AS5304/AS5306 pdf datasheet (I
消耗积分:0 | 格式:rar | 大小:555 | 2008-09-19
訾存贵
分享资料个
The AS5306 is a single-chip IC with integrated Hall elements for measuring linear or rotary motion using multi-pole magnetic strips or rings. This allows the usage of the AS5306 in applications where the Sensor IC cannot be mounted at the end of a rotating device (e.g. at hollow shafts). Instead, the AS5306 is mounted off axis underneath a multi-pole magnetized ring or strip and provides a quadrature incremental output with 40 pulses per pole period at speeds of up to 12 meters/sec. A single index pulse is generated once for every pole pair at the index output.
The magnet pole pair length is 2.4mm (1.2mm north pole / 1.2mm south pole).
The AS5306A device provides push pull configurations for the A, B and index outputs. The AS5306B device provides open drain configurations for the A, B and index outputs.
The AS5306 is available in a small 20-pin TSSOP package and specified for an operating ambient temperature of -40° to 125°C.
The AS5304/AS5306 is ideal for high speed linear motion and off axis rotation measurement in applications such as
  • Electrical motors
  • X-Y-stages
  • Rotation knobs
  • Industrial drives
评论(0)
发评论
下载排行榜
