产品信息
描述The THS1209 is a CMOS, low-power, 12-bit, 8 MSPS analog-to-digital converter (ADC). The speed, resolution, bandwidth, and single-supply operation are suited for applications in radar, imaging, high-speed acquisition, and communications. A multistage pipelined architecture with output error correction logic provides for no missing codes over the full operating temperature range. Internal control registers allow for programming the ADC into the desired mode. The THS1209 consists of two analog inputs, which are sampled simultaneously. These inputs can be selected individually and configured to single-ended or differential inputs. Internal reference voltages for the ADC (1.5 V and 3.5 V) are provided. An external reference can also be chosen to suit the dc accuracy and temperature drift requirements of the application. The THS1209C is characterized for operation from 0°C to 70°C, and the THS1209I is characterized for operation from 40°C to 85°C.特性Simultaneous Sampling of 2 Single-Ended Signals or 1 Differential Signal Signal-to-Noise Ratio: 68 dB at fI = 2 MHz Differential Nonlinearity Error: ±1 LSB Integral Nonlinearity Error: ±1.5 LSB Auto-Scan Mode for 2 Inputs 3-V or 5-V Digital Interface Compatible Low Power: 218 mW Max at 5 V Power Down: 1 mW Max 5-V Analog Single Supply Operation Internal Voltage References ...50 PPM/°C and ±5% Accuracy Glueless DSP Interface Parallel µC/DSP Interface APPLICATIONS Radar Applications Communications Control Applications High-Speed DSP Front-End Automotive Applications
