数据: SN74CBT3251 1-of-8 FET Multiplexer and Demultiplexer 数据表
SN74CBT3251是一款兼容8的高速TTL兼容FET多路复用器和多路分解器。开关的低导通电阻允许以最小的传播延迟进行连接。
当输出使能(> OE )为低电平时,SN74CBT3251使能,S0,S1和S2选择B输出之一对于A输入数据。
所有商标均为各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
SN74CBT3251 | SN74CB3Q3251 | SN74CBTLV3251 |
8:1 | 8:1 | 8:1 |
1 | 1 | 1 |
Single | Single | Single |
N/A | N/A | N/A |
N/A | N/A | N/A |
4 | 2.3 | 2.3 |
5.5 | 3.6 | 3.6 |
5 | 3.5 | 5 |
200 | 500 | 200 |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 |
16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16SSOP: 48 mm2: 7.8 x 6.2(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) |
SOIC SSOP SSOP TSSOP VQFN | SSOP TSSOP TVSOP VQFN | SOIC SSOP TSSOP TVSOP VQFN |
5.5 | 3.6 | 3.6 |
15 | 11 | 40 |
128 | 64 | 128 |
600 | ||
3 | 2000 | 10 |
Powered off protection | Powered off protection | |
1 | 1 | 1 |
1 | 1 | |
15 | ||
4 | 3.5 | 6 |
1 | 1 | |
1.5 | 2 | |
0.8 | 0.8 | 0.8 |
2 | 1.7 | 2 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
