Holtek HT82V863R CCD监控摄影机处理方案
移动通信
298人已加入
关键词: CCD , Holtek , HT82V863R , 监控摄影机
Holtek(盛群半导体)公司的HT82V863R是新一代的 CCD监控摄影机处理器, 采用更精简的 64LQFP封装, 新的影像处理器在低照,色彩及噪声等各项影像处理上,其性能都比 HT82V862R 优秀,提供数字式高动态处理,自动背光补偿及数字式线锁定同步等功能.本文介绍了HT82V863R主要特性,方框图以及系统应用框图.
The HT82V863R is a single chip digital image processor for Ye, Cy, Mg and G colour CCD video camera systems. It receives CFA patterns from colour CCDs and generates NTSC/PAL CVBS signals using internal video encoders and the 10-bit DAC. In addition, it also provides an AE/AWB algorithm, timing generation module together with other circuitry. The device contains a microcontroller in which an OTP ROM is integrated internally to implement the basic camera functions such as the AE/AWB algorithm. The video camera system consists of a CDS/AGC/ADC IC (HT82V842A), DSP IC (HT82V863R), Vertical Driver IC (HT82V805) and CCD sensors. It also provides a proprietary function to eliminate so called “line crawl” and automatic CCD defect compensation function to correct up to 30 bad pixels and 4 consequential bad pixels.
HT82V863R主要特性:
• Input: Supports Ye, Mg, Cy, G colour filters for NTSC/PAL, 270K/320K/410K/470K CCD sensors
• Output: NTSC/PAL Analog CVBS
• Automatic CCD Defect compensation Up to 50 bad pixels and 4 consequential bad pixels correction
• Automatic Back Light compensation
• Programmable False Colour suppression
• Programmable High Light suppression
• Programmable Sharpness enhancement
• Programmable Colour Saturation and Hue function
• Programmable Contrast and Brightness function
• Programmable GAMMA curve
• Integrate a 96-step CCD timing generator
• Support AE/AWB algorithm function
• Support OSD function
• Integrate a 2-D DNR function
• Integrate the digital WDR
• Integrate the digital Line Lock function to reduce colour rolling
• Integrate a NTSC/PAL video encoder
• Integrate a 10-bit DAC
• Support CCIR656 digital out
• Integrate a one-channel 6-bit ADC
• Integrate OTP ROM with ISP function for multiple programming codes
• Support Mirror function
• Support a master I2C interface for external EEPROM to store parameters
• Support a slave I2C interface for communication with an external host
• Embedded LVR and POR circuits
• Embedded 3.3V-to-1.8V regulator
• Single 3.3V power supply
• 64/80-LQFP package
2011-10-14 17:35:04 上传
下载附件 (29.04 KB)
图1. HT82V863R方框图
下载附件 (32.03 KB)
图2. HT82V863R系统应用框图
详情请见:
  • 相关推荐
