虚拟仪器技术的RLC测试仪
消耗积分:0 | 格式:rar | 大小:547 | 2010-03-30
王芳
分享资料个
虚拟仪器技术的RLC测试仪
针对传统RLC测试仪体积大、成本高等问题,运用虚拟仪器技术,根据伏安法测量
原理和相关分析测量算法,以虚拟仪器集成开发环境LabV IEW为平台,设计了RLC测试仪的硬件和软件部分。测试结果表明,电阻、电感和电容的基本测量范围分别为0. 001 ~1 000 kΩ、0. 010~50 mH和0101~470μF,测量误差的绝对值分别为δ≤115%、δ≤5%和δ≤5% ,满足测量精度要求。该测试仪不仅研制成本低、效率高,而且设计灵活、人机交互界面友好,具有较高的实用价值。
A imed at overcom ing the disadvantage of large volume and high cost of the traditional RLC parameters tester, this paper introduces the design of the hardware and the software of the RLC parameters tester by using the virtual instrument technology, based on the voltammetry measuring princip le and correlative analysis measuring algorithm and the p latform of the LabV IEW software.
The test results show that the fundamentalmeasurement ranges of the resistance (R) , the inductance (L) and the capacitance (C) are 0. 001~1 000 kΩ , 0. 010~50 mH and 0. 01~470μF respectively and the absolute values of the measurement errors areδ≤1. 5% , δ≤5% andδ≤5%. It follows that the requirements of the measurement accuracy are fulfilled. The advantages of lower cost,
higher efficiency, more flexible design and friendly Human2Machine Interface (HM I) give the instrument a higher app lication value.
评论(0)
发评论
下载排行榜
