PLC行业常用184个专业英语中英文词汇对照
1.2w人已加入
1. PLC   可编程逻辑控制器2. absolute  绝对位置
3. absoluteoutput  绝对输出4 .actuator  执行器/作动器5. against  对比6. allocate  分配 7. alter  改变/修改8. ambient  环境周围  ambient operating temperature 9. analog  模拟   analogoutput 10. analysis  分析 thecollection an and analysis of data 12. applicable  可用  the applicableCPU for the module13. assign  分配 14. back up battey  备用电池15. barcode reader/ID  条形码阅读器16. base unit  主基板17. baud  波特  18. beforehand  事先19. binary  二进制  20. buffer memory  缓冲存储器21. bus  总线22. case 外壳 do notremove the module's print board from the case
23. characteristic 特征
I/Ocharacterristic
24. check  校验 the datalink status canbe checked25. child-station  子站26. common terminal   公共端
27. compatible  兼容 compatiblewith the MODBUS protocol
28. compound  混合  compoundsystem communication 29. condensation  结露30. condition   条件  conditionsetting
31. conductive  导电  conductivemetal picees32. configuration 组态
systemconfiguration
33. configure  组态34. confirm 确认how toconfirm the operation of the module35. consumption  消耗
currentconsumption36. content  目录37. control level  控制级38. convenient  方便 moreconvenient and easy-to-use39. conventionaly  传统
whichconventionaly has been used 40. conversion 转换 Analog-Digital conversion module41. converter   转换器42. conveyor  传送 conveyorline 43. corrosive  腐蚀 corrosivegas 44. countermeasure  对策
countermeasure for mis-inpute45. cutoff  切断46. debug  调试 isrecommended before debugging47. dedicated  屏蔽
cc-linkdedicated cable48. dedicated  专用 dedicatedtransmission protocol49. default value  缺省值50. define  解释/阐明 Offset value and gain value are defined as follow. 51. design  设计 design asystem52. device level  现场级53. diagnosis  诊断 diagnosisfunction54. digital  数字  digitalinpute55. DIN rail  导轨56. diverse  不同的/各种各样的 57. download  下载58. duplicate  完全一样59. dust  灰尘60. eliminate  免得61. enterprise level  管理级62. erase  清除63. exceed  超出The numberadmitted must not exceed 200
64.execute 执行date linkis executed using these parameters
65. expand  扩展 can beeapanded up to 255 networks66. faulty  故障站67. field bus  现场总线68. fix  固定69. flexibly  灵活的 to supporta variety systerm flexibly
70. flow  流量71. format  格式  transmission format72. fuse   融丝
73.graph图标坐标图曲线voltage output characterristicgraph
74.guaranteed 担保nomaloperration cannot be guaranteed 75. handle  处理76. hardware manual  硬件手册77. hint  提示 programminghints78. humidity  湿度 ambientoperating humdlity79. individual  独立的80. inductance  电感  inductanceload81. initiate  实施发起 can be initiate by a computer [i`nifieit]82. input  输入83. input point  输入点数84. install  安装85. instruction  指令
the FROMinstruction86. insulation 隔离 form rubberprovides good insulation 87. interface  接口88.interlocking 互锁can be usedfor sequence program interlocking89. internal external  内部 外部 internal connection90. interrupt  中断 excute aninterrupt processing91. invalid 无效 errorinvalid station function92. magnetic 有磁性的 magneticfields [maeg`netik]93. main circuit  主回路/线电路94. malfunction  故障 causesystem malfunction95. mandatory  强制96. mantenance  维护
maintenancecosts are reduced97. manual  手册 User'Manual98. mechanical  机械 michanicallife  机械寿命99. module  模块/组件  mount orremove the module 100. momentary power failure  瞬时断电101. monitor  监视102. mount  固定  mount orremove the module103. multiple  多样  mutipleremote i/o modules104. negative  负105. observation  观察106. occupy  占用  occupies 1station 107. occur  发生108. offline  离线  offlinetest109. offset gain  偏置增益110. oil mist  油雾112. optical loop  光缆回路113. optimum  最佳的 optimumcontrol 114. output  输出115. overall  总的  overalldistance116. overview  总揽  communication overview117. parameter  参数118. path  路径  transmission path119. per network120. perform  进行 normal datalink cannot be performed121. performance specifations  性能规格122. peripheral  外围/外部设备  Whenutilizing peripheral device to assign I/O number.123. phase 相  swith offall phases of the power supply 124. point  要点125. port  接口  Rs232c port126. positive  正127.power line 电源线128. power on/off  电源开/关129.precaution 注意事项precaution when configuing system130. print board  印刷电路板131. procedure  过程
follow theprocedure132. programing interface  编程接口/编程界面133. protocol  协议
protocolcommunication issues 134. range  范围135. rated input voltage  额定输入电压136. ratio  比率137. recommend  建议  isrecommended before debugging138. reduce  减少/缩小 the numberof steps in operation program can be reduced139. refer to  参照  refer toChapter 6140. register  数据寄存器141. relay  继电器 142. remote I/O 远程网络143. reserved station 预留主站144. resistor  电阻器
load bridgingresistor  负载转移电阻
load compensating resistor  负荷补偿电阻
load shifting resistor  负载移动电阻器 ; 负荷转移电阻
load-resistor contactor  负载电阻器接触器 ; 负荷电阻接触器
anode load resistor   释义阳极负载电阻 ; 阳极负载电阻
effect of load resistor  负载电阻效应
145. resolution  分辨率
nMaximum resolution   最大分辨率 146. restriction  限制  norestriction [ri`strikfn]147. retry 重试148. scan 扫描 link scan149. screw 螺丝 Teminal-block screw150. seamless network  无缝网络151. sequence programme  顺控程序152. serial communications module  串口通信模块153. series 系列154. servo 伺服系统155. short  短路156. signal 信号157. sink   漏极 sink commen158. slot  周边元件扩展插槽
159. soures 源极 sourescommen160. specifications 特性 inputmodules specifications161. stabilized power supply 稳压电源 162. standby master station 备用主站163. start up 起动164. status  状态  data linkstatus165. step drive  步进166. storage  存储  storagearea167. store  存储168. switch off  切断 swith offall phases of the power supply169. swith 开关170. table  表格171. transfer 传送172. transistor 晶体管173. transmission speed 传输速度174. transmit  传送/传输 data istransmitted in unchanged code175. triac  三端双向可控硅开关元件
176. troubleshooting  故障处理177. unuseble  不可以使用178. upload  上传/上载179. utilize  利用 180. verify  校验  verify theset parameter contents181. voltage  电压  highvoltage 182. watchdog  看门狗定时器183. width  范围 184.  wire chips  线头
