LM358与LMV358的区别,LM358运放介绍
1.2w人已加入
关键字:LM358,LMV358
LMV358适合用于低功耗场合,通俗一点的说法是LMV358是LM358的低电压低功耗版本,两者的管教和应用原理图兼容。
两者主要有以下几点不同:
1、用LM358代替LMV358耗电量会大很多,一倍以上。(210uA与500uA)
2、电源电压不同,LMV358 最低可以2.7V最高仅能5V,而LM358则宽得多,可单电源3V到32V,也可双电源±1.5V到±16V。
2、输出特性会差很多,LMV358 有轨到轨输出特性,而LM358就差很多。
LM358 Features:
Large dc voltage gain: 100 dB
Wide bandwidth: 1 MHz
Wide power supply range:
— Single supply: 3V to 32V
— or dual supplies: ±1.5V to ±16V
Very low supply current drain (500 μA)—essentially
independent of supply voltage
Low input offset voltage: 2 mV
Input common-mode voltage range includes ground
Differential input voltage range equal to the power supply voltage
Large output voltage swing: 0V to V+− 1.5V
LMV358 Features
Guaranteed 2.7V and 5V Performance
No Crossover Distortion
Gain-Bandwidth Product 1MHz
Low Supply Current:LMV358 210μA
Rail-to-Rail Output Swing @10kΩ
V+ −10mV
V− +65mV
VCM −0.2V to V+−0.8V
  • 相关推荐
