PULS_COUNT;
//碰撞检测在该函数中实现.由于无线模块本身的限制,碰撞检测为非完全检测,只能在发送前
//检测是否有其它单元在使用信道,在发送过程中受到的碰撞干扰是无法检测到的.经测试,效果还行
void wirless(){
if (send_stat == SEND_PROGRESSING && send_delay == 0){
send();
if (send_stat == SEND_SUCCESS)
}else{
recv();
if (recv_step > HEAD_NEED_RECIVED) //如果检测到当前有其它单元正在发送,继续等待
else{
if(TEST_PULS(w_data, PULS_0_WIDTH) //如果检测到当前有其它单元正在发送,继续等待
|| TEST_PULS(w_data, PULS_1_WIDTH)
//|| TEST_PULS(w_data, PULS_HEAD_WIDTH)
|| TEST_PULS(w_data, PULS_START_WIDTH)
//|| TEST_PULS(w_data, PULS_STOP_WIDTH)
if (valid_puls_counts)
valid_puls_counts--;
else
}else{
void Display_T()
DisplayOneChar(9,1,recv_buf[5]);
DisplayOneChar(8,1,recv_buf[4]);
DisplayOneChar(7,1,recv_buf[3]);
DisplayOneChar(6,1,recv_buf[2]);
DisplayOneChar(5,1,recv_buf[1]);
#define SCMD_SET_PORT 0x51
#define SCMD_GET_PORT 0x52
#define SCMD_RESET 0x61
#define SCMD_LCD_OUTSTR 0x71
#define SCMD_LCD_RESET 0x72
#define SCMD_LCD_SETXY 0x73
#define SCMD_LCD_SETLINE 0x74
#define SCMD_LCD_CLEAR 0x75
#define SRESP_GET_PORT_ERROR 0x41
#define SRESP_SET_PORT_ERROR 0x42
#define HEART_BEAT_INTERVAL 200  //心跳间隔 X / 1000   秒
unsigned int heart_beat_timer = HEART_BEAT_INTERVAL;
unsigned int last_jiffies=0;
void main(){
Delay400Ms(); //启动等待,等LCM讲入工作状态
LCMInit(); //LCM初始化
Delay5Ms(); //延时片刻(可不要)
mychar(10,1); //显示 自定义字符
init_serialcomm();
P0=0x0ff;
P2=0x00;
sys_init();
//send_string_com("ok",2);
//lcd_reset();
//lcd_power_on();
//lcd_self_test();
while(1){
if (jiffies - last_jiffies >= 20){//每次中断为50us,所以要20次才为1ms
last_jiffies = jiffies;
heart_beat_timer--;
if (send_delay)
send_delay--;
if (heart_beat_timer == 0){
while(1) {recv();if (recv_stat == RECV_SUCCESS)
P0_0=~P0_0;
send_string_com(recv_buf,strlen(recv_buf));
Display_T();
recv_stat = 0;break;}
recv_stat = 0;
/*#if 0
if (send_stat == 0){
//碰撞测试
START_SEND(8);
send_buf[1]='T';
send_buf[2]='e';
send_buf[3]='s';
send_buf[4]='t';
send_buf[5]='O';
send_buf[6]='k';
send_buf[7]='!';
lcd_out_string("sending:");
//send_string_com(send_buf,strlen(send_buf));
printhex(send_buf[0]);
printhex(send_buf[1]);
#endif
wirless();
if (send_stat == SEND_FAILED){
send_stat = 0;
}else if (send_stat == SEND_SUCCESS){
send_stat = 0;
P2_3=~P2_3;
//recv();
//send_string_com("start",5);
/*while(1) {recv();if (recv_stat == RECV_SUCCESS)
P0_0=~P0_0;
send_string_com(recv_buf,strlen(recv_buf));} }*/
/* if (recv_stat == RECV_SUCCESS){
//send_string_com("test1",5);
#if 1
//unsigned int i;
//for(i=0; i
// serial_out(recv_buf[i]); //输出接收到的字符
P0_0=~P0_0;
#else
//if (recv_buf[1]=='o')
//P0=0x00;
//lcd_out_string("data recived:");
//printhex(recv_buf[0]);
//printhex(recv_buf[1]);
//OutChar('\n');
//send_string_com("test3",5);
#endif
recv_stat = 0;
#if 0
if (RI){
unsigned char scmd[17];
wait_serial(scmd, 1, 0);
switch(scmd[0]){
case SCMD_RESET:
((void (code *) (void))0x0000) ();//软件复位
case SCMD_SET_PORT:
if (wait_serial(scmd, 2, 200))
break;
switch(scmd[0]){
case 0:
P0 = scmd[1];
break;
case 1:
P1 = scmd[1];
break;
case 2:
P2 = scmd[1];
break;
case 3:
P3 = scmd[1];
break;
break;
case SCMD_GET_PORT:
if (wait_serial(scmd, 1, 200))
break;
switch(scmd[0]){
case 0:
serial_out(P0);
break;
case 1:
serial_out(P1);
break;
case 2:
serial_out(P2);
break;
case 3:
serial_out(P3);
break;
break;
case SCMD_LCD_OUTSTR:
break;
scmd[scmd[0]] = 0;
if (wait_serial(scmd, scmd[0], 200))
break;
lcd_out_string(scmd);
break;
case SCMD_LCD_RESET:
lcd_reset();
break;
case SCMD_LCD_CLEAR:
lcd_clear();
break;
case SCMD_LCD_SETXY:
break;
SetXY(scmd[0], scmd[1]);
break;
case SCMD_LCD_SETLINE:
break;
SetLine(scmd[0]);
break;
default:
break;
#endif
