如何在ARM7中进行A/D转换
控制/MCU
1828人已加入
主程序:/******************************************************************************/
/* This file is part of the uVision/ARM development tools */
/* Copyright KEIL ELEKTRONIK GmbH 2002-2004 */
/* BLINKY.C: LED Flasher */
#include /* LPC21xx definitions */
extern void init_serial (void); /* Initialize Serial Interface */
extern int putchar (int ch); /* Write character to Serial Port */
extern int getchar (void); /* Read character from Serial Port */
void puthex (int hex) { /* Write Hex Digit to Serial Port */
if (hex 》 9) putchar(‘A’ + (hex - 10));
else putchar(‘0’ + hex);
void putstr (char *p) { /* Write string */
while (*p) {
putchar (*p++);
void delay (void) { /* Delay function */
unsigned int cnt;
unsigned int val;
ADCR |= 0x01000000; /* Start A/D Conversion */
do {
val = ADDR; /* Read A/D Data Register */
} while ((val & 0x80000000) == 0); /* Wait for end of A/D Conversion */
ADCR &= ~0x01000000; /* Stop A/D Conversion */
val = (val 》》 6) & 0x03FF; /* Extract AIN0 Value */
putstr (“\nAIN0 Result = 0x”); /* Output A/D Conversion Result */
puthex((val 》》 8) & 0x0F); /* Write 1. Hex Digit */
puthex((val 》》 4) & 0x0F); /* Write 2. Hex Digit */
puthex (val & 0x0F); /* Write 3. Hex Digit */
val = (val 》》 2) 《《 12; /* Adjust Delay Value */
for (cnt = 0; cnt 《 val; cnt++); /* Delay */
int main (void) {
unsigned int n;
IODIR1 = 0x00FF0000; /* P1.16..23 defined as Outputs */
ADCR = 0x002E0401; /* Setup A/D: 10-bit AIN0 @ 3MHz */
init_serial(); /* Initialize Serial Interface */
IOSET1=0x00ff0000;
while (1) { /* Loop forever */
for (n = 0x00010000; n 《= 0x00800000; n 《《= 1) {
/* Blink LED 0, 1, 2, 3, 4, 5, 6, 7 */
IOCLR1 = n; /* Turn on LED */
delay(); /* Delay */
IOSET1 = 0x00FF0000; /* Turn off LEDs */
串口程序:
/* SERIAL.C: Low Level Serial Routines */
#define CR 0x0D
void init_serial (void) { /* Initialize Serial Interface */
PINSEL0 = 0x00050000; /* Enable RxD1 and TxD1 */
U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
U1DLL = 97; /* 9600 Baud Rate @ 15MHz VPB Clock */
U1LCR = 0x03; /* DLAB = 0 */
int putchar (int ch) { /* Write character to Serial Port */
if (ch == ‘\n’) {
while (!(U1LSR & 0x20));
U1THR = CR; /* output CR */
return (U1THR = ch);
int getchar (void) { /* Read character from Serial Port */
while (!(U1LSR & 0x01));
return (U1RBR);
