DRV835x用于三相马达的三相智能栅极驱动器
1.2w人已加入
  TI公司的DRV835x系列是用于三相马达的9-100V三相智能栅极驱动器,集成了用于高边和低边的三个独立半桥栅极驱动器,电荷泵和线性稳压器,以及可选择的三个电流分流放大器和350mA降压稳压器,工作电压6-95V,输出电流2.5V-75V/350mA.主要用在3相无刷DC(BLDC)马达模块,风扇,鼓风机和泵,电动自行车,电动滑板车和电动汽车,无人机,机器人遥控玩具,工厂自动化和纺织机械。本文介绍了DRV835x系列主要特性和框图,栅极驱动器框图,应用电路以及评估板DRV8353RS-EVM主要特性和电路图,材料清单与PCB设计图。
  The DRV835x family of devices are integrated 100-V gate drivers for three-phase motor drive applications.
  These devices decrease system component count, cost, and complexity by integrating three independent halfbridgegate drivers, charge pump and linear regulator for the high-side and low-side gate driver supply voltages,optional triple current shunt amplifiers, and an optional 350-mA buck regulator. A standard serial peripheralinterface (SPI) provides a simple method for configuring the various device settings and reading fault diagnosticinformation through an external controller. Alternatively, a hardware interface (H/W) option allows for configuringthe most commonly used settings through fixed external resistors.
  The gate drivers support external N-channel high-side and low-side power MOSFETs and can drive up to 1-Asource, 2-A sink peak currents with a 25-mA average output current. The high-side gate drive supply voltage isgenerated using a doubler charge-pump architecture that regulates the VCP output to VVDRAIN + 10.5-V. The lowsidegate drive supply voltage is generated using a linear regulator from the VM power supply that regulates theVGLS output to 14.5-V. The VGLS supply is further regulated to 11-V on the GLx low-side gate driver outputs. Asmart gate-drive architecture provides the ability to dynamically adjust the output gate-drive current strengthallowing for the gate driver to control the power MOSFET VDS switching speed. This allows for the removal ofexternal gate drive resistors and diodes reducing BOM component count, cost, and PCB area. The architecturealso uses an internal state machine to protect against gate-drive short-circuit events, control the half-bridge deadtime, and protect against dV/dt parasitic turnon of the external power MOSFET.
  The gate drivers can operate in either a single or dual supply architecture. In the single supply architecture, VMcan be tied to VDRAIN and is regulated to the correct supply voltages internally. In the dual supply architecture,VM can be connected to a lower voltage supply from a more efficient switching regulator to improve the deviceefficiency. VDRAIN stays connected to the external MOSFETs to set the correct charge pump and overcurrentmonitor reference.
  The DRV8353 and DRV8353R devices integrate three, bidirectional current-shunt amplifiers for monitoring thecurrent level through each of the external half-bridges using a low-side shunt resistor. The gain setting of theshunt amplifier can be adjusted through the SPI or hardware interface with the SPI providing additional flexibilityto adjust the output bias point.
  The DRV8350R and DRV8353R devices integrate a 350-mA buck regulator that can be used to power anexternal controller or other logic circuits. The buck regulator is implemented as a separate internal die that canuse either the same or a different power supply from the gate driver.
  In addition to the high level of device integration, the DRV835x family of devices provides a wide range ofintegrated protection features. These features include power-supply undervoltage lockout (UVLO), gate driveundervoltage lockout (GDUV), VDS overcurrent monitoring (OCP), gate-driver short-circuit detection (GDF), andovertemperature shutdown (OTW/OTSD)。 Fault events are indicated by the nFAULT pin with detailed informationavailable in the SPI registers on the SPI device version.
  The DRV835x family of devices are available in 0.5-mm pin pitch, QFN surface-mount packages. The QFN sizesare 5 × 5 mm for the 32-pin package, 6 × 6 mm for the 40-pin package, and 7 × 7 mm for the 48-pin package.
  DRV8353RS主要特性:
  1• 9 to 100-V, Triple Half-Bridge Gate Driver
  – Optional Integrated Buck Regulator
  – Optional Triple Low-Side Current ShuntAmplifiers
  • Smart Gate Drive Architecture
  – Adjustable Slew Rate Control For EMIPerformance
  – VGS Handshake and Minimum Dead-TimeInsertion to Prevent Shoot-Through
  – 50-mA to 1-A Peak Source Current
  – 100-mA to 2-A Peak Sink Current
  – dV/dt Mitigation Through Strong Pulldown
  • Integrated Gate Driver Power Supplies
  – High-Side Doubler Charge Pump For 100%PWM Duty Cycle Control
  – Low-Side Linear Regulator
  • Integrated LM5008A Buck Regulator
  – 6 to 95-V Operating Voltage Range
  – 2.5 to 75-V, 350-mA Output Capability
  • Integrated Triple Current Shunt Amplifiers
  – Adjustable Gain (5, 10, 20, 40 V/V)
  – Bidirectional or Unidirectional Support
  • 6x, 3x, 1x, and Independent PWM Modes
  – Supports 120° Sensored Operation
  • SPI or Hardware Interface Available
  • Low-Power Sleep Mode (20 μA at VVM = 48-V)
  • Integrated Protection Features
  – VM Undervoltage Lockout (UVLO)
  – Gate Drive Supply Undervoltage (GDUV)
  – MOSFET VDS Overcurrent Protection (OCP)
  – MOSFET Shoot-Through Prevention
  – Gate Driver Fault (GDF)
  – Thermal Warning and Shutdown (OTW/OTSD)
  – Fault Condition Indicator (nFAULT)
  DRV8353RS应用:
  • 3-Phase Brushless-DC (BLDC) Motor Modules
  • Fans, Blowers, and Pumps
  • E-Bikes, E-Scooters, and E-Mobility
  • Power and Garden Tools, Lawn Mowers
  • Drones, Robotics, and RC Toys
  • Factory Automation and Textile Machines
放大器
  图1.DRV8350H框图
放大器
  图2.DRV8350S框图
放大器
  图3.DRV8350RH框图
放大器
  图4.DRV8350RS框图
放大器
  图5.DRV8353H框图
放大器
  图6.DRV8353S框图
放大器
  图7.DRV8353RH框图
放大器
  图8.DRV8353RS框图
放大器
  图9.栅极驱动器框图
放大器
  图10.DRV8353系列基本应用电路图(1)
放大器
  图11.DRV8353系列基本应用电路图(2)
  评估板DRV8353RS-EVM
  The DRV8353RS-EVM is a 15A, 3-phase brushless DC drive stage based on the DRV8353RS gate driver and CSD19532Q5B NexFET™ MOSFETs.
  The module has individual DC bus and phase voltage sense as well as individual low-side current shunt amplifiers, making this evaluation module ideal for sensorless BLDC algorithms. The module supplies MCU 3.3V power with an integrated 0.35A step down buck regulator. The drive stage has IDRIVE configuration, along with a fault pin and protection for short circuit, thermal, shoot-through, and under voltage conditions through configurable SPI.
  评估板DRV8353RS-EVM主要特性:
  9- to 95-V operation
  15 A continuous/20 A peak H-bridge output current
  Internal buck regulator
  Three individual, internal low-side current shunt amplifiers
  INSTASPIN FOC BLDC firmware available
  图12.评估板DRV8353RS-EVM外形图
放大器
  图13.评估板DRV8353RS-EVM框图
  图14.评估板DRV8353RS-EVM硬件连接图(1)
  图15.评估板DRV8353RS-EVM硬件连接图(2)
放大器
  图16.评估板DRV8353Rx-EVM电路图(1):MD016A
放大器
  图17.评估板DRV8353Rx-EVM MD016A PCB设计图(1)
放大器
  图18.评估板DRV8353Rx-EVM MD016A PCB设计图(2)
放大器
  图19.评估板DRV8353Rx-EVM MD016A PCB设计图(3)
放大器
  图20.评估板DRV8353Rx-EVM MD016A PCB设计图(4)
放大器
  图21.评估板DRV8353Rx-EVM MD016A PCB设计图(5)
放大器
  图22.评估板DRV8353Rx-EVM MD016A PCB设计图(6)
放大器
  图23.评估板DRV8353Rx-EVM MD016A PCB设计图(7)
放大器
  图24.评估板DRV8353Rx-EVM MD016A PCB设计图(8)
放大器
  图25.评估板DRV8353Rx-EVM MD016A PCB设计图(9)
放大器
  图26.评估板DRV8353Rx-EVM MD016A PCB设计图(10)
放大器
  图27.评估板DRV8353Rx-EVM MD016A(001)装配图
放大器
  图28.评估板DRV8353Rx-EVM MD016A(002)装配图
放大器
  图29.评估板DRV8353Rx-EVM MD017A电路图(1)
放大器
  图30.评估板DRV8353Rx-EVM MD017A电路图(2)
放大器
  图31.评估板DRV8353Rx-EVM MD017A PCB设计图(1)
放大器
  图32.评估板DRV8353Rx-EVM MD017A PCB设计图(2)
放大器
  图33.评估板DRV8353Rx-EVM MD017A PCB设计图(3)
放大器
  图34.评估板DRV8353Rx-EVM MD017A PCB设计图(4)
  放大器
  图35.评估板DRV8353Rx-EVM MD017A PCB设计图(5)
放大器
  图36.评估板DRV8353Rx-EVM MD017A PCB设计图(6)
放大器
  图37.评估板DRV8353Rx-EVM MD017A PCB设计图(7)
放大器
  图38.评估板DRV8353Rx-EVM MD017A PCB设计图(8)
放大器
  图39.评估板DRV8353Rx-EVM MD017A PCB装配图(1)
放大器
  图39.评估板DRV8353Rx-EVM MD017A PCB装配图(2)
  评估板DRV8353Rx-EVM材料清单见:
  MCU036A(001)_BOM.xls
  MD016A(001)_BOM.xls
  MD016A(002)_BOM.xls
  slvc742a.zip
  详情请见:
  和
  drv8353.pdf
