Avnet MiniZed单核Zynq 7Z007S入门开发方案
1.2w人已加入
Avnet公司的MiniZed是Xilinx公司的单核Zynq 7Z007S器件的开发板,目标在具有低成本原型平台的入门级Zynq开发设计师,可使设计者开发或评估Zynq处理器子系统(PS)和可编逻辑(PL)架构.开发板具有通过USB, Wi-Fi和蓝牙进行板上连接,外设能插入两个Pmod兼容的连接器, Arduino兼容的屏蔽接口或USB 2.0主接口, JTAG电路使用一根电缆通过 USB口连接笔记本电脑,就可以使开发板运行起来.主要应用在入门级/低成本Zynq开发环境,采Wi-Fi和蓝牙的无线设计和演示,采用麦克风输入的音频信号处理,板上和外设传感器的IoT/云连接.本文介绍了MiniZed开发板主要特性和所支持特性,框图和拓扑图,电路图,材料清单和PCB设计图.
MiniZed™ is a single-core Zynq 7Z007S development board.With the advent of the latest cost-optimized portfolio fromXilinx, this board targets entry-level Zynq developers witha low-cost prototyping platform.
This compact design features on-board connectivity through USB, Wi-Fi andBluetooth. Peripherals can be plugged into dual Pmod-compatible connectors,the Arduino-compatible shield interface or the USB 2.0 host interface. JTAGcircuitry is incorporated onto the MiniZed base board, so with a single micro-USB cable to your laptop you are already up and running. User LED’s, a buttonand a switch allow for a physical board interface.
Micron memory solutions are presented for QSPI flash, DDR3L memory andon-board eMMC instead of an external SD card. The Murata Type 1DX wirelesssolution incorporates 802.11b/g/n Wi-Fi as well as Bluetooth 4.1, whichprovides both Bluetooth Classic and Low Energy (BLE). The integrated powersupply from Dialog generates all on-board voltages, while an auxiliary supplyinput can be used to power designs that require additional current. From STMicro there is an on-board motion and temperature sensor, as well as a digitalmicrophone.
MiniZed provides for an efficient hardware reference design, while it is alsoan inexpensive board that can be used to run workshops and tutorials. Theboard aims to showcase the power of Zynq, where the Cortex A9 processorcore integrates seamlessly with the programmable fabric to provide signalprocessing and control solutions. The on-board digital microphone serves asan input for a variety of illustrations of how to implement FIR filters, FFT’s anddirect memory access.
图1.MiniZed开发板外形图
MiniZed开发板主要特性:
 Xilinx Zynq XC7Z007S SoC
 Memory
o Micron 512 MB DDR3L
o Micron 128 MB QSPI flash
o Micron 8GB eMMC mass storage
 Configuration and Debug
o On-board USB to JTAG and debug UART circuit
 Communications
o Murata "Type 1DX" wireless module with 802.11b/g/n Wi-Fi and Bluetooth 4.1 plus EDR and BLE (Bluetooth Low Energy)
o USB 2.0 host interface
 Power
o Dialog Semiconductor DA9062 PMIC (Power Management IC)
 Expansion connectors
o Arduino-compatible shield interface
o 2 x Pmod-compatible interfaces
 Sensors
o ST Micro LIS2DS12 Accelerometer and Temperature sensor
o ST Micro MP34DT05 digital MEMS microphone
 General Purpose I/O
o Reset button
o User button
o User switch
o Two user bi-element LEDs
MiniZed开发板支持下面特性:
̶ Zynq single-core System-on-Chip (SoC) device : XC7Z007S-1CLG225C
̶ Storage ̶ Micron 512 MB DDR3L
̶ Micron 128 Mb Quad SPI NOR flash
̶ Micron 8GB eMMC
̶ Micro USB connector for on-board JTAG and UART via FTDI device
̶ Micro USB connector for external power in high power mode
̶ USB Type A host connector for a USB slave device connection
̶ Arduino Shield connectors for Arduino-compatible peripherals
̶ Pmod sockets x 2
̶ Murata wireless “Type 1DX” module: LBEE5KL1DX ̶ based on the Cypress BCM4343W
̶ 2.4 GHz Wi-Fi complies with 802.11b/g/n
̶ Bluetooth ̶ Bluetooth Version 4.1 plus EDR (Enhanced Data Rate)
̶ Power Class 1 (10dBm max) and BLE (Bluetooth Low Energy)
̶ Leverages certification of reference design that uses PCB antenna
̶ Dialog PMIC (power-management IC) with I2C interface : DA9062
̶ Bi-element user LEDs x 2
̶ Single-color LEDs for Power, Config Done, Wifi, and Bluetooth
̶ Reset pushbutton & user PS pushbutton x 1
̶ User PL switch x 1
̶ ST Micro Accelerometer and Temperature sensor : LIS2DS12
̶ ST Micro MEMS microphone sensor : MP34DT05
MiniZed开发板目标应用:
--Entry level/Low-cost Zynqdevelopment environment
--Training, prototyping andproof-of-concept demo platform
--Wireless design and demonstrationsusing Wi-Fi and Bluetooth
--Audio signal processing examplesusing the microphone input
--IoT/Cloud connectivity for on-boardand peripheral sensors
Avnet
图2.MiniZed开发板框图
Avnet
图3.MiniZed开发板拓扑图
Avnet
图4.MiniZed开发板电路图(1)
Avnet
图5.MiniZed开发板电路图(2)
Avnet
图6.MiniZed开发板电路图(3)
Avnet
图7.MiniZed开发板电路图(4)
Avnet
图8.MiniZed开发板电路图(5)
Avnet
图9.MiniZed开发板电路图(6)
Avnet
图10.MiniZed开发板电路图(7)
Avnet
图11.MiniZed开发板电路图(8)
MiniZed开发板材料清单:
Avnet
Avnet
Avnet
图12.MiniZed开发板PCB设计图(1)
图13.MiniZed开发板PCB设计图(2)
图14.MiniZed开发板PCB设计图(3)
图15.MiniZed开发板PCB设计图(4)
图16.MiniZed开发板PCB设计图(5)
图17.MiniZed开发板PCB设计图(6)
Avnet
图18.MiniZed开发板PCB设计图(7)
Avnet
图19.MiniZed开发板PCB设计图(8)
图20.MiniZed开发板PCB设计图(9)
图21.MiniZed开发板PCB设计图(10)
Avnet
图22.MiniZed开发板PCB设计图(11)
Avnet
图23.MiniZed开发板PCB设计图(12)
