STM32单片机ILI9325系列TFT的驱动原理解析
控制/MCU
1811人已加入
为了更好,更深入学习了解ILI9325系列TFT的驱动原理,自己做了一块TFT板子。为了方便测试,在上面集成了STM32芯片,到时候做实验的时候就焊接STM32测试,如果只是使用,就直接焊接TFT就行了。板子还在做,先上原理图与PCB。
STM32单片机
-------------------------等板子回来,再测试,总结继续-------------
--------板子回来了,焊接好了,简单测试了一下!-----------
---------第二部分---------------ili9320.h------------------代码简单分析------
#ifndef _ILI9320_H_
#define _ILI9320_H_
#include “stm32f10x.h”
#define DB0_7_RCC RCC_APB2Periph_GPIOB
#define DB_8_15_RCC RCC_APB2Periph_GPIOC
#define nCsPin_RCC RCC_APB2Periph_GPIOC
#define nCsPin_Port GPIOC
#define nCsPin GPIO_Pin_11
#define RsPin_RCC RCC_APB2Periph_GPIOC
#define RsPin_Port GPIOC
#define RsPin GPIO_Pin_8
#define nWrPin_RCC RCC_APB2Periph_GPIOC
#define nWrPin_Port GPIOC
#define nWrPin GPIO_Pin_9
#define nRdPin_RCC RCC_APB2Periph_GPIOC
#define nRdPin_Port GPIOC
#define nRdPin GPIO_Pin_10
#define nRstPin_RCC RCC_APB2Periph_GPIOC
#define nRstPin_Port GPIOC
#define nRstPin GPIO_Pin_12
#define LightPin_RCC RCC_APB2Periph_GPIOB
#define LightPin_Port GPIOB
#define LightPin GPIO_Pin_0
#define Set_nWrnCsPin_Port-》BSRR = nWrPin // GPIO_SetBits (nWrPin_Port, nWrPin)
#define Clr_nWrnCsPin_Port-》BRR = nWrPin // GPIO_ResetBits (nWrPin_Port, nWrPin)
#define Set_Cs nCsPin_Port-》BSRR = nCsPin // GPIO_SetBits (nCsPin_Port, nCsPin)
#define Clr_Cs nCsPin_Port-》BRR = nCsPin// GPIO_ResetBits (nCsPin_Port, nCsPin)
#define Set_Rs RsPin_Port-》BSRR = RsPin// GPIO_SetBits (RsPin_Port, RsPin)
#define Clr_Rs RsPin_Port-》BRR = RsPin // GPIO_ResetBits (RsPin_Port, RsPin)
#define Set_nRdnRdPin_Port-》BSRR = nRdPin// GPIO_SetBits (nRdPin_Port, nRdPin)
#define Clr_nRdnRdPin_Port-》BRR = nRdPin // GPIO_ResetBits (nRdPin_Port, nRdPin)
#define Set_RstnRstPin_Port-》BSRR = nRstPin// GPIO_SetBits (nRstPin_Port, nRstPin)
#define Clr_RstnRstPin_Port-》BRR = nRstPin // GPIO_ResetBits (nRstPin_Port, nRstPin)
#define Set_LightLightPin_Port-》BSRR = LightPin// GPIO_SetBits (LightPin_Port, LightPin)
#define Clr_LightLightPin_Port-》BRR = LightPin// GPIO_ResetBits (LightPin_Port, LightPin)
#define White 0xFFFF
#define Black 0x0000
#define Grey 0xF7DE
#define Blue 0x001F
#define Blue2 0x051F
#define Red 0xF800
#define Magenta 0xF81F
#define Green 0x07E0
#define Cyan 0x7FFF
#define Yellow 0xFFE0
void Lcd_Configuration(void); //初始化GPIO
void LCD_ili9320_Initializtion(void); //初始化ILI9320---uCGUI需要使用--1
void LCD_ili9320_Reset(void);
void LCD_ili9320_BackLight(u8 status); //背光
void LCD_ili9320_SetCursor(u16 x,u16 y); //设置坐标---uCGUI需要使用--2
void LCD_ili9320_SetWindows(u16 StartX,u16 StartY,u16 EndX,u16 EndY); //设置窗体
void LCD_ili9320_DrawPicture(u16 StartX,u16 StartY,u16 EndX,u16 EndY,u16 *pic);//画图片
void LCD_ili9320_SetPoint(u16 x,u16 y,u16 point);//画点---uCGUI需要使用--3
u16 LCD_ili9320_GetPoint(u16 x,u16 y); //读取点颜色---uCGUI需要使用--4
void LCD_ili9320_PutChar(u16 x,u16 y,u8 c,u16 charColor,u16 bkColor); //显示字符--需要字体头文件
void LCD_ili9320_Clear(u16 dat); //清屏
void LCD_ili9320_Delay(u32 nCount);
void LCD_ili9320_Test(void);
void LCD_ili9320_WriteData(u16 dat); //写数据
void LCD_ili9320_WriteIndex(u16 idx); //写地址
u16 LCD_ili9320_ReadData(void); //读数据
u16 LCD_ili9320_ReadRegister(u16 index); //读寄存器
void LCD_ili9320_WriteRegister(u16 index,u16 dat); //写寄存器
u16 LCD_ili9320_BGR2RGB(u16 c); //转换颜色格式
u16 LCD_ili9320_Color565(u32 RGB); // RGB颜色转为16位(565)
void LCD_ili9320_DrawHLine(uint16_t usX1 , uint16_t usY1 , uint16_t usX2 , uint16_t usColor);//水平线---uCGUI需要使用--5
void LCD_ili9320_DrawVLine(uint16_t usX1 , uint16_t usY1 , uint16_t usY2 , uint16_t usColor);//垂直线---uCGUI需要使用--6
void LCD_ili9320_FillRect(u16 x0, u16 y0, u16 x1, u16 y1,u16 color);//填充矩形---uCGUI需要使用--7
void LCD_ili9320_Line(u16 x0, u16 y0, u16 x1, u16 y1,u16 color); // 画任意直线线
void LCD_ili9320_Circle(u16 cx,u16 cy,u16 r,u16 color,u8 fill); // 画园
void LCD_ili9320_Rectangle(u16 x0, u16 y0, u16 x1, u16 y1,u16 color,u8 fill); // 画矩形--填充或者不填充
void LCD_ili9320_Square(u16 x0, u16 y0, u16 with, u16 color,u8 fill); // 画正方形--填充或者不填充
void LCD_ili9320_Text(u16 x, u16 y, u8 *str, u16 len,u16 Color, u16 bkColor); //简单测试--显示渐变色条
#endif
---------第三部分----------------ili9320.c------代码分析------
#include “ili9320.h”
#include “ili9320_font.h”
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB “ RCC_APB2Periph_GPIOC, ENABLE); //初始化数据引脚 ---DB0~~DB7是PB8~~PB15 DB8~~DB15是PC0~~PC7----------//
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 |GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(nCsPin_RCC, ENABLE); // 控制脚 CS ------PC11----//
GPIO_InitStructure.GPIO_Pin = nCsPin;
GPIO_Init(nCsPin_Port, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(RsPin_RCC, ENABLE); // 控制脚 RS -------PC8---//
GPIO_InitStructure.GPIO_Pin = RsPin;
GPIO_Init(RsPin_Port, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(nWrPin_RCC, ENABLE); // 控制脚 WR ----PC9--//
GPIO_InitStructure.GPIO_Pin = nWrPin;
GPIO_Init(nWrPin_Port, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(nRdPin_RCC, ENABLE); // 控制脚 RD ---PC10--//
GPIO_InitStructure.GPIO_Pin = nRdPin;
GPIO_Init(nRdPin_Port, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(nRstPin_RCC, ENABLE); // 控制脚 RST ---PC12--//
GPIO_InitStructure.GPIO_Pin = nRstPin;
GPIO_Init(nRstPin_Port, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(LightPin_RCC, ENABLE); // 控制脚背光 --PB00---//
GPIO_InitStructure.GPIO_Pin = LightPin;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(LightPin_Port, &GPIO_InitStructure);
void delayms(int count) // X1ms
int i,j;
for(i=0;i for(j=0;j《1000;j++);
void LCD_ili9320_Initializtion (void) //--功 能:初始化 ILI9320 控制器
volatile u16 i, j, k;
u32 DeviceCode = 0;
Lcd_Configuration();
LCD_ili9320_BackLight(0); //关背光
delayms(200);
Clr_Rst;
delayms(200);
LCD_ili9320_WriteData(0xffff);
Set_Rst; Set_nWr; Set_Cs; Set_Rs; Set_nRd; Set_Rst;
delayms(200);
LCD_ili9320_WriteRegister(0x0000,0x0001); // Start OCS
delayms(200);
DeviceCode = LCD_ili9320_ReadRegister(0x0000); // 读控制器型号 ILI9320
if(DeviceCode == 0x9320||0x9300)
LCD_ili9320_WriteRegister(0x00,0x0000);
LCD_ili9320_WriteRegister(0x01,0x0100);//驱动器输出控制
LCD_ili9320_WriteRegister(0x02,0x0700);//LCD驱动波形控制-反转
LCD_ili9320_WriteRegister(0x03,0x1030);//进入模式--F-
LCD_ili9320_WriteRegister(0x04,0x0000);//重新调整控制寄存器大小---缩放
LCD_ili9320_WriteRegister(0x08,0x0202);//Display Contral 2.(0x0207)
LCD_ili9320_WriteRegister(0x09,0x0000);//Display Contral 3.(0x0000)
LCD_ili9320_WriteRegister(0x0a,0x0000);//Frame信号输出间隔
LCD_ili9320_WriteRegister(0x0c,(1《《0)); //RGB显示接口控制1--16位
LCD_ili9320_WriteRegister(0x0d,0x0000);//帧标记的位置
LCD_ili9320_WriteRegister(0x0f,0x0000); //RGB显示接口控制1
delayms(5);
LCD_ili9320_WriteRegister(0x07,0x0101);//Display Contral.
delayms(5);
LCD_ili9320_WriteRegister(0x10,(1《《12)|(0《《8)|(1《《7)|(1《《6)|(0《《4));//Power Control 1.(0x16b0)
LCD_ili9320_WriteRegister(0x11,0x0007); //Power Control 2.(0x0001)
LCD_ili9320_WriteRegister(0x12,(1《《8)|(1《《4)|(0《《0));//Power Control 3.(0x0138)
LCD_ili9320_WriteRegister(0x13,0x0b00);//Power Control 4.
LCD_ili9320_WriteRegister(0x29,0x0000); //Power Control 7.
LCD_ili9320_WriteRegister(0x2b,(1《《14)|(1《《4));//帧速率和色彩控制---70
LCD_ili9320_WriteRegister(0x50,0);//Set X Star240*320
LCD_ili9320_WriteRegister(0x51,239); //水平GRAM终止位置Set X End.
LCD_ili9320_WriteRegister(0x52,0);//Set Y Star
LCD_ili9320_WriteRegister(0x53,319);//Set Y End.t.
LCD_ili9320_WriteRegister(0x60,0x2700);//门扫描控制器
LCD_ili9320_WriteRegister(0x61,0x0001);//Driver Output Control.
LCD_ili9320_WriteRegister(0x6a,0x0000); //Vertical Srcoll Control.
LCD_ili9320_WriteRegister(0x80,0x0000); //局部影像控制器1
LCD_ili9320_WriteRegister(0x81,0x0000); //局部影像控制器1--起始地址
LCD_ili9320_WriteRegister(0x82,0x0000); //局部影像控制器1--终止地址
LCD_ili9320_WriteRegister(0x83,0x0000); //Displsy Position? Partial Display 2.
LCD_ili9320_WriteRegister(0x84,0x0000); //RAM Address Start? Partial Display 2.
LCD_ili9320_WriteRegister(0x85,0x0000); //RAM Address End? Partial Display 2.
LCD_ili9320_WriteRegister(0x90,(0《《7)|(16《《0)); //平板接口控制器1(0x0013)
LCD_ili9320_WriteRegister(0x92,0x0000);//Panel Interface Contral 2.(0x0000)
LCD_ili9320_WriteRegister(0x93,0x0001); //Panel Interface Contral 3.
LCD_ili9320_WriteRegister(0x95,0x0110); //Frame Cycle Contral.(0x0110)
LCD_ili9320_WriteRegister(0x97,(0《《8)); //
LCD_ili9320_WriteRegister(0x98,0x0000); //Frame Cycle Contral.
LCD_ili9320_WriteRegister(0x07,0x0173);//(0x0173)
else if(DeviceCode==0x9325||DeviceCode==0x9328)//ILI9325
LCD_ili9320_WriteRegister(0x00e7,0x0010);
LCD_ili9320_WriteRegister(0x0000,0x0001); //开启内部时钟
LCD_ili9320_WriteRegister(0x0001,0x0100);
LCD_ili9320_WriteRegister(0x0002,0x0700); //电源开启
LCD_ili9320_WriteRegister(0x0003,(1《《12)|(3《《4)|(0《《3) ); //65K
LCD_ili9320_WriteRegister(0x0004,0x0000);
LCD_ili9320_WriteRegister(0x0008,0x0207);
LCD_ili9320_WriteRegister(0x0009,0x0000);
LCD_ili9320_WriteRegister(0x000a,0x0000);//display setting
LCD_ili9320_WriteRegister(0x000c,0x0001); //display setting
LCD_ili9320_WriteRegister(0x000d,0x0000);//0f3c
LCD_ili9320_WriteRegister(0x000f,0x0000);
//电源配置
LCD_ili9320_WriteRegister(0x0010,0x0000);
LCD_ili9320_WriteRegister(0x0011,0x0007);
LCD_ili9320_WriteRegister(0x0012,0x0000);
LCD_ili9320_WriteRegister(0x0013,0x0000);
delayms(5);
LCD_ili9320_WriteRegister(0x0010,0x1590);
LCD_ili9320_WriteRegister(0x0011,0x0227);
delayms(5);
LCD_ili9320_WriteRegister(0x0012,0x009c);
delayms(5);
LCD_ili9320_WriteRegister(0x0013,0x1900);
LCD_ili9320_WriteRegister(0x0029,0x0023);
LCD_ili9320_WriteRegister(0x002b,0x000e);
delayms(5);
LCD_ili9320_WriteRegister(0x0020,0x0000);
LCD_ili9320_WriteRegister(0x0021,0x013f);
delayms(5);
//伽马校正
LCD_ili9320_WriteRegister(0x0030,0x0007);
LCD_ili9320_WriteRegister(0x0031,0x0707);
LCD_ili9320_WriteRegister(0x0032,0x0006);
LCD_ili9320_WriteRegister(0x0035,0x0704);
LCD_ili9320_WriteRegister(0x0036,0x1f04);
LCD_ili9320_WriteRegister(0x0037,0x0004);
LCD_ili9320_WriteRegister(0x0038,0x0000);
LCD_ili9320_WriteRegister(0x0039,0x0706);
LCD_ili9320_WriteRegister(0x003c,0x0701);
LCD_ili9320_WriteRegister(0x003d,0x000f);
delayms(5);
LCD_ili9320_WriteRegister(0x0050,0x0000); //水平GRAM起始位置
LCD_ili9320_WriteRegister(0x0051,0x00ef);//水平GRAM终止位置
LCD_ili9320_WriteRegister(0x0052,0x0000); //垂直GRAM起始位置
LCD_ili9320_WriteRegister(0x0053,0x013f); //垂直GRAM终止位置
LCD_ili9320_WriteRegister(0x0060,0xa700);
LCD_ili9320_WriteRegister(0x0061,0x0001);
LCD_ili9320_WriteRegister(0x006a,0x0000);
LCD_ili9320_WriteRegister(0x0080,0x0000);
LCD_ili9320_WriteRegister(0x0081,0x0000);
LCD_ili9320_WriteRegister(0x0082,0x0000);
LCD_ili9320_WriteRegister(0x0083,0x0000);
LCD_ili9320_WriteRegister(0x0084,0x0000);
LCD_ili9320_WriteRegister(0x0085,0x0000);
LCD_ili9320_WriteRegister(0x0090,0x0010);
LCD_ili9320_WriteRegister(0x0092,0x0000);
LCD_ili9320_WriteRegister(0x0093,0x0003);
LCD_ili9320_WriteRegister(0x0095,0x0110);
LCD_ili9320_WriteRegister(0x0097,0x0000);
LCD_ili9320_WriteRegister(0x0098,0x0000);
//开启显示设置
LCD_ili9320_WriteRegister(0x0007,0x0133);
delayms(200);
LCD_ili9320_BackLight(1);//开背光
void LCD_ili9320_SetCursor(u16 x,u16 y) //--功 能:设置屏幕座标
LCD_ili9320_WriteRegister(0x0020,x);// 行
LCD_ili9320_WriteRegister(0x0021,y);// 列
* 功 能:设置窗口区域
* 入口参数:StartX 行起始座标
* StartY 列起始座标
* EndX 行结束座标
* EndY 列结束座标
LCD_ili9320_SetCursor(StartX,StartY);
LCD_ili9320_WriteRegister(0x0050, StartX);
LCD_ili9320_WriteRegister(0x0052, StartY);
LCD_ili9320_WriteRegister(0x0051, EndX);
LCD_ili9320_WriteRegister(0x0053, EndY);
* 功 能:将屏幕填充成指定的颜色,如清屏,则填充 0xffff
* 入口参数:dat 填充值
u32 i;
LCD_ili9320_SetCursor(0x0000, 0x0000);
Clr_Cs;
LCD_ili9320_WriteIndex(0x0022);
Set_Rs;
for(i = 0; i 《 768000; i++) //240*320=76800
LCD_ili9320_WriteData(dat);
Clr_nWr;
Set_nWr;
Set_Cs;
* 功 能:获取指定座标的颜色值
* 入口参数:x 行座标
* y 列座标
* 出口参数:当前座标颜色值
LCD_ili9320_SetCursor(x,y);
return (LCD_ili9320_BGR2RGB(LCD_ili9320_ReadRegister(0x0022)));
* 功 能:在指定座标画点
* 入口参数:x 行座标
* y 列座标
* point 点的颜色
if ((x》240)||(y》320))
return;
Clr_Cs;
Set_Rs;
LCD_ili9320_WriteData(point);
Clr_nWr;Set_nWr;
Set_Cs;
* 功 能:在指定座标范围显示一副图片
* 入口参数:StartX 行起始座标
* StartY 列起始座标
* EndX 行结束座标
* EndY 列结束座标
* pic 图片头指针
* 说 明:图片取模格式为水平扫描,16位颜色模式
u16 i;
LCD_ili9320_SetWindows(StartX,StartY,EndX,EndY);
Clr_Cs;
Set_Rs;
for (i=0;i《(EndX*EndY);i++)
LCD_ili9320_WriteData(*pic++);
Clr_nWr;Set_nWr;
Set_Cs;
* 功 能:在指定座标显示一个8x16点阵的ascii字符
* 入口参数:x 行座标
* y 列座标
* charColor 字符的颜色
* bkColor 字符背景颜色
* 说 明:显示范围限定为可显示的ascii码
u16 i=0;
u16 j=0;
u8 tmp_char=0;
for (i=0;i《16;i++)
if(c == ‘’)
continue;
tmp_char=ascii_8x16[((c-0x20)*16)+i];
for (j=0;j《8;j++)
if ( (tmp_char 》》 7-j) & 0x01 == 0x01)
LCD_ili9320_SetPoint(x+j,y+i,charColor);// 字符颜色
else
LCD_ili9320_SetPoint(x+j,y+i,bkColor);// 背景颜色
* 功 能:测试液晶屏
* 说 明:显示彩条,测试液晶屏是否正常工作
void LCD_ili9320_Test()
u8 R_data,G_data,B_data,i,j;
LCD_ili9320_SetCursor(0x00, 0x0000);
LCD_ili9320_WriteRegister(0x0050,0x00);//水平 GRAM起始位置
LCD_ili9320_WriteRegister(0x0051,239); //水平GRAM终止位置
LCD_ili9320_WriteRegister(0x0052,0); //垂直GRAM起始位置
LCD_ili9320_WriteRegister(0x0053,319); //垂直GRAM终止位置
Clr_Cs;
Set_Rs;
R_data=0;G_data=0;B_data=0;
for(j=0;j《50;j++)//红色渐强条
for(i=0;i《240;i++)
R_data=i/8;
LCD_ili9320_WriteData(R_data《《11|G_data《《5|B_data);
Clr_nWr;Set_nWr;
R_data=0x1f;G_data=0x3f;B_data=0x1f;
for(j=0;j《50;j++)
for(i=0;i《240;i++)
G_data=0x3f-(i/4);
B_data=0x1f-(i/8);
Clr_nWr;
Set_nWr;
for(j=0;j《50;j++)//绿色渐强条
for(i=0;i《240;i++)
G_data=i/4;
Clr_nWr;
Set_nWr;
for(j=0;j《50;j++)
for(i=0;i《240;i++)
R_data=0x1f-(i/8);
B_data=0x1f-(i/8);
Clr_nWr;
Set_nWr;
for(j=0;j《60;j++) //蓝色渐强条
for(i=0;i《240;i++)
B_data=i/8;
Clr_nWr;
Set_nWr;
B_data=0;
for(j=0;j《60;j++)
for(i=0;i《240;i++)
G_data=0x3f-(i/4);
R_data=0x1f-(i/8);
Clr_nWr;
Set_nWr;
Set_Cs;
* 功 能:RRRRRGGGGGGBBBBB 改为 BBBBBGGGGGGRRRRR 格式
* 入口参数:c BRG 颜色值
* 出口参数:RGB 颜色值
u16 r, g, b, rgb;
b = (c》》0) & 0x1f;
g = (c》》5) & 0x3f;
r = (c》》11) & 0x1f;
rgb = (b《《11) + (g《《5) + (r《《0);
return( rgb );
* 功 能:写 ili9320 控制器寄存器地址
* 入口参数:idx 寄存器地址
Clr_Rs;
Set_nRd;
LCD_ili9320_WriteData(idx);
Clr_nWr;
Set_nWr;
Set_Rs;
* 功 能:写 ili9320 寄存器数据
* 入口参数:dat 寄存器数据
* 说 明:向控制器指定地址写入数据,调用前需先写寄存器地址,内部函数
void LCD_ili9320_WriteData(u16 data)
GPIOB-》ODR = (GPIOB-》ODR & 0x00ff) | (((data 《《 8) 》》 8) 《《 8);// 低8位数据写入CPIOB高8位
GPIOC-》ODR = (GPIOC-》ODR & 0xff00) | (((data 》》 8) 《《 8) 》》 8);// 高8位数据写入CPIOC低8位
* 功 能:读取控制器数据
* 出口参数:返回读取到的数据
// ** nCS ----\__________________________________________/------- **
// ** RS ------\____________/----------------------------------- **
// ** nRD -------------------------\_____/--------------------- **
// ** nWR --------\_______/-------------------------------------- **
// ** DB[0:15] ---------[index]----------[data]----------------------- **
u32 tmp;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 |GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入模式
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 |GPIO_Pin_6 | GPIO_Pin_7;
tmp = ((GPIOB-》IDR & 0xff00) 》》 8); //PB的高8位为数据的低8位
tmp |= ((GPIOC-》IDR & 0x00ff) 《《 8);//PC的低8位为数据的高8位
//再次将GPIO恢复为输出模式
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 |GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
return tmp;
* 功 能:读取指定地址寄存器的值
* 入口参数:index 寄存器地址
* 出口参数:寄存器值
Clr_Cs;
LCD_ili9320_WriteIndex(index);
Clr_nRd;
index = LCD_ili9320_ReadData();
Set_nRd;
Set_Cs;
return index;
* 功 能:写指定地址寄存器的值
* 入口参数:index 寄存器地址
* :dat 寄存器值
** nRD ------------------------------------------------------- **
** nWR --------\_______/--------\_____/----------------------- **
Clr_Cs;
Clr_Rs;
Set_nRd;
LCD_ili9320_WriteData(index);//地址
Clr_nWr;
Set_nWr;
Set_Rs;
LCD_ili9320_WriteData(dat); //值
Clr_nWr;
Set_nWr;
Set_Cs;
* 功 能:复位 ili9320 控制器
* 说 明:复位控制器,内部函数
void LCD_ili9320_Reset()
* 功 能:开、关液晶背光
* 入口参数:status 1:背光开 0:背光关
if ( status 》= 1 )
Clr_Light; //低电平开背光
else
评论(0)
发评论
jinniuxing 2018-11-28
0 回复 举报
大拇指! 收起回复
