MATLAB 2013a 的 license 过期 的解决办法
两种解决办法:自己亲测可以使用
第一种办法:修改系统的时间到你的license未过期的时候,你就依然可以使用MATLAB2013a。但是这种方法治标不治本
第二种方法:彻底解决,强烈推荐。打开text文本编辑器,新建一个license.lic的文件,文件中的内容如下。之后用这个文件覆盖掉MATLAB安装根目录的license文件夹里原来的license.lic文件。关机重启后,就可以正常使用MATLAB2013a。
license.lic文件中写入的内容:
INCREMENT Aerospace_Blockset MLM 99 permanent uncounted\
      A05070F00D1EB1F92326 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=216 SN=888888 TS_OK
INCREMENT Aerospace_Toolbox MLM 99 permanent uncounted \
      6090F0C08395D4289512 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=237 SN=888888 TS_OK
INCREMENT Bioinformatics_Toolbox MLM 99 permanent uncounted\
      40E0B0406DE56D23A426 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=190 SN=888888 TS_OK
INCREMENT Cert_Kit_IEC MLM 99 permanent uncounted \
      9080309041D2DCCB2B10 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=179 SN=888888 TS_OK
INCREMENT Communication_Blocks MLM 99 permanent uncounted\
      80E010304ACCEEB5E0AA VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=77 SN=888888 TS_OK
INCREMENT Communication_Toolbox MLM 99 permanent uncounted\
      C0003000770A1A086530 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=162 SN=888888 TS_OK
INCREMENT Compiler MLM 99 permanent uncounted60D0C0F0DC03C2F72FF7 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=232SN=888888 TS_OK
INCREMENT Control_Toolbox MLM 99 permanent uncounted \
      6020E0B00B7ECE0893BB VENDOR_STRING=QQ=47399897HOSTID=ANY ck=7 \
      SN=888888 TS_OK
INCREMENT Curve_Fitting_Toolbox MLM 99 permanent uncounted\
      10703080061FF9DA5A81 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=229 SN=888888 TS_OK
INCREMENT Data_Acq_Toolbox MLM 99 permanent uncounted \
      E0B0E0E05124CF4A1A8D VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=21 SN=888888 TS_OK
INCREMENT Database_Toolbox MLM 99 permanent uncounted \
      0010D0B02CA7353F8314 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=230 SN=888888 TS_OK
INCREMENT Datafeed_Toolbox MLM 99 permanent uncounted \
      40905060D1ECD939538F VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=185 SN=888888 TS_OK
INCREMENT Dial_and_Gauge_Blocks MLM 99 permanent uncounted\
      A0F05070AA9AEBF40588 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=226 SN=888888 TS_OK
INCREMENT Distrib_Computing_Toolbox MLM 99 permanent uncounted\
      5000D00031D2C6B89F9C VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT EDA_Simulator_Link MLM 99 permanent uncounted\
      E070C0C02B4B90B5A8D0 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=205 SN=888888 TS_OK
INCREMENT Econometrics_Toolbox MLM 99 permanent uncounted\
      505010F00EB1289A73BA VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=149 SN=888888 TS_OK
INCREMENT Embedded_IDE_Link MLM 99 permanent uncounted \
      90E01090A9BDA4FF67D7 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=254 SN=888888 TS_OK
INCREMENT Excel_Link MLM 99 permanent uncountedE0800080FED6DF10E43F \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=207SN=888888 TS_OK
INCREMENT Filter_Design_HDL_Coder MLM 99 permanent uncounted\
      3050B02039903259577E VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=181 SN=888888 TS_OK
INCREMENT Filter_Design_Toolbox MLM 99 permanent uncounted\
      3000E0B02C875CDF5823 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=239 SN=888888 TS_OK
INCREMENT Fin_Derivatives_Toolbox MLM 99 permanent uncounted\
      70A010D017A8FA7CE955 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=247 SN=888888 TS_OK
INCREMENT Financial_Toolbox MLM 99 permanent uncounted \
      20E050A0ACC6A69E7AEE VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=241 SN=888888 TS_OK
INCREMENT Fixed-Point_Blocks MLM 99 permanent uncounted\
      E0206040ED6EF9BCCB3B VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=11 SN=888888 TS_OK
INCREMENT Fixed_Income_Toolbox MLM 99 permanent uncounted\
      50E090D0C130F6416176 VENDOR_STRING=QQ=47399897HOSTID=ANY \
       ck=132 SN=888888 TS_OK
INCREMENT Fixed_Point_Toolbox MLM 99 permanent uncounted\
      C07000703494010EF55C VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=154 SN=888888 TS_OK
INCREMENT Fuzzy_Toolbox MLM 99 permanent uncounted \
      D04010B048FB8D350E4E VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=233 SN=888888 TS_OK
INCREMENT GADS_Toolbox MLM 99 permanent uncounted \
      50D0900087384B51643A VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=210 SN=888888 TS_OK
INCREMENT Identification_Toolbox MLM 99 permanent uncounted\
      00707080A0CC0D8FB71E VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Image_Acquisition_Toolbox MLM 99 permanent uncounted\
      50D0D0905C22130C4D2A VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=208 SN=888888 TS_OK
INCREMENT Image_Toolbox MLM 99 permanent uncounted \
      B01030E0F517B496275C VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=133 SN=888888 TS_OK
INCREMENT Instr_Control_Toolbox MLM 99 permanent uncounted\
      80C0505033C162F3017F VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=169 SN=888888 TS_OK
INCREMENT MAP_Toolbox MLM 99 permanent uncountedC090E0E022BD3BA852B3 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=4SN=888888 TS_OK
INCREMENT MATLAB_Report_Gen MLM 99 permanent uncounted \
      80B000B00052F620FB11 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT MATLAB_Distrib_Comp_Engine MLM 99 permanentuncounted \
      804080300CB545FBECE8 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT MATLAB_Builder_for_Java MLM 99 permanent uncounted\
      404040707C2CA5639DEE VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=186 SN=888888 TS_OK
INCREMENT MATLAB_Builder_for_dot_Net MLM 99 permanentuncounted \
      8070E0D0FFAA645DA39D VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=255 SN=888888 TS_OK
INCREMENT MATLAB MLM 99 permanent uncounted50E0F0D08F6CEF24CC5B \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=14SN=888888 TS_OK
INCREMENT MATLAB_Excel_Builder MLM 99 permanent uncounted\
      50106010BCBF479623D9 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=206 SN=888888 TS_OK
INCREMENT MBC_Toolbox MLM 99 permanent uncountedB05000C02F157C5BEE28 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=198SN=888888 TS_OK
INCREMENT MPC_Toolbox MLM 99 permanent uncounted3050206087BF1C33045E \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=203SN=888888 TS_OK
INCREMENT Neural_Network_Toolbox MLM 99 permanent uncounted\
      D0009010451EEB5A283F VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=198 SN=888888 TS_OK
INCREMENT OPC_Toolbox MLM 99 permanent uncounted50F070404BE7E269740A \
INCREMENT Optimization_Toolbox MLM 99 permanent uncounted\
      E0F00030546D043DF202 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=152 SN=888888 TS_OK
INCREMENT PDE_Toolbox MLM 99 permanent uncounted5080705081D393548E6E \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=166SN=888888 TS_OK
INCREMENT Power_System_Blocks MLM 99 permanent uncounted\
      90405000B77AC9D2CBB9 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Qual_Kit_DO MLM 99 permanent uncountedD01010C04E05A80BCD10 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=190SN=888888 TS_OK
INCREMENT RF_Blockset MLM 99 permanent uncountedA0A00020B1FED5C15465 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=201SN=888888 TS_OK
INCREMENT RF_Toolbox MLM 99 permanent uncounted90F0905068868B4A97C8 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=168SN=888888 TS_OK
INCREMENT RTW_Embedded_Coder MLM 99 permanent uncounted\
      A0D0E0C0B3978D64A1A3 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=250 SN=888888 TS_OK
INCREMENT Real-Time_Win_Target MLM 99 permanent uncounted\
      300060D0E68A928A0DBC VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Real-Time_Workshop MLM 99 permanent uncounted\
      7020D04006040066FAEA VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=134 SN=888888 TS_OK
INCREMENT Robust_Toolbox MLM 99 permanent uncounted \
      1040201098A2D1E80D25 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=173 SN=888888 TS_OK
INCREMENT SIMULINK MLM 99 permanent uncounted30D05030E2F9BBB8FCC2 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=213SN=888888 TS_OK
INCREMENT SIMULINK_Report_Gen MLM 99 permanent uncounted\
      E070B070769E869B6A03 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT SL_Verification_Validation MLM 99 permanentuncounted \
      C0309000FB238CC772CC VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=251 SN=888888 TS_OK
INCREMENT Signal_Blocks MLM 99 permanent uncounted \
      F000A0702665C46E07FF VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=196 SN=888888 TS_OK
INCREMENT Signal_Toolbox MLM 99 permanent uncounted \
      E070B0403768324D14C1 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT SimBiology MLM 99 permanent uncounted404080202CFCE52296A3 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=187SN=888888 TS_OK
INCREMENT SimDriveline MLM 99 permanent uncounted \
      B030A0704195F94612EF VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=163 SN=888888 TS_OK
INCREMENT SimElectronics MLM 99 permanent uncounted \
      F0D050A035E4883B1E9D VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=246 SN=888888 TS_OK
INCREMENT SimEvents MLM 99 permanent uncounted30E02040EB0C922C71A0 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=216SN=888888 TS_OK
INCREMENT SimHydraulics MLM 99 permanent uncounted \
      C07090B0F394787D61B7 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT SimMechanics MLM 99 permanent uncounted \
      909000103231C13BB4BB VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=148 SN=888888 TS_OK
INCREMENT Simscape MLM 99 permanent uncounted8020D0906FAC13D095EC \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=211SN=888888 TS_OK
INCREMENT Simulink_Control_Design MLM 99 permanent uncounted\
      D09060704E819BCDDD32 VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Simulink_Design_Optim MLM 99 permanent uncounted\
      6020C080F9B2D2F92E1C VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=243 SN=888888 TS_OK
INCREMENT Simulink_Design_Verifier MLM 99 permanent uncounted\
      8080D0002C390CBB546E VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Simulink_HDL_Coder MLM 99 permanent uncounted\
      F05000C0108BB935AD39 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=215 SN=888888 TS_OK
INCREMENT Simulink_PLC_Coder MLM 99 permanent uncounted\
      803090F0C42068269D45 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=194 SN=888888 TS_OK
INCREMENT Spline_Toolbox MLM 99 permanent uncounted \
      30E0B0A014330227515B VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=112 SN=888888 TS_OK
INCREMENT Stateflow_Coder MLM 99 permanent uncounted \
      2050D0B06F85F87E216B VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=199 SN=888888 TS_OK
INCREMENT Stateflow MLM 99 permanent uncounted4030C0C01E0B917BED3F \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=223SN=888888 TS_OK
INCREMENT Statistics_Toolbox MLM 99 permanent uncounted\
      7010C05033AC51015B7C VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=178 SN=888888 TS_OK
INCREMENT Symbolic_Toolbox MLM 99 permanent uncounted \
      80D09090A1ADD082F35D VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=33 SN=888888 TS_OK
INCREMENT SystemTest MLM 99 permanent uncountedB0A0A0E039DA5A2F4AA0 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=29SN=888888 TS_OK
INCREMENT Target_Support_Package MLM 99 permanent uncounted\
      207000609E1847CC5A6E VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=172 SN=888888 TS_OK
INCREMENT Vehicle_Network_Toolbox MLM 99 permanent uncounted\
      00C02010ABF2A8B8152B VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Video_and_Image_Blockset MLM 99 permanent uncounted\
      107070B0AF7901361B1E VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Virtual_Reality_Toolbox MLM 99 permanent uncounted\
      B010002042F6C767442D VENDOR_STRING=QQ=47399897HOSTID=ANY \
INCREMENT Wavelet_Toolbox MLM 99 permanent uncounted \
      30C0F0800F9B41DD8577 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=238 SN=888888 TS_OK
INCREMENT XPC_Embedded_Option MLM 99 permanent uncounted\
      102000905C51C5DE4BF0 VENDOR_STRING=QQ=47399897HOSTID=ANY \
      ck=174 SN=888888 TS_OK
INCREMENT XPC_Target MLM 99 permanent uncounted6090B0000421BEBA6810 \
      VENDOR_STRING=QQ=47399897 HOSTID=ANY ck=136SN=888888 TS_OK
INCREMENT Sensor_Array_Toolbox MLM 99 permanent uncounted\
      E0008030D7E6251042F1 VENDOR_STRING=QQ=47399897HOSTID=ANY \
HostID前面要加空格
