日本晶体管2SBxxxx 系列晶体管参数大全
电子常识
2686人已加入
型号材料最高电压最大电流最大功率频率沟道电阻
2SB206GE-PNP80 V30 A80 W--
2SB324GE-PNP32 V1 A0,25 W--
2SB337GE-PNP50 V7 A30 W--
2SB407GE-PNP30 V7 A30 W--
2SB481GE-PNP32 V1 A6 W15 kHz-
2SB492GE-PNP25 V2 A6 W--
2SB511ESI-PNP35 V1,5 A10 W8 MHz-
2SB524SI-PNP60 V1,5 A10 W70 MHz-
2SB527SI-PNP110 V0,8 A10 W70 MHz-
2SB531SI-PNP90 V6 A50 W8 MHz-
2SB536SI-PNP130 V1,5 A20 W40 MHz-
2SB537SI-PNP130 V1,5 A20 W60 MHz-
2SB541SI-PNP110 V8 A80 W9 MHz-
2SB544SI-PNP25 V1 A0,9 W180 MHz-
2SB546ASI-PNP200 V2 A25 W5 MHz-
2SB549SI-PNP120 V0,8 A10 W80 MHz-
2SB557SI-PNP120 V8 A80 W--
2SB560SI-PNP100 V0,7 A0,9 W100 MHz-
2SB561SI-PNP25 V0,7 A0,5 W--
2SB564SI-PNP30 V1 A0,8 W--
2SB598SI-PNP25 V1 A0,5 W180 MHz-
2SB600SI-PNP200 V15 A200 W4 MHz-
2SB601P-DARL100 V5 A30 W--
2SB605SI-PNP60 V0,7 A0,8 W120 MHz-
2SB621SI-NPN25 V1,5 A0,6 W200 MHz-
2SB621ASI-NPN50 V1 A0,75 W200 MHz-
2SB631SI-PNP100 V1 A8 W--
2SB632SI-PNP25 V2 A10 W100 MHz-
2SB633SI-PNP100 V6 A40 W15 MHz-
2SB637SI-PNP50 V0,1 A0,3 W200 MHz-
2SB641SI-PNP30 V0,1 A-120 MHz-
2SB647SI-PNP120 V1 A0,9 W140 MHz-
2SB649ASI-PNP160 V1,5 A1 W140 MHz-
2SB656SI-PNP160 V12 A125 W20 MHz-
2SB673P-DARL+D100 V7 A40 W0,8 us-
2SB676P-DARL100 V4 A30 W0,15 us-
2SB681SI-NPN150 V12 A100 W13 MHz-
2SB688SI-PNP120 V8 A80 W10 MHz-
2SB700SI-PNP160 V12 A100 W--
2SB703SI-PNP100 V4 A40 W18 MHz-
2SB705SI-PNP140 V10 A120 W17 MHz-
2SB707SI-PNP80 V7 A40 W--
2SB709SI-PNP45 V0,1 A0,2 W80 MHz-
2SB716SI-PNP120 V0,05 A0,75 W--
2SB720SI-PNP200 V2 A25 W100 MHz-
2SB727P-DARL+D120 V6 A50 W--
2SB731SI-PNP60 V1 A10 W75 MHz-
2SB733SI-PNP20 V2 A1 W50 MHz-
2SB734SI-PNP60 V1 A1 W80 MHz-
2SB739SI-PNP16 V2 A0,9 W80 MHz-
2SB740SI-PNP70 V1 A0,9 W--
2SB744SI-PNP70 V3 A10 W45 MHz-
2SB750P-DARL+D60 V2 A35 W--
2SB753SI-PNP100 V7 A40 W0,4 us-
2SB764SI-PNP60 V1 A0,9 A150 MHz-
2SB765P-DARL+D120 V3 A30 W--
2SB766SI-PNP30 V1 A-200 MHz-
2SB772SI-PNP40 V3 A10 W80 MHz-
2SB774SI-PNP30 V0,1 A0,4 W150 MHz-
2SB775SI-PNP100 V6 A60 W13 MHz-
2SB776SI-PNP120 V7 A70 W15 MHz-
2SB788SI-PNP120 V0,02 A0,4 W150 MHz-
2SB791P-DARL+D120 V8 A40 W--
2SB794P-DARL+D60 V1,5 A10 W--
2SB795P-DARL+D80 V1,5 A10 W--
2SB808SI-PNP20 V0,7 A0,25 W250 MHz-
2SB810SI-PNP30 V0,7 A0,35 W160 MHz-
2SB815SI-PNP20 V0,7 A0,25 W250 MHz-
2SB816SI-PNP150 V8 A80 W15 MHz-
2SB817SI-PNP160 V12 A100 W--
2SB817FSI-PNP160 V12 A90 W15 MHz-
2SB819SI-PNP50 V1,5 A1 W150 MHz-
2SB822SI-PNP40 V2 A0,75 W100 MHz-
2SB824SI-PNP60 V5 A30 W30 MHz-
2SB825SI-PNP60 V7 A40 W10 MHz-
2SB826SI-PNP60 V12 A40 W10 MHz-
2SB827SI-PNP60 V7 A80 W10 MHz-
2SB828SI-PNP60 V12 A80 W10 MHz-
2SB829SI-PNP60 V15 A90 W20 MHz-
2SB857SI-PNP50 V4 A40 W--
2SB861SI-PNP200 V2 A30 W--
2SB863SI-PNP140 V10 A100 W15 MHz-
2SB865P-DARL80 V1,5 A0,9 W--
2SB873SI-PNP30 V5 A1 W120 MHz-
2SB882P-DARL+D70 V10 A40 W--
2SB883P-DARL+D70 V15 A70 W--
2SB884P-DARL110 V3 A30 W--
2SB885P-DARL+D110 V3 A35 W--
2SB891SI-PNP40 V2 A5 W100 MHz-
2SB892SI-PNP60 V2 A1 W--
2SB895AP-DARL60 V1 A--
2SB897P-DARL+D100 V10 A80 W--
2SB908P-DARL+D80 V4 A15 W0,15 us-
2SB909SI-PNP40 V1 A1 W150 MHz-
2SB922SI-PNP120 V12 A80 W20 MHz-
2SB926SI-PNP30 V2 A0,75 W--
2SB938AP-DARL+D60 V4 A40 W--
2SB940SI-PNP200 V2 A35 W30 MHz-
2SB941SI-PNP60 V3 A35 W--
2SB945SI-PNP130 V5 A40 W30 MHz-
2SB946SI-PNP130 V7 A40 W30 MHz-
2SB950AP-DARL+D80 V4 A40 W--
2SB953ASI-PNP50 V7 A30 W150 MHz-
2SB955P-DARL+D120 V10 A50 W--
2SB975P-DARL+D100 V8 A40 W--
2SB976SI-PNP27 V5 A0,75 W120 MHz-
2SB985SI-PNP60 V3 A1 W150 MHz-
2SB986SI-PNP60 V4 A10 W150 MHz-
2SB988SI-PNP60 V3 A30 W400 MHz-
2SB1009SI-PNP40 V2 A10 W100 MHz-
2SB1010SI-PNP40 V2 A0,75 W100 MHz-
2SB1012KP-DARL120 V1,5 A8 W--
2SB1013SI-PNP20 V2 A0,7 W--
2SB1015SI-PNP60 V3 A25 W0,4 us-
2SB1016SI-PNP100 V5 A30 W5 MHz-
2SB1017SI-PNP80 V4 A25 W9 MHz-
2SB1018SI-PNP100 V7 A30 W0,4 us-
2SB1020P-DARL+D100 V7 A30 W0,8 us-
2SB1023P-DARL+D60 V3 A20 W--
2SB1035SI-PNP30 V1 A0,9 W100 MHz-
2SB1039SI-PNP100 V4 A40 W20 MHz-
2SB1050SI-PNP30 V5 A1 W120 MHz-
2SB1055SI-PNP120 V6 A70 W20 MHz-
2SB1065SI-PNP60 V3 A10 W--
2SB1066SI-PNP50 V3 A1 W70 MHz-
2SB1068SI-PNP20 V2 A0,75 W180 MHz-
2SB1071SI-PNP40 V4 A25 W150 MHz-
2SB1077P-DARL60 V4 A40 W--
2SB1086SI-PNP160 V1,5 A20 W50 MHz-
2SB1098P-DARL+D100 V5 A20 W--
2SB1099P-DARL+D100 V8 A25 W--
2SB1100P-DARL+D100 V10 A30 W--
2SB1109SI-PNP160 V0,1 A1,25 W--
2SB1109SSI-PNP160 V0,1 A1,25 W--
2SB1117SI-PNP30 V3 A1 W280 MHz-
2SB1120SI-PNP20 V2,5 A0,5 W250 MHz-
2SB1121TSI-PNP30 V2 A-150 MHz-
2SB1123SI-PNP60 V2 A0,5 W150 MHz-
2SB1132SI-PNP40 V1 A0,5 W150 MHz-
2SB1133SI-PNP60 V3 A25 W40 MHz-
2SB1134SI-PNP60 V5 A25 W30 W-
2SB1135SI-PNP60 V7 A30 W10 MHz-
2SB1136SI-PNP60 V12 A30 W10 MHz-
2SB1140SI-PNP25 V5 A10 W320 MHz-
2SB1141SI-PNP20 V1,2 A10 W150 MHz-
2SB1143SI-PNP60 V4 A10 W140 MHz-
2SB1146P-DARL120 V6 A25 W--
2SB1149P-DARL100 V3 A15 W--
2SB1151SI-PNP60 V5 A20 W--
2SB1154SI-PNP130 V10 A70 W30 MHz-
2SB1156SI-PNP130 V20 A100 W--
2SB1162SI-PNP160 V12 A120 W--
2SB1163SI-PNP170 V15 A150 W--
2SB1166SI-PNP60 V8 A20 W130 MHz-
2SB1168SI-PNP120 V4 A20 W130 MHz-
2SB1182SI-PNP40 V2 A10 W100 MHz-
2SB1184SI-PNP60 V3 A15 W70 MHz-
2SB1185SI-PNP50 V3 A25 W70 MHz-
2SB1186SI-PNP120 V1,5 A20 W50 MHz-
2SB1187SI-PNP80 V3 A35 W--
2SB1188SI-PNP40 V2 A-100 MHz-
2SB1202SI-PNP60 V3 A15 W150 MHz-
2SB1203SI-PNP60 V5 A20 W130 MHz-
2SB1204SI-PNP60 V8 A20 W130 MHz-
2SB1205SI-PNP25 V5 A10 W320 MHz-
2SB1212SI-PNP160 V1,5 A0,9 W50 MHz-
2SB1223P-DARL+D70 V4 A20 W20 MHz-
2SB1236SI-PNP 打开APP阅读更多精彩内容
