F0424600-4200MHz SiGe大功率宽带RF放大器
功率器件
110人已加入
  IDT公司的F0424是600MHz-4200MHz SiGe大功率宽带RF放大器,组合低噪音(NF)和高线性性能,是器件可用在发送器和蔼接收器中。器件可工作单电压5V或3.3V,ICC正常电流70A,2600MHz时的增益17.3dB,OIP3为+40dBm和2.3dB噪音。主要用在4G TDD和FDD基站,2G/3G基站,中继器和DAS,点对点基础设备,公共安全设备和军用手持设备。本文介绍了F0424主要特性,框图,F0424评估板电路图和材料清单。
  The F0424 is a 600MHz to 4200MHz SiGe High-Gain Broadband RF Amplifier. The combination of low noise figure (NF) and high linearity performance allows the device to be used in both receiver and transmitter applications.
  The F0424 is designed to operate with a single 5V or 3.3V power supply using a nominal 70mA of ICC. With a supply voltage of 5V, the F0424 provides 17.3dB gain with +40dBm OIP3 and 2.3dB noise figure at 2600MHz.
  This device is packaged in a 2mm x 2mm, 8-pin Thin DFN with 50Ω single-ended RF input and output impedances for ease of integration into the signal-path.
  F0424主要特性:
  § RF Range: 600MHz to 4200MHz
  § Noise Figure = 2.3dB @ 2600MHz
  § Gain = 17.3dB @ 2600MHz
  § OIP3 = +40dBm @ 2600MHz
  § Output P1dB = +21dBm @ 2600MHz
  § Near-Constant Gain versus Temperature
  § 3.3V or 5V Power Supply
  § 350mW Typical DC Power @ 5V Supply
  § 50Ω Input and Output Impedances
  § Operating Temperature (TEP) Range: -40℃ to +105℃
  § 2mm x 2mm, 8-DFN Package
  F0424具有竞争优势:
  F0424典型应用:
放大器
放大器
  图1. F0424框图
  图2. F0424评估板外形图(正面)
  图3. F0424评估板外形图(背面)
放大器
  图4. F0424评估板电路图
  F0424评估板材料清单:
放大器
  详情请见:
  https://www.idt.com/document/dst/f0424-datasheet
  IDT_F0424-Datasheet-RevO_DST_20180505.pdf
