THS14F01/THS14F03,pdf (14-BIT,
消耗积分:0 | 格式:rar | 大小:329 | 2010-06-04
分享资料个
The THS14F01 and THS14F03 are 14-bit, 1/3 MSPS, single supply analog-to-digital converters with a FIFO, internal reference, differential inputs, programmable input gain, and an on-chip sample and hold amplifier.
Implemented with a CMOS process, the device has outstanding price/performance and  ower/speed ratios. The THS14F01 and THS14F03 are designed for use with 3.3-V systems, and with a high-speed uP compatible parallel interface, making them the first choice for solutions based on high-performance DSPs like the TI TMS320C6000 series.
The THS14F01 and THS14F03 are available in a TQFP-48 package in standard commercial and industrial temperature ranges.
评论(0)
发评论
下载排行榜
