DIOPSIS 940HF Atmel brings flo
消耗积分:0 | 格式:rar | 大小:710 | 2010-07-09
分享资料个
Atmel's Diopsis® 940HF is designed for data-intensive applications requiring the combination of a high
performance microcontroller unit and floating point DSP capablities. Its parallel architecture incorporates
a VLIW floating point processor, Magic DSP™, delivering up to 10 floating point operations per cycle and an
ARM926EJ-S™ ARM® Thumb® RISC CPU. The ARM926EJ-S supports the Jazelle® technology for Java®
acceleration. A rich set of peripherals and internal memory provide a highly flexible and integrated system
solution. The system-on-chip embeds distributed DMA to support data moves related to the on chip peripherals
and to the processing performed by mAgic. The availability of on-chip memory for Magic and ARM reduces the
data traffic on the external bus and allows an effective usage of the available processing and I/O resources.
评论(0)
发评论
下载排行榜
