51单片机对八位数字秒表的设计
控制/MCU
1813人已加入
//基于51单片机的八位数字秒表
//开发语言:C51
//所选芯片:AT89S51
#include
#include
#define DIG_NONE 0xff;
#define DIG_1 0x7f
#define DIG_2 0xbf
#define DIG_3 0xdf
#define DIG_4 0xef
#define DIG_5 0xf7
#define DIG_6 0xfb
#define DIG_7 0xfd
#define DIG_8 0xfe
#define LINE 0xf7//根据共阴共阳以及接法要调整
typedef unsigned char Byte;
typedef bit bool;
sbit START = P3^0;
sbit RESET = P3^1;
Byte data dis_digit;
Byte data min;
Byte data sec;
Byte data msec;
bool data isStarted;
Byte data dis_index;
Byte data dis_buff[8];
Byte data dis_num[8];
//根据共阴共阳以及数码管接法这里要的表要调整
Byte code number[11]={ 0x28, 0x7E, 0xA2, 0x62, 0x74, 0x61, 0x21, 0x7A, 0x20, 0x60,0xff};//0,1,2,3,4,5,6,7,8,9,关显示,数码管码表
Byte dis_buff[8]; // 显示缓冲区
Byte dis_num[8]; // 秒计数值, BCD码
Byte dis_index;
bit Scan_Key();
void Proc_Key();
void Delayms(Byte ms);
void Update_buff();
void Msec_Increment();
void Reset(void);
bool Get_Key(bit key);//有效为1
void MCU_Init(void);
void Timer0_Overflow();
void Timer1_Overflow();
//sbit K1 = P3^2;
void Msec_Increment()//中断里面的设置
msec += 1;
if (msec == 100)
msec = 0;
sec += 1;
if (sec == 60)
sec = 0;
min += 1;
if (min == 60)
min = 0;
void MCU_Init()
P1 = 0xff;
P2 = 0xff;
TMOD = 0x12;
TH1 = 0xd8;
TL1 = 0xf0;
TH0 = 0x9c;
TL0 = 0x00;
////定时器1选用方式1工作,扫描周期0.01s=10ms,定时器0选用工作方式3工作,自动装入,扫描周期0.1ms=100μs
Reset();
min = 0;
sec = 0;
msec = 0;
dis_digit = 0x7f; // 初始显示P20口数码管
dis_index = 0;
IE = 0x8a; // 使能timer0, timer1中断
TR0 = 1;
TR1 = 0;
isStarted = 0;
void Reset()
min = 0;
sec = 0;
msec = 0;
Update_buff();
void Update_buff()
dis_num[0] = min / 10;
dis_num[1] = min % 10;
dis_num[3] = sec / 10;
dis_num[4] = sec % 10;
dis_num[6] = msec / 10;
dis_num[7] = msec % 10;
//这里根据数码管的顺序进行调整
dis_buff[0] = number[dis_num[7]];
dis_buff[1] = number[dis_num[6]];
dis_buff[2] = LINE;
dis_buff[3] = number[dis_num[4]];
dis_buff[4] = number[dis_num[3]];
dis_buff[5] = LINE;
dis_buff[6] = number[dis_num[1]];
dis_buff[7] = number[dis_num[0]];
bool Get_Key(bit key)//有效为1,这里按下为低电平
if (key == 0)
return 1;
else
return 0;
void timer0() interrupt 1
P2 = 0xff; // 先关闭所有数码管
P1 = dis_buff[dis_index]; // 显示代码传送到P0口
P2 = dis_digit; //
dis_digit = _cror_(dis_digit,1); // 位选通值右移(P20《-P27), 下次中断时选通下一位数码管
//_cror_()为字符循环右移函数
dis_index++; //
dis_index &= 0x07; // 8个数码管全部扫描完一遍之后,再回到第一个开始下一次扫描
void timer1() interrupt 3
TH1 = 0xd8;
TL1 = 0xf0;
Msec_Increment();
Update_buff();
void delayms(unsigned char ms)
// 延时子程序
unsigned char i;
while(ms--)
for(i = 0; i 《 120; i++);
void main(void)
bool startkey, resetkey;
MCU_Init();
while(1)
startkey = Get_Key(START);
resetkey = Get_Key(RESET);
if (startkey == 1)
Delayms(50);
if (startkey == 1)
isStarted = !isStarted;
TR1 = !TR1;
if (resetkey == 1 && isStarted == 0)
Delayms(20);
Reset();
