产品信息
描述The THS12082 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed, resolution, bandwidth, and single-supply operation are suited for applications in radar, imaging, high-speed acquisition, and communications. A multistage pipelined architecture with output error correction logic provides for no missing codes over the full operating temperature range. Internal control registers allow for programming the ADC into the desired mode. The THS12082 consists of two analog inputs, which are sampled simultaneously. These inputs can be selected individually and configured to single-ended or differential inputs. An integrated 16 word deep FIFO allows the storage of data in order to take the load off of the processor connected to the ADC. Internal reference voltages for the ADC (1.5 V and 3.5 V) are provided.An external reference can also be chosen to suit the dc accuracy and temperature drift requirements of the application. Two different conversion modes can be selected. In the single conversion mode, a single and simultaneous conversion can be initiated by using the single conversion start signal (CONVST)\. The conversion clock in the single conversion mode is generated internally using a clock oscillator circuit. In the continuous conversion mode, an external clock signal is applied to the CONV_CLK input of the THS12082. The internal clock oscillator is switched off in the continuous conversion mode. The THS12082C is characterized for operation from 0°C to 70°C, and the THS12082I is characterized for operation from 40°C to 85°C.特性Simultaneous Sampling of 2 Single-Ended Signals or 1 Differential Signal Integrated 16 Word FIFO Signal-to-Noise and Distortion Ratio: 66 dB at fI = 2 MHz Differential Nonlinearity Error: ±1 LSB Integral Nonlinearity Error: ±1.5 LSB Auto-Scan Mode for 2 Inputs 3-V or 5-V Digital Interface Compatible Low Power: 216 mW Max 5-V Analog Single Supply Operation Internal Voltage References . . . 50 PPM/°C and ±5% Accuracy Parallel µC/DSP Interface applications Radar Applications Communications Control Applications High-Speed DSP Front-End Automotive Applications
