TRF2443 EEPROM User's Guid
消耗积分:0 | 格式:rar | 大小:97 | 2010-07-08
打马过草原
分享资料个
The TRF2443 contains an integrated EEPROM that can easily be read from an external read-back pin (pin
RDBKSPI, pin 64). The embedded EEPROM contains information measured and stored at RF final test
that allows the user to optimize performance of the TRF2443. In order to ensure the integrity of the
EEPROM contents, it is important that the user adhere to the correct power supply sequence. The pin
VCCREF (pin 15) must be powered to 3.3 V at the same time or before pin VCCSPI (pin 75). If VCCSPI is
powered before VCCREF, the contents of the EEPROM registers will be erased. For this reason, it is
recommended that the user read the EEPROM contents once and store this data in memory outside of the
TRF2443 for future use. The EEPROM SPI block (address < 00 >) has three 32-bit registers (Reg0, 1, 2).
Register 1 and Register 2 contain the actual bit information stored in the EEPROM registers. These
registers are READ ONLY. Register 0 is used to invoke a read-back operation of the information stored in
the EEPROM registers 1 and 2 by specifying which register to read back. This register is a WRITE ONLY
register.
评论(0)
发评论
下载排行榜
