基于TQP3M9036下的Ultra Low Noise High Linearity LNA
消耗积分:0 | 格式:pdf | 大小:1.16 MB | 2018-07-25
分享资料个
  Applications 
  Repeaters 
  Mobile Infrastructure 
  LTE / WCDMA / CDMA / GSM 
  General Purpose Wireless 
  TDD or FDD systems
  General Description
  The TQP3M9036 is a high linearity, ultra low noise gain block amplifier in a small 2x2 mm surface-mount package. At 900 MHz, the amplifier typically provides high 19.8 dB gain, +36 dBm OIP3, and 0.45 dB Noise Figure while drawing 68 mA current from a 5V supply. The amplifier does not require any negative supplies for operation and can be biased from positive supply rails from 3.3 to 5 V.
  The device is housed in a lead-free/green/RoHScompliant industry-standard 2x2 mm package. The TQP3M9036 is internally matched using a high performance E-pHEMT process and only requires 4 external components for operation from a single positive supply: an external RF choke and blocking/bypass capacitors.
  The low noise amplifier contains an internal active bias to maintain high performance over temperature and integrates a shut-down biasing capability for TDD applications. The TQP3M9036 covers the 100−2000 MHz frequency band and is targeted for wireless infrastructure. The LNA is pin compatible with the high-band, 1500−2700 MHz TQP3M9037.
评论(0)
发评论
下载排行榜
