常用的发射管数据2
电子常识
2686人已加入
ype: Vermogen: Spanning: Frequentie: Gain:
2SC2290  100 Watt 14 Volt 30 MHz
2SC2312 16 Watt 12 Volt 30 MHz 12dB
2SC2879 100 Watt 12,5 Volt 28 MHz 13dB
2N918 50mA 15 Volt 600 MHz
2N3553 2,5 Watt 28 Volt 175 MHz 10 dB
2N3866 1 Watt 28 Volt 400 MHz 10dB
ABH711585 35 Watt 13,5 Volt 108 MHz 10dB
BF964  30mA 20 Volt 200 MHz
BF966  30mA 20 Volt 800 MHz
BFG90a 180mW 15 Volt 5 GHz
BFG91 300mW 12 Volt 6 GHz
BFQ136 9 Watt 14 Volt 4 GHz 12,5dB
BFQ34 2,7 Watt 15 Volt 4 GHz 16,3dB
BFQ68 4,5 Watt 14 Volt 4 GHz 13dB
BFR94 3,5 Watt 25 Volt 3,5 GHz 10dB
BFW30 220mW 10 Volt 800 MHz
BGY22A 2,9 Watt 13,8 Volt 380-512 MHz
BGY33 22 Watt 12 Volt 108 MHz
BGY47H 3 Watt 9,6 Volt 400-470 MHz
BGY887  24 Volt 40-860 MHz 21,5 dB
BLF147 150 Watt 28 Volt 108 MHz 14dB
BLF177 150 Watt 50 Volt 108 MHz 19dB
BLF245 30 Watt 28 Volt 175 MHz >13dB
BLF246 80 Watt 28 Volt 108 MHz >16dB
BLF248 300 Watt 28 Volt 225 MHz >10dB
BLF368 300 Watt 32 Volt 225 MHz >12dB
BLF548 150 Watt 28 Volt 500 MHz 10dB
BLF861 150 Watt 32 Volt 860 MHz >13,5dB
BLF1047 70 Watt 26 Volt 1 GHz >14dB
BLF1820 65 Watt 26 Volt 2,4 GHz >11dB
BLF2045 30 Watt 26 Volt 2,4 GHz >10dB
BLF2057 60 Watt 26 Volt 2,4 GHz
BLU20/12 20 Watt 12,5 Volt 470 MHz >6,5dB
BLU45/12  45 Watt 12,5 Volt 470 MHz >4,8dB
BLU53  100 Watt 28 Volt 400 MHz
BLV21 15 Watt 28 Volt 175 MHz >10dB
BLV25 175 Watt 28 Volt 108 MHz >10dB
BLV32F 10 Watt 25 Volt 224 MHz >16dB
BLV33 90 Watt 28 Volt 224 MHz 7,5dB
BLV59 30 Watt 25 Volt 860 MHz >7dB
BLV80/28 80 Watt 28 Volt 175 MHz >6,5dB
BLV92 4 Watt 12,5 Volt 900 MHz >7,5dB
BLV93 8 Watt 12,5 Volt 900 MHz >6,5dB
BLV97 30 Watt 24 Volt 960 MHz >7dB
BLV102
BLV193 12 Watt 12,5 Volt 900 MHz >6,5dB
BLV862 150 Watt 28 Volt 860 MHz >8dB
BLV910 10 Watt 26 Volt 960 MHz >11dB
BLV950 150 Watt 26 Volt 900 MHz >8dB
BLV2047 60 Watt 26 Volt 2,4 GHz >9dB
BLW33 1 Watt 25 Volt 860 MHz >10dB
BLW34 2 Watt 25 Volt 860 MHz 10dB
BLW50 50 Watt 50 Volt 30 MHz >19,5dB
BLW76 80 Watt 28 Volt 108 MHz 7,9dB
BLW77 130 Watt 28 Volt 87,5 MHz 7,5dB
BLW81 10 Watt 12,5 Volt 470 MHz >6dB
BLW82 25 Watt 12,5 Volt 470 MHz 6,2dB
BLW82F 30 Watt 36 Volt 470 MHz
BLW86 45 Watt 28 Volt 175 MHz 7,5dB
BLW89 2 Watt 28 Volt 470 MHz >12dB
BLW90 4 Watt 28 Volt 470 MHz >11dB
BLW95 160 Watt 50 Volt 30 MHz >14dB
BLW96 200 Watt 50 Volt 108 MHz 6,5dB
BLW98 4,4 Watt 25 Volt 860 MHz 7dB
BLX15  175 Watt 50 Volt 108 MHz 7,4dB
BLY83 12 Watt  175 MHz
BLY87 8 Watt 13,5 Volt 175 MHz >12dB
BLY89 25 Watt 13,5 Volt 175 MHz >6dB
BLY91 8 Watt 28 Volt 175 MHz >12dB
BLY94 50 Watt 28 Volt 175 MHz >7dB
MHW720-3 20 Watt 12,5 Volt 512 MHz 21dB
MRF237 4 Watt 12,5 Volt 175 MHz 12dB
MRF245 80 Watt 12,5 Volt 175 MHz 6,4dB
MRF450A 50 Watt 13,6 Volt 30 MHz 11dB
MRF454 80 Watt 12,5 Volt 30 MHz 12dB
MRF455 60 Watt 12,5 Volt 30 MHz 13dB
MRF475 12 Watt 13,6 Volt 30 MHz 10dB
MRF477 40 Watt 12,5 Volt 30 MHz 15dB
SD1460 150 Watt 28 Volt 108 MHz 9,2dB
