E8363C-05 PNA Series Network A
消耗积分:0 | 格式:rar | 大小:163 | 2010-08-21
分享资料个
Situation:
It is possible that the center of the X-frame of the HDD tray is slightly bowed which will cause the
hard drive to warp when secured with screws.  If warped, a head crash may occur that can destroy the
drive. Only SATA (Serial ATA) drives are affected - PATA drives don’t have this issue.  SATA
drives are identifiable by a flat, X-shaped Mylar insulator between the drive and the tray - see the
photo. Also affected are trays used for replacement/swapping purposes on the E836xA/B and N5230A
models. This issue does not affect the PNA-X series.
评论(0)
发评论
下载排行榜
