了解并学会使用Linux中ifreq结构体
嵌入式技术
1335人已加入
结构原型:
 * Interface request structure used for socket
 * ioctl's.  All interface ioctl's must have parameter
 * definitions which begin with ifr_name.  The
 * remainder may be interface specific.
struct ifreq
#define IFHWADDRLEN 6
 union
  char ifrn_name[IFNAMSIZ];  /* if name, e.g. "en0" */
 } ifr_ifrn;
 union {
  struct sockaddr ifru_addr;
  struct sockaddr ifru_dstaddr;
  struct sockaddr ifru_broadaddr;
  struct sockaddr ifru_netmask;
  struct  sockaddr ifru_hwaddr;
  short ifru_flags;
  int ifru_ivalue;
  int ifru_mtu;
  struct  ifmap ifru_map;
  char ifru_slave[IFNAMSIZ]; /* Just fits the size */
  char ifru_newname[IFNAMSIZ];
  void __user * ifru_data;
  struct if_settings ifru_settings;
 } ifr_ifru;
#define ifr_name ifr_ifrn.ifrn_name /* interface name  */
#define ifr_hwaddr ifr_ifru.ifru_hwaddr /* MAC address   */
#define ifr_addr ifr_ifru.ifru_addr /* address  */
#define ifr_dstaddr ifr_ifru.ifru_dstaddr /* other end of p-p lnk */
#define ifr_broadaddr ifr_ifru.ifru_broadaddr /* broadcast address */
#define ifr_netmask ifr_ifru.ifru_netmask /* interface net mask */
#define ifr_flags ifr_ifru.ifru_flags /* flags  */
#define ifr_metric ifr_ifru.ifru_ivalue /* metric  */
#define ifr_mtu  ifr_ifru.ifru_mtu /* mtu   */
#define ifr_map  ifr_ifru.ifru_map /* device map  */
#define ifr_slave ifr_ifru.ifru_slave /* slave device  */
#define ifr_data ifr_ifru.ifru_data /* for use by interface */
#define ifr_ifindex ifr_ifru.ifru_ivalue /* interface index */
#define ifr_bandwidth ifr_ifru.ifru_ivalue    /* link bandwidth */
#define ifr_qlen ifr_ifru.ifru_ivalue /* Queue length  */
#define ifr_newname ifr_ifru.ifru_newname /* New name  */
#define ifr_settings ifr_ifru.ifru_settings /* Device/proto settings*/
基本介绍:
ifreq结构定义在/usr/include/net/if.h,用来配置ip地址,激活接口,配置MTU等接口信息的。其中包含了一个接口的名字和具体内容——(是个共用体,有可能是IP地址,广播地址,子网掩码,MAC号,MTU或其他内容)。ifreq包含在ifconf结构中。而ifconf结构通常是用来保存所有接口的信息的。
举例说明:
在Linux系统中,ifconfig命令是通过ioctl接口与内核通信,例如,当系统管理员输入如下命令来改变接口eth0的MTU大小:
ifconfig eth0 mtu 1250
ifconfig命令首先打开一个socket,然后通过系统管理员输入的参数初始化一个数据结构,并通过ioctl调用将数据传送到内核。SIOCSIFMTU是命令标识符。
struct ifreq data;
    fd = socket(PF_INET, SOCK_DGRAM, 0);
    < ... initialize "data" ...>
    err = ioctl(fd, SIOCSIFMTU, &data);
