STM32如何配置ADC?
控制/MCU
1821人已加入
1、 系统时钟定义:
RCC_Configuration();
包涵:
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMAx, ENABLE); // Enable DMA clock
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADCx , ENABLE); // Enable ADC1 and GPIOC clock
2、 中断源配置:
NVIC_Configuration();
举例:
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //设置串口1中断
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //子优先级为0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能
NVIC_Init(&NVIC_InitStructure);
注:如需要外部中断启动ADC,则需要配置,自动转换不需要配置
3、 端口初始化:
GPIO_Configuration();
端口初始化不但包括要用IO,也包括ADC的IO口初始化;
RCC_APB1PeriphClockCmd(XX, ENABLE); //使能APB1低速总线
RCC_APB2PeriphClockCmd(XX,ENABLE); //使能APB2高速总线
普通IO配置:
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_x; //定义GPIOX中的x脚,输出需要规定速度
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOX, &GPIO_InitStructure);
注:模式包涵:
GPIO_Mode_AIN、GPIO_Mode_IN_FLOATING、GPIO_Mode_IPD、GPIO_Mode_IPU、GPIO_Mode_Out_OD、GPIO_Mode_Out_PP、GPIO_Mode_AF_OD、GPIO_Mode_AF_PP
ADC的IO配置:
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOC, &GPIO_InitStructure); //设置AD模拟输入端口为输入一共2路AD规则通道
4、ADC初始化:
ADC_Configuration();
如果使用多路采集的话,在ADC初始化中需要进行DMA的初始化。
a、DMA初始化例子如下所示:
/* DMA channel1 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel1); //使能DMA
DMA_InitStructure.DMA_PeripheralBaseAddr =ADC1_DR_Address; //DMA通道1的地址
//需要定义ADC1_DR_Address,范围0x4001 2400 - 0x4001 27FF
如:#define ADC1_DR_Address ((u32)0x4001244C)
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;//DMA传送地址
//需要定义ADC_ConvertedValue,
如volatile unsigned short int ADC_ConvertedValue[2];
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //传送方向
DMA_InitStructure.DMA_BufferSize = 2; //传送内存大小,2个16位
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//当前外设寄存器地址不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //传送内存地址递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //ADC1转换的数据是16位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
//传送的目的地址是16位宽度
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/*允许DMA1通道1传输结束中断*/
//DMA_ITConfig(DMA1_Channel1,DMA_IT_TC, ENABLE);
//使能DMA通道1
DMA_Cmd(DMA1_Channel1, ENABLE);
b、ADC初始化如下:
//ADC配置
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC1工作在独立模式
ADC_InitStructure.ADC_ScanConvMode = ENABLE; //模数转换工作在扫描模式(多通道)还是单次(单通道)模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //ADC转换工作在自动连续模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//转换由软件而不是外部触发启动
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = 2;//规定了顺序进行规则转换的ADC通道的数目。这个数目的取值范围是1到16
ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 regular channels configuration [规则模式通道配置]*/
//ADC1规则通道配置
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5); //通道10采样时间55.5周期
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5); //通道11采样时间55.5周期
//使能ADC1 DMA
ADC_DMACmd(ADC1, ENABLE);
//使能ADC1
ADC_Cmd(ADC1, ENABLE);
//初始化ADC1校准寄存器
ADC_ResetCalibration(ADC1);
//检测ADC1校准寄存器初始化是否完成
while(ADC_GetResetCalibrationStatus(ADC1));
//开始校准ADC1
ADC_StartCalibration(ADC1);
//检测是否完成校准
while(ADC_GetCalibrationStatus(ADC1));
通过 ADC_SoftwareStartConvCmd(ADC1, ENABLE);进行软启动
如上初始化所示,ADC转化结果将存入ADC_ConvertedValue数组中去,到时只需读取其值即可。
  • 相关推荐
