PIC单片机编程器2,PIC programmer
1.2w人已加入
关键字:PIC单片机编程器,编程器电路,编程器制作
This PIC Programmer was designed by Jens Madsen. If you require more information try the guestbook for the PIC Programmer.
This PIC Programmer is able to program: PIC12C5XX, 12C67X, 24CXX, 16C55X, 16C61, 16C62X, 16C71, 16C71X, 16C8X, 16F8X, ISO-CARD's with ASF and other serial programmable chips by adapter.
The PIC Programmer can connect to a 25/9 pin serial port, use the serial pin-out tables to determine the correct pins to use when wiring. The schematic above assumes you are using a 9 pin female connector (to connect to an ATX motherboards).
Software
There are probably several applications available for the PIC Programmer II, but the two most popular, I beleive, are:
  • PP2 utility, by Malte Kiesel (a DOS based program)
  • IC-Prog Programmer, by Bonny Gijzen (Windows based program)
  • For more software (including PIC16C84 utilities) check out Jens' website
  • 相关推荐
