详细介绍NXP的 i.MX 8M应用处理器开发方案、电路图及BOOM
汽车电子
2300人已加入
NXP公司的i.MX 8M Dual/8M QuadLite/8M Quad应用处理器是基于四核Arm®Cortex®-A53,工作速率高达1.3GHz,可连接音频/视频设备,扫描/图像设备,以及需要高性能低功耗处理器的各种设备.其DRAM控制器支持32位/16位LPDDR4,DDR4和DDR3L存储器,以及连接外设如WLAN,蓝牙,GPS,显示和照相机传感器.应用处理器的硬件加速可使视频播放高达4K,驱动视频输出高达60fps,主要可用在汽车电子和工业控制.本文介绍了i.MX 8M处理器主要特性,应用处理器框图以及i.MX 8X多传感器实现板(MEK)主要特性和电路图.
The i.MX 8M Dual/8M QuadLite/8M Quad processorsrepresent NXP’s latest market of connected streamingaudio/video devices, scanning/imaging devices, andvarious devices requiring high-performance, low-powerprocessors.
The i.MX 8M Dual/8M QuadLite/8M Quad processorsfeature advanced implementation of a quad Arm®Cortex®-A53 core, which operates at speeds of up to1.3 GHz. A general purpose Cortex®-M4 core processoris for low-power processing. The DRAM controller supports 32-bit/16-bit LPDDR4, DDR4, and DDR3Lmemory. There are a number of other interfaces forconnecting peripherals, such as WLAN, Bluetooth, GPS,displays, and camera sensors. The i.MX 8M Quad andi.MX 8M Dual processors have hardware accelerationfor video playback up to 4K, and can drive the videooutputs up to 60 fps. Although the i.MX 8M QuadLiteprocessor does not have hardware acceleration for video decode, it allows for video playback with softwaredecoders if needed.
i.MX 8M处理器主要特性:
NXP
NXP
NXP
NXP
图1.i.MX 8MDual/8M QuadLite/8MQuad处理器框图
i.MX 8X多传感器实现板(MEK)
NXP’s development tools and ecosystem for safety-certifiable and efficient performance i.MX 8X application processors are ideal in automotive and industrial applications
图2.i.MX 8X多传感器实现板(MEK)外形图
The i.MX 8X multisensory enablement kit (MEK) from NXP provides a platform for evaluation and development of the Arm® Cortex®-A35+ Cortex-M4F based i.MX 8QuadXPlus, i.MX 8DualXPlus, and i.MX 8DualX applications processors as well as the NXP PF8100 power management integrated circuit (PMIC) solution and sensors. The i.MX 8x processor family from NXP is ideal for safety-certifiable and efficient performance requirements thanks to its high-level integration that supports graphics, video, image processing, audio, and voice functions.
The MEK is complete with highly optimized drivers and software. Users can utilize the stand-alone MCIMX8QXP-CPU to get a jump start on i.MX 8X development. The optional MCIMX8-8X-BB baseboard includes the IMX-AUD-IO board and can be used for additional connectivity,audio, and expansion options.
i.MX 8X多传感器实现板(MEK)主要特性:
CPU board:
Processor:
NXP i.MX 8QuadXPlus
4x Arm Cortex-A35 at up to 1.2 GHz
512 MB L2 cache
Arm Cortex-M4 at 266 MHz
Debug:
JTAG connector
Serial to USB connector
Display/camera connectors:
2x MIPI/LVDS connectors
Camera MIPI-CSI
Audio:
Audio codec
Microphone and headphone jacks
Connectivity:
1x full-size SD/MMC card slot
10/100/1000 Ethernet port
1x USB 3.0 Type C
Power management:
NXP MMPF8100 PMIC
Memory:
3 GB LPDDR4 memory, x32
32 GB eMMC 5.0
64 MB octal SPI Flash
Additional features:
NXP 3-axis accelerometer and eCompass (not populated)
NXP gyroscope
NXP light sensor
NSP pressure sensor
RGB LED
Power supply
OS support:
Linux®
Android
FreeRTOS
Expansion connector:
M.2 connector (PCIe, USB, UART, I2C, and I2S)
Connectivity:
1x I2C auxiliary connector
1x tamper head
1x parallel CSI connector
1x UART, 2x CAN
1x USB OTG connector
1x audio-in connector
1x audio-out connector
1x 10/100/1000 Ethernet connector
Muxed with audio port
Arduino connector/mikroBus™ interface
i.MX 8X多传感器实现板(MEK)应用:
Automotive
Industrial vehicles
Advanced industrial human machine interface (HMI) and controls
Robotics
Building controls
Healthcare
Networking
Mobile payments
General purpose HMI solutions
NXP
图3.i.MX 8X多传感器实现板(MEK)电路图(1)
NXP
图4.i.MX 8X多传感器实现板(MEK)电路图(2)
NXP
图5.i.MX 8X多传感器实现板(MEK)电路图(3)
NXP
图6.i.MX 8X多传感器实现板(MEK)电路图(4)
NXP
图7.i.MX 8X多传感器实现板(MEK)电路图(5)
NXP
图8.i.MX 8X多传感器实现板(MEK)电路图(6)
NXP
图9.i.MX 8X多传感器实现板(MEK)电路图(7)
NXP
图10.i.MX 8X多传感器实现板(MEK)电路图(8)
NXP
图11.i.MX 8X多传感器实现板(MEK)电路图(9)
NXP
图12.i.MX 8X多传感器实现板(MEK)电路图(10)
NXP
图13.i.MX 8X多传感器实现板(MEK)电路图(11)
NXP
图14.i.MX 8X多传感器实现板(MEK)电路图(12)
NXP
图15.i.MX 8X多传感器实现板(MEK)电路图(13)
NXP
图16.i.MX 8X多传感器实现板(MEK)电路图(14)
NXP
图17.i.MX 8X多传感器实现板(MEK)电路图(15)
NXP
图18.i.MX 8X多传感器实现板(MEK)电路图(16)
NXP
图19.i.MX 8X多传感器实现板(MEK)电路图(17)
NXP
图20.i.MX 8X多传感器实现板(MEK)电路图(18)
NXP
图21.i.MX 8X多传感器实现板(MEK)电路图(19)
NXP
图22.i.MX 8X多传感器实现板(MEK)电路图(20)
NXP
图23.i.MX 8X多传感器实现板(MEK)电路图(21)
