基于UCC28911型号具有初级侧稳压和恒流控制功能的高电压反激开关
今日头条
1100人已加入
  The UCC28910 and UCC28911 are high-voltage flyback switchers that provide output voltage and current regulation without the use of an optical coupler. Both devices incorporate a 700-V power FET and a controller that process operating information from the flyback auxiliary winding and power FET to provide a precise output voltage and current control. The integrated high-voltage current source for startup that is switched off during device operation, and the controller current consumption is dynamically adjusted with load. Both enable the very low stand-by power consumption.
  Control algorithms in the UCC28910 and UCC28911, combining switching frequency and peak primary current modulation, allow operating efficiencies to meet or exceed applicable standards. Discontinuous conduction mode (DCM) with valley switching is used to reduce switching losses. Built-in protection features help to keep secondary and primary component stress levels in check across the operating range. The frequency jitter helps to reduce EMI filter
  特性
  Constant-Voltage (CV) and Constant-Current (CC) Output Regulation Without Optical-Coupler
  ±5% Output Voltage Regulation Accuracy
  ±5% Output Current Regulation With AC Line and Primary Inductance Tolerance Compensation
  700-V Start-Up and Smart Power Management Enables <30-mW Standby Power
  115-kHz Maximum Switching Frequency Design for High-Power Density
  Valley Switching and Frequency Dithering to Ease EMI Compliance
  Thermal Shut Down
  Low Line and Output Over-Voltage Protection
  相关终端应用
  Circuit Breaker
  LCD 测试设备
  交流/直流功率计和分析器
  仪表(实验室、分析、现场)
  内存和半导体测试设备
  冰箱和冰柜
  割草机
  单相 UPS
  吸尘器
  咖啡机
  商用 DIN 导轨电源
  家用水泵和风扇
  家电压缩机
  工业 AC-DC
  工业机器人检测模块
  无管式空调室内系统
  无管式空调室外装置
  无线控制
  智能插件
  有线控制
  机器人割草机
  油烟机
  洗碗机
  洗衣机和干衣机
  混料器、搅拌器和食品加工机
  烹饪灶具
  由市电供电的工具
  电器用户界面和连接模块
  电器电池充电器
  电子病床和床控制器
  电网通信模块 - 无线通信
  电能质量 - 电能质量分析仪
  真空机器人
  空气净化器和加湿器
  输液泵
  风扇
  相关料号推荐:
  UCC28880DR
  • 相关推荐
