TFP510,pdf(TI PanelBus DVI Tra
消耗积分:0 | 格式:rar | 大小:383 | 2010-08-24
李敏
分享资料个
The TFP510 is a Texas Instruments PanelBus flat panel display product, part of a comprehensive family of end-to-end DVI 1.0 compliant solutions, targeted at the PC and consumer electronics industry.
The TFP510 provides a universal interface to allow a glueless connection to most commonly available graphics controllers. Some of the advantages of this universal interface include selectable bus widths, adjustable signal levels, and differential and single-ended clocking. The adjustable 1.1-V to 1.8-V digital interface provides a low-EMI, high-speed bus that connects seamlessly with 12-bit or 24-bit interfaces. The DVI interface supports flat panel display resolutions up to UXGA at 165 MHz in 24-bit true color pixel format.
评论(0)
发评论
下载排行榜
