基于FPGA和STM32的FSMC通信
可编程逻辑
1340人已加入
1、FSMC简介:FSMC即灵活的静态存储控制器,FSMC管理1GB空间,拥有4个Bank连接外部存储器,每个Bank有独立的片选信号和独立的时序配置;支持的存储器类型有SRAM、PSRAM、NOR/ONENAND、ROM、LCD接口(支持8080和6800模式)、NANDFlash和16位的PCCard。
2、在设计中将FPGA当做SRAM来驱动,使用库函数来实现FSMC的初始化配置代码如下:
//初始化外部SRAM
void FSMC_SRAM_Init(void)
    FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure; //定义FSMC初始化的结构体变量
    FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;           //用来设置FSMC读时序和写时序的指针变量
    GPIO_InitTypeDef  GPIO_InitStructure;                                      //初始化FSMC总线的IO口
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE|RCC_APB2Periph_AFIO,ENABLE);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);    //开启FSMC的时钟
    GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14
|GPIO_Pin_15|GPIO_Pin_0|GPIO_Pin_1
    |GPIO_Pin_7|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_4|GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;          //IO口配置为复用推挽输出
     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
     GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9
|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
     GPIO_Init(GPIOE, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_6;
    readWriteTiming.FSMC_AddressSetupTime = 14;
    readWriteTiming.FSMC_AddressHoldTime = 0x00;
    readWriteTiming.FSMC_DataSetupTime = 16;
    readWriteTiming.FSMC_BusTurnAroundDuration = 0;
    readWriteTiming.FSMC_CLKDivision = 0x00;
    readWriteTiming.FSMC_DataLatency = 0x00;
    readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;
    FSMC_NORSRAMInitStructure.FSMC_Bank=FSMC_Bank1_NORSRAM1;
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
    FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth= FSMC_MemoryDataWidth_16b;
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode=FSMC_BurstAccessMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
    FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
    FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming;
    FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
    delay_ms(50);
FPGA代码:
//fsmc read / write ep4ce6 demo
module fsmc(
    ab,     //address
    db,      //data
    wrn,      //wr
    rdn,      //rd
    resetn, //resetn
    csn,      //cs
    clk
    input[2:0]    ab;
    inout[15:0] db;
    input wrn;
    input rdn;
    input resetn;
    input csn;
    input clk;
    reg [15:0] ina = 16'd0;  //存储数据供ARM读
    reg [15:0] inb = 16'd1;
    reg [15:0] inc = 16'd2;
    reg [15:0] ind = 16'd3;
    reg [15:0] ine = 16'd4;
    reg [15:0] inf = 16'd5;
    reg [15:0] ing = 16'd6;
    reg [15:0] inh = 16'd7;
   reg [15:0] outa;
   reg [15:0] outb;
   reg [15:0] outc;
   reg [15:0] outd;
   reg [15:0] oute;
   reg [15:0] outf;
   reg [15:0] outg;
   reg [15:0] outh;
    wire rd;
    wire wr;
    reg [15:0] indata;
    assign rd = !(csn & rdn); //get rd pulse  ____|~~~~|______
    assign wr = !(csn & wrn) ; //get wr pulse  ____|~~~~|______
    /*********当不进行读写操作时db=indata*********
     *********当进行写操作时db=16'hzzzz**********
     *********当进行读操作时db=indata**********/
    assign db = rd? indata:16'hzzzz;
    //write data, 根据地址线选择八个空间写入,每个空间16位
    always @(negedge wr or negedge resetn)
    begin
        if(!resetn)begin
            outa <= 16'h0000;
            outb <= 16'h0000;
            outc <= 16'h0000;
            outd <= 16'h0000;
            oute <= 16'h0000;
            outf <= 16'h0000;
            outg <= 16'h0000;
            outh <= 16'h0000;
        end    else  begin
        case (ab)
            3'b000:outa <= db;
            3'b001:outb <= db;
            3'b010:outc <= db;
            3'b011:outd <= db;
            3'b100:oute <= db;
            3'b101:outf <= db;
            3'b110:outg <= db;
            3'b111:outh <= db;
            default:;
        endcase
        end
    end
    //red data 根据地址线选择8个空间读取,每个空间 16位
    always @(rd or !resetn)
    begin
        if(!resetn)indata <= 16'h0000;
        else  begin
        case (ab)
            3'b000:indata <= ina;
            3'b001:indata <= inb;
            3'b010:indata <= inc;
            3'b011:indata <= ind;
            3'b100:indata <= ine;
            3'b101:indata <= inf;
            3'b110:indata <= ing;
            3'b111:indata <= inh;
            default:;
        endcase
        end
    end
endmodule
