数据: CD405xB CMOS Single 8-Channel Analog Multiplexer/Demultiplexer With Logic-Level Conversion 数据表
CD405xB模拟多路复用器和解复用器是数字控制的模拟开关,具有低导通阻抗和极低的关断漏电流。这些多路复用器电路在整个V DD -V SS 和V DD - V EE 电源上消耗极低的静态功耗 - 电压范围,与控制信号的逻辑状态无关。
所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
CD4053B | CD4051B | CD4051B-MIL | CD4051B-Q1 | CD4052B | CD4053B-MIL | CD4053B-Q1 |
2:1 SPDT | 8:1 | 8:1 | 4:1 | 2:1 SPDT | ||
3 | 1 | 1 | 2 | 3 | ||
Single Dual | Single Dual | Single Dual | Single Dual | Single Dual | ||
-10 | -10 | -10 | -10 | -10 | ||
0 | 0 | 0 | 0 | 0 | ||
5 | 5 | 5 | 5 | 5 | ||
20 | 20 | 20 | 20 | 20 | ||
125 | 125 | 125 | 125 | 125 | 125 | 125 |
30 | 20 | 20 | 25 | 30 | ||
Catalog | Catalog | Military | Automotive | Catalog | Military | Automotive |
-55 to 125 | -55 to 125 | -55 to 125 | -40 to 125 | -55 to 125 | -55 to 125 | -40 to 125 |
See datasheet (PDIP) 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (CDIP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) |
PDIP SO SOIC TSSOP | PDIP SO SOIC TSSOP | CDIP | TSSOP | PDIP SO SOIC TSSOP | CDIP | SOIC |
1300 | 1300 | 240 | 1300 | 1300 | 240 | 1300 |
10 | 10 | 10 | 10 | 10 | ||
0.04 | 0.04 | 0.04 | 0.04 | 0.04 | ||
3000 | 3000 | 3000 | 3000 | 3000 | ||
Control logic voltage translation Dual supply Break-before-make | Control logic voltage translation Dual supply Break-before-make | Low Power Break-before-make | Control logic voltage translation Dual supply Break-before-make | Control logic voltage translation Dual supply Break-before-make | Low Power Break-before-make | Dual supply |
1.5 | 2 | |||||
2.5 | 3 | |||||
Vdd*.3 | Vdd*.3 | Vdd*.3 | Vdd*.3 | Vdd*.3 | ||
Vdd*.7 | Vdd*.7 | Vdd*.7 | Vdd*.7 | Vdd*.7 | ||
无样片 | 无样片 |
收藏
评论(0)
©2021 elecfans.com.All Right Reserved
