日本晶体管2SDxxxx 系列晶体管参数大全
电子常识
2686人已加入
型号材料最高电压最大电流最大功率频率沟道电阻
2SD92SI-NPN100 V3 A20 W--
2SD155SI-NPN80 V3 A25 W--
2SD198SI-NPN300 V1 A25 W45 MHz-
2SD200SI-NPN1500 V2,5 A10 W--
2SD213SI-NPN110 V10 A100 W--
2SD234SI-NPN60 V3 A25 W--
2SD287SI-NPN200 V10 A100 W8 MHz-
2SD313SI-NPN60 V3 A30 W8 MHz-
2SD325SI-NPN35 V1,5 A10 W8 MHz-
2SD350SI-NPN1500 V5 A22 W--
2SD350ASI-NPN1500 V5 A22 W--
2SD359SI-NPN40 V2 A10 W--
2SD361SI-NPN60 V1,5 A10 W70 MHz-
2SD381SI-NPN130 V1,5 A20 W60 MHz-
2SD382SI-NPN130 V1,5 A20 W60 MHz-
2SD386SI-NPN200 V3 A25 W8 MHz-
2SD400SI-NPN25 V1 A0,9 W--
2SD401SI-NPN200 V2 A20 W10 MHz-
2SD414SI-NPN80 V0,8 A10 W--
2SD415SI-NPN100 V0,8 A10 W--
2SD424SI-NPN160 V15 A150 W--
2SD438SI-NPN100 V0,7 A0,9 W100 MHz-
2SD467SI-NPN25 V0,7 A0,5 W280 MHz-
2SD468SI-NPN25 V1 A0,9 W280 MHz-
2SD471SI-NPN30 V1 A0,8 W--
2SD476SI-NPN70 V4 A40 W7 MHz-
2SD478SI-NPN200 V2 A30 W--
2SD545SI-NPN25 V1,5 A0,5 W--
2SD549N-DARL30 V1,5 A15 W--
2SD552SI-NPN220 V15 A150 W4 MHz-
2SD553SI-NPN70 V7 A40 W10 MHz-
2SD555SI-NPN400 V15 A200 W7 MHz-
2SD556SI-NPN120 V15 A120 W8 MHz-
2SD560N-DARL100 V5 A30 W--
2SD571SI-NPN60 V700 mA1 W110 MHz-
2SD592SI-NPN30 V1 A0,75 W200 MHz-
2SD596SI-NPN30 V0,7 A170 MHz--
2SD600KSI-NPN120 V1 A8 W--
2SD602ASI-NPN60 V0,5 A0,2 W200 MHz-
2SD612SI-NPN25 V2 A10 W100 MHz-
2SD613SI-NPN100 V6 A40 W15 MHz-
2SD617N-DARL120 V8 A100 W--
2SD637SI-NPN60 V0,1 A0,4 W150 MHz-
2SD661SI-NPN35 V0,1 A0,4 W200 MHz-
2SD662SI-NPN250 V0,1 A0,6 W50 MHz-
2SD666SI-NPN120 V0,05 A-140 MHz-
2SD667SI-NPN120 V1 A-140 MHz-
2SD669ASI-NPN160 V1,5 A1 W140 MHz-
2SD676SI-NPN160 V12 A125 W8 MHz-
2SD712SI-NPN100 V4 A30 W8 MHz-
2SD717SI-NPN70 V10 A80 W0,3 us-
2SD718SI-NPN120 V8 A80 W12 MHz-
2SD725SI-NPN1500 V6 A50 W--
2SD726SI-NPN100 V4 A40 W10 MHz-
2SD731SI-NPN170 V7 A80 W7 MHz-
2SD732SI-NPN150 V8 A80 W15 MHz-
2SD734SI-NPN25 V0,7 A0,6 W250 MHz-
2SD762SI-NPN60 V3 A25 W25 kHz-
2SD763SI-NPN120 V1 A0,9 W--
2SD768N-DARL+D120 V6 A40 W--
2SD773SI-NPN20 V2 A1 W110 MHz-
2SD774SI-NPN100 V1 A1 W95 MHz-
2SD781SI-NPN150 V2 A1 W0,6 us-
2SD786SI-NPN40 V0,3 A0,25 W--
2SD787SI-NPN20 V2 A0,9 W80 MHz-
2SD788SI-NPN20 V2 A0,9 W100 MHz-
2SD789SI-NPN50 V1 A0,9 W80 MHz-
2SD794SI-NPN70 V3 A10 W60 MHz-
2SD795SI-NPN40 V3 A20 W95 MHz-
2SD798N-DARL600 V6 A30 W--
2SD799N-DARL+D400 V6 A30 W--
2SD800SI-NPN750 V4 A30 W8 MHz-
2SD809SI-NPN100 V1 A10 W85 MHz-
2SD819SI-NPN1500 V3,5 A50 W--
2SD820SI-NPN1500 V5 A50 W--
2SD822SI-NPN600 V7 A50 W--
2SD826SI-NPN60 V5 A10 W120 MHz-
2SD829N-DARL+D150 V15 A100 W--
2SD837N-DARL60 V4 A40 W--
2SD844SI-NPN50 V7 A60 W15 MHz-
2SD850SI-NPN1500 V3 A25 W--
2SD856SI-NPN60 V3 A35 W--
2SD863SI-NPN50 V1 A0,9 W--
2SD864KN-DARL+D120 V3 A30 W--
2SD867SI-NPN130 V10 A100 W3 MHz-
2SD871SI-N+D1500 V5 A50 W--
2SD879SI-NPN30 V3 A0,75 W200 MHz-
2SD880SI-NPN60 V3 A30 W0,8 us-
2SD882SI-NPN30 V3 A10 W--
2SD889SI-N+D1500 V4 A50 W--
2SD892AN-DARL60 V0,5 A0,4 W--
2SD894N-DARL30 V1,5 A10 W120 MHz-
2SD895SI-NPN100 V6 A60 W10 MHz-
2SD917SI-NPN330 V7 A70 W--
2SD921N-DARL200 V5 A80 W--
2SD946N-DARL30 V1 A---
2SD947N-DARL40 V2 A5 W150 MHz-
2SD951SI-NPN1500 V3 A65 W--
2SD958SI-NPN120 V0,02 A0,4 W200 MHz-
2SD965SI-NPN40 V5 A0,75 W150 MHz-
2SD966SI-NPN40 V5 A1 W150 MHz-
2SD968ASI-NPN120 V0,5 A1 W120 MHz-
2SD970N-DARL+D120 V8 A40 W--
2SD972N-DARL50 V4 A30 W--
2SD982N-DARL200 V5 A40 W--
2SD986N-DARL80 V1,5 A10 W--
2SD998N-DARL100 V1,5 A10 W--
2SD1010SI-NPN50 V50 mA0,3 W200 MHz-
2SD1012SI-NPN20 V0,7 A0,25 W250 MHz-
2SD1018SI-NPN250 V4 A80 W--
2SD1027N-DARL+D20 V15 A100 W--
2SD1033SI-NPN200 V2 A20 W10 MHz-
2SD1036SI-NPN120 V15 A150 W--
2SD1047SI-NPN160 V12 A100 W15 MHz-
2SD1048SI-NPN20 V0,7 A0,25 W250 MHz-
2SD1049SI-NPN120 V25 A100 W--
2SD1051SI-NPN50 V1,5 A1 W150 MHz-
2SD1055SI-NPN40 V2 A0,75 W100 MHz-
2SD1062SI-NPN60 V12 A40 W10 MHz-
2SD1064SI-NPN60 V12 A80 W--
2SD1065SI-NPN60 V15 A90 W--
2SD1073N-DARL300 V4 A40 W--
2SD1088N-DARL300 V6 A30 W--
2SD1113KN-DARL+D300 V6 A40 W--
2SD1128N-DARL150 V5 A30 W--
2SD1135SI-NPN80 V4 A40 W--
2SD1138SI-NPN200 V2 A30 W--
2SD1140N-DARL30 V1,5 A0,9 W--
2SD1145SI-NPN60 V5 A0,9 W120 MHz-
2SD1148SI-NPN140 V10 A100 W20 MHz-
2SD1153SI-NPN80 V1,5 A0,9 W--
2SD1163ASI-NPN300 V7 A40 W--
2SD1164SI-NPN150 V1,5 A10 W--
2SD1173SI-N+D1500 V5 A70 W--
2SD1187SI-NPN100 V10 A80 W10 MHz-
2SD1189SI-NPN40 V2 A5 W100 MHz-
2SD1192N-DARL+D70 V10 A40 W--
2SD1196N-DARL+D110 V8 A40 W--
2SD1198N-DARL30 V1 A1 W150 MHz-
2SD1207SI-NPN60 V2 A1 W--
2SD1210N-DARL+D150 V10 A80 W--
2SD1213SI-NPN60 V20 A50 W--
2SD1225SI-NPN40 V1 A1 W150 MHz-
2SD1238SI-NPN120 V12 A80 W20 MHz-
2SD1244SI-N+D900 V1 A50 W--
2SD1246SI-NPN30 V2 A0,75 W--
2SD1247SI-NPN30 V2,5 A1 W--
2SD1254SI-NPN130 V3 A30 W--
2SD1255SI-NPN130 V4 A35 W30 MHz-
2SD1263ASI-NPN400 V0,75 A35 W30 MHz-
2SD1264SI-NPN200 V2 A30 W--
2SD1265SI-NPN60 V4 A30 W25 kHz-
2SD1266SI-NPN60 V3 A35 W--
2SD1267SI-NPN60 V4 A40 W20 MHz-
2SD1270SI-NPN130 V5 A2 W30 MHz-
2SD1271SI-NPN130 V7 A40 W30 MHz-
2SD1272SI-NPN200 V1 A40 W25 MHz-
2SD1273SI-NPN80 V3 A40 W50 MHz-
2SD1274SI-NPN150 V5 A40 W40 MHz-
2SD1276N-DARL60 V4 A40 W--
2SD1286N-DARL+D60 V1 A8 W--
2SD1288SI-NPN120 V7 A70 W--
2SD128 打开APP阅读更多精彩内容
