基于ATmega48的3相无刷电机的控制方法
消耗积分:0 | 格式:rar | 大小:614 | 2010-12-21
分享资料个
介绍了采用ATmega48单片机实现三相无刷直流电机控制器的方法。利用Atmega48获得带死区的脉宽调制(PWM)、霍尔传感器的换相处理、正弦驱动信号的产生和电机转速的控制等功能。采用该方法的优点是所需的外围器件少,成本低。
Abstract:
 The method of 3-phase brushless DC motor control based on ATmega48 is presented in this paper.The system uses ATmega48 to generate PWM signals with dead-time, hall sensors signals commutation,sine driving signal and rotational speed of motor.Using this method,the needed external devices are few, the cost is low.
评论(1)
发评论
gzxiaozhong 2021-07-01
0 回复 举报
AVR单片机控制无刷电机的文章需要学一学 收起回复
下载排行榜
全部1条评论
