基于TQM7M6025下的Power Amplifier Module
消耗积分:0 | 格式:pdf | 大小:0.19 MB | 2018-07-25
远不及你
分享资料个
  General Description
  The TQM7M6025 PA Module integrates two high efficiency BiHEMT power amplifiers, input band select switch, directional coupler and Vreg circuitry into a compact 4.0 mm x 3.0 mm package. TriQuint’s CuFlip® assembly technology and BiHEMT GaAs process provides a compact, low cost solution optimized for the Qualcomm WTR2605 transceiver with state-of-the-art HPM PAE. The TQM7M6025 is a power amplifier module for bands 2, 25 & 5, 26 for use with WCDMA and BC0 and BC1 for CDMA modulations. As a result of the combination of high performance, low cost and small size it is well suited for both mobile handset and data card applications.
  Applications
  BC0 / BC1 CDMA / EVDO Handsets / Data cards  Bands 2 & 5 WCDMA Handsets / Data Cards  HSDPA / HSUPA / HSPA+
  Product Features
  Integrated high efficiency dual-band two gain state power amplifier, VREG circuitry, input band select switch and directional coupler  Multi-Band coverage o High Band 2, 25, BC1 (1850 – 1915 MHz) o Low Band 5, 26, BC0 (814 – 849 MHz)  Small Size = 4.0 mm x 3.0 mm  Low Quiescent Current in LPM  High Max Power PAE  No External Voltage Regulation Required  APT (Average Power Tracking) Capable
评论(0)
发评论
下载排行榜
