XTR117,pdf(4-20mA Current-Loop
消耗积分:0 | 格式:rar | 大小:611 | 2010-09-26
淡淡的爱
分享资料个
The XTR117 is a precision current output converter designed to transmit analog 4-20mA signals over an industry- standard current loop. It provides accurate current scaling and output current limit functions.
The on-chip voltage regulator (5V) can be used to power external circuitry. A current return pin (IRET) senses any current used in external circuitry to assure an accurate control of the output current.
The XTR117 is a fundamental building block of smart sensors using 4-20mA current transmission. The XTR117 is specified for operation over the extended industrial temperature range, -40°C to +125°C.
评论(2)
发评论
成森林 2021-01-16
0 回复 举报
楼主辛苦! 收起回复
蒋末0105 2020-06-15
0 回复 举报
厉害 收起回复
下载排行榜
全部2条评论
