XTR112,XTR114,pdf(4-20mA Curre
消耗积分:0 | 格式:rar | 大小:211 | 2010-09-26
分享资料个
The XTR112 and XTR114 are monolithic 4-20mA,
two-wire current transmitters. They provide complete
current excitation for high impedance platinum RTD
temperature sensors and bridges, instrumentation am-
plifier, and current output circuitry on a single inte-
grated circuit. The XTR112 has two 250µA current
sources while the XTR114 has two 100µA sources for
RTD excitation.
Versatile linearization circuitry provides a 2nd-order
correction to the RTD, typically achieving a 40:1
improvement in linearity.
Instrumentation amplifier gain can be configured for a
wide range of temperature or pressure measurements.
Total unadjusted error of the complete current trans-
mitter is low enough to permit use without adjustment
in many applications. This includes zero output cur-
rent drift, span drift and nonlinearity. The XTR112
and XTR114 operate on loop power supply voltages
down to 7.5V.
评论(1)
发评论
成森林 2021-01-16
0 回复 举报
谢谢楼主! 收起回复
下载排行榜
全部1条评论
