​详解gitlab+jenkins如何打造ceph的rpm自动编译
1.2w人已加入
前置条件
准备jenkins和gitlab的安装,这个过程请自行谷歌
jenkins 插件设置
需要添加的插件:Gitlab Hook、Build Authorization Token Root、Gitlab Authentication、Gitlab
jenkins
jenkins
gitlab新建ceph
jenkins
源码包上传到gitlab
在 http://download.ceph.com/tarballs/ 下载对应的软件包版本,以12.2.12为例
解压软件包
[root@demohost1 supdev]# tar zxf ceph-12.2.12.tar.gz #解压[root@demohost1 ceph-12.2.12]# cd ceph-12.2.12[root@demohost1 ceph-12.2.12]# lsadmin    ceph-erasure-code-corpus  ChangeLog       CONTRIBUTING.rst  debian            do_freebsd.sh  fusetrace        make-apk.sh   man
                  pom.xml     README.alpine.md    README.solaris     share
                  udevalpine   ceph-object-corpus        cmake           COPYING           doc               Doxyfile       INSTALL          make-
debs.sh  mirroring  qa
          README.FreeBSD      README.xio         srcAUTHORS  ceph.spec
                 CMakeLists.txt  COPYING-GPL2      doc_deps.deb.txt  etc
            install-deps.sh  make-dist     NEWS
                 README      README.git-subtree  run-make-check.sh  SubmittingPatches.rstbin      ceph.spec.in
              CodingStyle     COPYING-LGPL2.1   do_cmake.sh       examples       keys
             make-srpm.sh  PendingReleaseNotes  README.aix  README.md  selinux
            systemd[root@demohost1 ceph-12.2.12]# find . -name ".gitignore"| xargs rm -f #关键步骤,剔除掉.gitignore,不然后面编译依赖检查会报错
初始化git,提交到gitlab仓库
[root@demohost1 ceph-12.2.12]# git initInitialized empty Git repository in /home/supdev/ceph-12.2.12/.git/[root@demohost1 ceph-12.2.12]# pwd/home/demo/ceph-12.2.12[root@demohost1 ceph-12.2.12]# git remote add origin http://gitlab.cephdemo.local/diluga/ceph.git[root@demohost1 ceph-12.2.12]# git add --all .  The file will have its original line endings in your working directory.warning: CRLF will be replaced by LF in src/rapidjson/thirdparty/gtest/googletest/msvc/gtest_unittest.vcproj.The file will have its original line endings in your working directory.[root@demohost1 ceph-12.2.12]# git commit -m "Initial commit"[master (root-commit) 85a9fab] Initial commit Committer: root Your name and email address were configured automatically basedon your username and hostname. Please check that they are accurate.You can suppress this message by setting them explicitly:    git config --global user.name "Your Name"    git config --global user.email you@example.comAfter doing this, you may fix the identity used for this commit with:    git commit --amend --reset-authorThe file will have its original line endings in your working directory. 46084 files changed, 9316748 insertions(+) create mode 100644 .gitmodule_mirrors create mode 100644 .gitmodules ... create mode 100644 udev/60-ceph-by-parttypeuuid.rules create mode 100644 udev/95-ceph-osd.rules[root@demohost1 ceph-12.2.12]# git push -u origin masterUsername for 'http://gitlab.cephdemo.local': dilugaPassword for 'http://diluga@gitlab.cephdemo.local':Counting objects: 48328, done.Delta compression using up to 32 threads.Compressing objects: 100% (47048/47048), done.Writing objects: 100% (48328/48328), 83.34 MiB | 8.29 MiB/s, done.Total 48328 (delta 12162), reused 0 (delta 0)remote: Resolving deltas: 100% (12162/12162), done.To http://gitlab.cephdemo.local/diluga/ceph.git * [new branch]      master -> masterBranch master set up to track remote branch master from origin.
jenkins 任务设置
新建一个自由风格的软件项目,输入"rpmbuilid_ceph"
jenkins
之后在源码管理里面选择git,输入之前新建的gitlab项目信息,设置相应的分支,这里选的是默认master分支
jenkins
Credentials部分,选择“添加”,输入gitlab的账号和密码如下
jenkins
之后设置 构建触发器,选择“Build when a change is pushed to GitLab”,记录“GitLab webhook URL”,选择在 “Push Events” 和 “Accepted Merge Request Events” 两种事件类型的时候触发webhook通知。
jenkins
同时在Secret token 点击“Generate”,记录生成的token字段
jenkins
最后选择"构建” -> "执行 shell",输入对应的rpm编译打包脚本,点击保存,完成jenkins设置。
jenkins
脚本如下
#!/bin/bashrm -rf ~/rpmbuild/usr/bin/rpmdev-setuptreecp -f ./ceph.spec ~/rpmbuild/SPECS#git archive master --prefix=ceph-12.2.12/ | bzip2 > ceph-12.2.12.tar.bz2mkdir ceph-12.2.12mv * ceph-12.2.12cp .gitmodules ceph-12.2.12tar -cvjSf ceph-12.2.12.tar.bz2 ceph-12.2.12cp ceph-12.2.12.tar.bz2 ~/rpmbuild/SOURCES/cd ~/rpmbuild/usr/bin/rpmbuild -bb SPECS/ceph.spec
gitlab webhook设置
打开gitlab 对应的项目,在 settings -> integrations
jenkins
输入之前的“GitLab webhook URL” 和 token,勾选 push和 merge 两种类型的事件,如果没用到SSL,则取消SSL认证。
jenkins
启动编译
回到jenkins对应的"rpmbuild_ceph"任务列表,点击“立即构建”,开始编译ceph的rpm包,
jenkins
编译过程可以通过点击具体任务,查看“控制台输出”,看到编辑的当前进度状态。
jenkins
编译完成后,RPM包会存储在jenkins节点的/root/rpmbuild/下。
总结
上面的设置需要注意的有3点
代码提交到gitlab一定要剔除掉“.gitignore”,当然你可以手工去修改具体内容,不然后面编译会报错。
jenkins是基于gitlab的pull和merge事件来触发后台的自动编译,所有后续在gitlab上面的代码pull和merge操作都会触发相应版本的rpm包编译,注意这里只针对源码的master分支做了处理,各位根据实际情况进行调整。
源码里面的“ceph.spec”文件写死了一些配置,如果你改变了编译流程细节,则需要修改对应的配置内容,比如源件包名称必须是"ceph-12.2.12.tar.bz2",具体可以参考ceph.spec内容。
