A7533D pdf datasheet (Low Powe
消耗积分:0 | 格式:rar | 大小:777 | 2008-08-19
吴湛
分享资料个
The A7533D is a low-cost 2 x 2 switch matrix in a 20-lead QFN package for use in RF multiplexing applications from 200 to 3000 MHz. A positive voltage controlled 2 bit decoder is integrated on the switch. The switch may be used in 50/75 ohm systems.
Both switch outputs (OP1 & OP2) can independently select any of the four inputs (H, V) or simultaneously select the same inputs. Note that the switch is bi-directional and input/output functionality may be interchanged.
评论(0)
发评论
下载排行榜
