Diodes公司的45W USB PD 3.0适配器评估板由三部分组成:1)电流模式PWM控制器AP3108L,提供具有频率折回的DCM/CCM PWM开关,以提高效率;2)同步整流控制器APR346;3) USB Type-C供电控制器AP43770,它和USB Type-C规范发布1.3和USB供电(PD)规范Rev3.0 V1.2兼容。 AP43770以20mV/步分辨率和50mA/步电流分辨率支持PPS APDO,用来电源管理。它也支持移动市场的高通快速充电4(Qualcomm Quick Charge 4)。评估板满足DOE 6 和CoC Tier 2效率要求,无负载待机功耗小于30mW,主要用在USB PD 3.0墙上适配器和USB PD 3.0汽车充电器。本文介绍了AP3108L主要特性,功能框图表和典型应用电路,以及AP43770主要特性,功能框图表和典型应用电路。同时还介绍了45W USB PD 3.0适配器评估板EV2主要特性和电源指标,电路图,变压器指标和材料清单。
1.AP3108L
The AP3108L is a Current Mode PWM controller specially designed for offline power supply that requires ultra-low standby power, high- power density and comprehensive protection. The AP3108L coordinating with Diodes’ secondary side controller, such as the AP4320, can be applied in the situation that requires for constant CC and constant CV.
The maximum switching frequency of the AP3108L is set at 65kHZ. The switching frequency can be modulated through green mode, in which it will smoothly decrease along with the decreasing load. This will cause the minimum switching frequency to be clamped at about 22kHz to avoid audible noise.
The AP3108L provides an inner high-voltage start-up function through HV pin which can save the use of the external start-up resistor, reducing the standby loss. The HV pin also realizes X-CAP discharge function. This is a useful function for power saving when an X-CAP is connected to a system, for it will discharge the X-CAP when the AC line voltage is off automatically without the need for extra discharge resistors.
The AP3108L integrates a VCC LDO circuitry, allowing the LDO to regulate the wide range VCC_IN, which is rectified from auxiliary winding to an acceptable value. This makes the AP3108L a good choice in wide range output voltage application.
There are also versatile system protections provided by AP3108L, such as secondary side OVP, secondary side UVP, constant output current limit, cycle-by-cycle current limit, brown-out protection, programmable external OTP, etc.
AP3108L主要特性:
Current Mode Control
High-Voltage Startup
Embedded VCC LDO to Guarantee Wide Range Output Voltage
Constant, Low Output Current in Output Short Situation
Low VCC Charge Current Reduces Standby Power in Output Short Situation
Non-Audible-Noise Green-Mode Control
Internal Slope Compensation
Soft Start During Startup Process
Frequency Fold Back for High Average Efficiency
Constant Over Current Protection(COCP)
VCC Maintain Mode
X-CAP Discharge Function
Precise Secondary Side OVP and UVP
Programmable External OTP
Brown-Out Protection
Overload Protection
FOCP and SSCP Protection
Useful Pin Fault Protection
SSOP-9 (Type CJ) is Available
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
AP3108L应用:
Switching AC-DC Adapter/Charger
Open Frame Switching Power Supply
图1.AP3108L典型应用电路
图2. AP3108L功能框图
2.AP43770
The AP43770 is a USB Type-C power delivery controller dedicated to power source applications with legacy capability. It is compliant with USB Type-C specification release 1.3 and USB power delivery (PD) specification Rev3.0 V1.2.
The AP43770 can support PPS APDO with 20mV/step resolution and 50mA/step current resolution for power management. In addition, it supports Qualcomm Quick Charge 4 for mobile market. What’s more, cable-loss compensation and SOP’command for e-Marker detection are embedded too.
In consideration of customer applications, the AP43770 supports options for non-PD protocols like BC 1.2, QC4/4+,QC3.0/QC2.0, and other legacy protocols with auto-detection. It maintains backwards compatibility with the existing environment. There are rich power-features embedded on the chip and they can be configured through CC channel.
AP43770主要特性:
Compliant with USB PD Rev3.0 V1.2
USB-IF PD3.0/PPS Certificated TID = 1090017
Qualcomm QC4 and QC4+,QC3.0, QC2.0 Built-in
Support VOUT 20mV/Step from 3.3V to 20V
Support Current Limit 50mA/Step up to 6A
OTP(One-Time-Programmable ) for Main Firmware
MTP (Multi-Time-Programmable ) for System Configuration
USB PD Transceiver with High Noise Immunity
Built-In CC/CV Controller
Support e-Marker Cable Detection
Built-In VCONN Switch with OCP Protection
Cable Compensation for Different Load Condition
Programmable for Configuration through CC Line
Support OCP/SCP/OTP/UVP with Auto-Restart
Built-In 5V/1.8V LDO
Low Standby Current : 550μA
Maximum 32V Input Voltage Rating
Support Non-USB PD Protocol Options
BC 1.2 Legacy Built-In
TID(11090017) for USB PD 3.0 PPS Compliance Test
Package: TSSOP-16
AP43770应用:
• AC Adapters
• Car Chargers
• USB PD Converter
• Power Hubs
• Power Banks
图3.AP43770功能框图
图4. AP43770典型应用电路图
The 45W USB PD 3.0 Adaptor Evaluation Board EV2 is composed of three main parts. The AP3108L offers DCM/CCM PWM switching with frequency fold-back for improving efficiency. The APR346 is a Synchronous Rectification Controller, and the AP43770T16 is a USB 3.0 protocol decoder which is based on monitoring CC1 & CC2 signals for interpreting desired voltage and current setting, and then feedback the information to primary side AP3108L controller to provide well regulated voltage and current as well as related power protections. The 45W USB PD 3.0 Power Brick board passed the USB IF Compliance Test (TID: 11090056), at June 2018.
45W USB PD 3.0适配器评估板EV2主要特性:
1.1系统主要特性:
SSR Topology Implementation with an Opto-coupler for Accurate Step Voltage Controlling
USB PD 3.0 Compliance
Meet DOE 6 and CoC Tier 2 Efficiency Requirements
《30mW No-Load Standby Power
1.2. AP3108L主要特性:
Current Mode PWM Controller
Frequency shift function changes frequency per line loading
Frequency fold back for high average efficiency
Integration of high-voltage start-up circuit to enable low standby power
Integration of 100V LDO, X-cap discharge for minimal system BOM components
Constant load output current during output short circuit
Rich Protection Functions: Precise Secondary Side OVP, UVP, OLP, BNO,FOCP, SSCP, External Programmable OTP
1.3. APR346主要特性:
Synchronous rectification operating at DCM, CCM and QR mode for flyback topology
Eliminate Resonant Ringing Interference
Fewest External Components used
1.4. AP43770T16-13主要特性:
Type-C USB PD DFP (Downstream Facing Port)
USB PD2.0, PD 3.0,PPS,QC4 Protocol Decoding
10-Bit DAC for Vbus 3 ~ 20 voltage and 7 bits DAC for current monitoring
Built in shunt regulator for constant voltage and constant current
Support E-marker cable detection
Programmable OVP/UVP/OCP/OTP
Internal Discharge MOS
Internal Vbus Load Switch Driver
3V- 30V operation voltage without external regulator
Package 16-Pin TSSOP
USB PD 3.0 PPS IC Compliance Certified – TID #11090017, 07/12/2018
45W USB PD 3.0适配器评估板EV2应用:
USB PD 3.0 Wall Adaptor
USB PD 3.0 Car Charger
主要电源指标(CV&CC模式):
图5.45W USB PD 3.0适配器评估板EV2外形图(正面)
图6.45W USB PD 3.0适配器评估板EV2外形图(背面)
图7.45W USB PD 3.0适配器评估板EV2电路图
45W USB PD 3.0适配器评估板EV2材料清单:
变压器设计指标:
图8.45W USB PD 3.0适配器评估板EV2 PCB布局图:左:顶层;右:底层
图9.样板的连接图
