程序员必备专用单词快来学习吧!
消耗积分:0 | 格式:rar | 大小:0.14 MB | 2018-08-14
分享资料个
  本文档的主要内容是程序员必备的专用单词快来学习吧!
       file n. 文件;v. 保存文件
  command n. 命令,指令
  use v. 使用,用途
  program n. 程序
  line n. (数据,程序)行,线路
  if conj. 如果
  display vt. 显示,显示器
  set v. 设置,n. 集合
  key n. 键,关键字,关键码
  list n. 列表,显示,v. 打印
  by prep. 凭,靠,沿
  press v. 按,压
  with prep. 用,与,随着
  format n. 格式
  change v. 更换,改变,变动
  cursor n. 光标
  directory n. 目录,索引簿
  from prep. 从,来自,以来
  menu n. 菜单,目录
  option n. 任选,选择,可选项
  character n. 字符,符号,特性
  current n. 电流
  type n. 型,类型;v. 打印
  screen n. 屏幕,屏;v. 屏蔽
  specify v. 指定,规定,确定
  move v. 移动
  disk n. 盘,磁盘
  text n. 正文,文本
  drive v. 驱动;n. 驱动器
  see v. 看,看出,查看
  name n. 名,名称;vt. 命名
  record n. 记录
  box n. 箱,匣,(逻辑)框
  database n. 数据库
  help v. & n. 帮助
  memory n. 记忆存储,存储器
  which pron. 哪个,a. 那一个
  all a. 全,全部;ad. 完全
  on ad. 接通,导电,开
  copy n. 复制,v. 拷贝
  shell n. 壳,外壳
  delete vt. 删除,删去,作废
  enter v. 键入,送入
  margin n. 余量,边缘,边际
评论(1)
发评论
h1654156022.1315 2022-08-23
0 回复 举报
http://house.china.com.cn/sousou/%25CF%25C2%25B7%25D6%252C%2B%25BD%25F0%25B6%25A6%25B9%25FA%25BC%25CA%25D3%25E9%25C0%25D6%25B3%25C7B2024.cN%252C%25D0%25ED%25B2%25FD%25CE%25C0%25BC%25C6%25CE%25AF_2s.htm http://house.china.com.cn/sousou/%25BF%25AA%25B4%25FA%25C0%25ED%252C%2B%25C3%25E5%25B5%25E9%25C5%25B7%25D1%25C7%25BC%25AF%25CD%25C5B2024.cN_1s.htm http://house.china.com.cn/sousou/%25C9%25CF%25CF%25C2%25B7%25D6%252C%2B%25B9%25FB%25B8%25D2%25C0%25CF%25B0%25D9%25CA%25A4%25D3%25E9%25C0%25D6B2024.cN%252C%25CB%25DE%25D6%25DD%25B7%25C3%25CC%25B8_2s.htm http://house.china.com.cn/sousou/%25BA%25F3%25CC%25A8%252C%2B%25C3%25E5%25B5%25E9%25C1%25FA%25CC%25DA%25D3%25E9%25C0%25D6B2024.cN%252C%25C4%25CF%25C6%25BD%25D5%25D0%25C6%25B8_50s.htm http://house.china.com.cn/sousou/VIP%252C%2B%25B9%25FB%25B8%25D2%25C1%25FA%25CC%25DA%25B9%25FA%25BC%25CA%25B9%25AB%25CB%25BEB2024.cN%252C%25B8%25B7%25D1%25F4%25BD%25BB%25B9%25DC%25BE%25D6_70s.htm 收起回复
下载排行榜
全部1条评论
