TLC59116 16 通道 Fm+ I2C 总线恒流下沉式 LED 驱动器
KANA 发表于 2019-04-18 20:08:09
数据: TLC59116中文资料.pdf
产品信息
描述The TLC59116 is an I2C bus controlled 16-channel LED driver that is optimized for red/green/blue/amber (RGBA) color mixing and backlight application. Each LED output has its own 8-bit resolution (256 steps) fixed-frequency individual PWM controller that operates at 97 kHz, with a duty cycle that is adjustable from 0% to 99.6%. The individual PWM controller allows each LED to be set to a specific brightness value. An additional 8-bit resolution (256 steps) group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds, with a duty cycle that is adjustable from 0% to 99.6%. The group PWM controller dims or blinks all LEDs with the same value. Each LED output can be off, on (no PWM control), or set at its individual PWM controller value at both individual and group PWM controller values. The TLC59116 operates with a supply voltage range of 3 V to 5.5 V and the outputs are 17 V tolerant. LEDs can be directly connected to the TLC59116 device outputs. Software programmable LED Group and three Sub Call I2C-bus addresses allow all or defined groups of TLC59116 devices to respond to a common I2C-bus address, allowing for example, all the same color LEDs to be turned on or off at the same time or marquee chasing effect, thus minimizing I2C-bus commands. Four hardware address pins allow up to 14 devices on the same bus. The Software Reset (SWRST) Call allows the master to perform a reset of the TLC59116 through the I2C-bus, identical to the Power-On Reset (POR) that initializes the registers to their default state causing the outputs to be set high (LED off). This allows an easy and quick way to reconfigure all device registers to the same condition.特性16 LED Drivers (Each Output Programmable at Off, On, Programmable LED Brightness, or Programmable GroupDimming and Blinking Mixed With Individual LED Brightness)16 Constant-Current Output Channels256-Step (8-Bit) Linear Programmable Brightness Per LED Output Varying From Fully Off (Default) to Maximum Brightness Using a 97-kHz PWM Signal256-Step Group Brightness Control Allows General Dimming [Using a 190-Hz PWM Signal From Fully Off to Maximum Brightness (Default)]256-Step Group Blinking With Frequency Programmable From 24 Hz to 10.73 s and Duty Cycle From 0% to 99.6%Four Hardware Address Pins Allow 14 TLC59116 Devices to Be Connected to Same I2C BusFour Software-Programmable I2C Bus Addresses (OneLED Group Call Address and Three LED Sub Call Addresses)Allow Groups of Devices to Be Addressed at Same Time in Any CombinationSoftware Reset Feature (SWRST Call) Allows Device to Be Reset Through I2C BusUp to 14 Possible Hardware-Adjustable Individual I2C Bus Addresses Per Device, So That Each Device Can Be ProgrammedOpen-Load and Overtemperature Detection Mode to DetectIndividual LED ErrorsOutput State Change Programmable on Acknowledge or StopCommand to Update Outputs Byte-by-Byte or All at Same Time(Default toChange on Stop)Output Current Adjusted Through an External ResistorConstant Output Current Range: 5 mA to 120 mAMaximum Output Voltage: 17 V25-MHz Internal Oscillator Requires No External Components1-MHz Fast-mode Plus (FMT) Compatible I2C Bus Interface With 30-mA High-Drive Capability on SDA Output for Driving High-Capacitive BusesInternal Power-On ResetNoise Filter on SCL and SDA InputsNo Glitch on Power-UpActive-Low ResetSupports Hot InsertionLow Standby Current3.3-V or 5-V Supply Voltage5.5-V Tolerant InputsOffered in 28-Pin Thin Shrink Small-Outline Package (TSSOP) (PW) and 32-Pin Quad Flatpack No Lead (QFN)–40 °C to 85 °C OperationAPPLICATIONSGaming Small Signage Industrial Equipment All other trademarks are the property of their respective owners
电路图、引脚图和封装图
技术文档
数据手册(1)
收藏
相关话题
文章来源栏目
+加入圈子
评论(0)
加载更多评论
参与评论
分享到
QQ空间 QQ好友 微博
取消
