基于TQM7M6018下的 Dual-Broadband Power Amplifier Module
消耗积分:0 | 格式:pdf | 大小:0.05 MB | 2018-07-25
分享资料个
  Applications
  • WCDMA Handsets / Data Cards • Bands 1, 2, 5, 8, 25, 26 • BC0 / BC1 CDMA / EVDO Handsets / Data Cards • HSDPA / HSUPA / HSPA+
  Product Features
  • Integrated high efficiency dual-broadband two gain state power amplifier, VREG circuitry, input band select switch and directional coupler • Small Size = 4.0 mm x 3.0 mm • Low Quiescent Current in LPM • High Max Power PAE • No External Voltage Regulation Required • APT (Average Power Tracking) Capable
  General Description
  The TQM7M6018 PA module integrates two high efficiency BiHEMT power amplifiers, an input band select switch, a directional coupler and Vreg circuitry into a compact 4.0 mm x 3.0 mm package. TriQuint’s CuFlip® assembly technology and BiHEMT GaAs process provides a compact, low cost solution optimized for the Qualcomm WTR2605 transceiver with state-ofthe-art HPM PAE. The TQM7M6018 is a power amplifier module for bands 1, 2, 5, 8, 25 and 26 for use with WCDMA and CDMA modulations. The combination of high performance, low cost and small size makes the TQM7M6018 ideally suited for both mobile handset and data card applications.
评论(0)
发评论
下载排行榜
