各频段发射管参数大全
电子常识
2686人已加入
Character (Serial Code) 100-999 Device for consumer or entertainment use Y## Industrial service (No letter Z), ## is a W## Registration number from 10_99
Japanese Semiconductor Numbering System
    2 SC 82DA
    1 23 4  5
1) Kind of device, indicating the number of effective electrical
connections minus one
2) For a semiconductor registered with the EIAJ this letter is always an S
3) Third letter designates the polarity and application
  A PNP transistor, high-frequency
  B PNP transistor, low-frequency
  C NPN transistor, high-frequency
  D NPN transistor, low-frequency
  E P-gate thyristor
  F N-gate thyristor
  H N-base unijunction transistor
  J P-channel FET
  K N-channel FET
  M Bi-directional triode thyristor
4) These figures designate the order of application for EIAj registration,
starting with 11
5) This letter indicates the level of improvement. An improved device
may be used in place of a previous-generation device , but not
necessarily the other way around
Transistors sorted by using
         Output   Input          Typ Supply
         Power    Power   Gain    Voltage
Device    (W)      (W)    (dB)      (V)       Case      Mfr
1.5 to 30 MHz, HF SSB/CW
2SC2086   0.3       -      13        12       TO-92     MI
BLV10     1         -      18        12       SOT123    PH
BLV11     2         -      18        12       SOT123    PH
MRF476    3        0.1     15     12.5-13.6   221A-04/1 MO
BLW87     6         -      18        12       SOT123    PH
2SC2166   6         -      13.8      12       TO-220    MI
BLW83    10         -      20        26       SOT123    PH
MRF475   12        1.2     10     12.5-13.6   221A-04/1 MO
MRF433   12.5      0.125   20     12.5-13.6   211-07/1  MO
2SC3133  13         -      14        12       TO-220    MI
MRF485   15        1.5     10        28       221A-04/1 MO
2SC1969  16         -      12        12       TO-220    MI
BLW50F   16         -      19.5      45       SOT123    PH
MRF406   20        1.25    12     12.5-13.6   211-07/1  MO
SD1285   20        0.65    15        12.5     M113      SG
MRF426   25        0.16    22        28       211-07/1  MO
MRF427   25        0.4     18        50       211-07/1  MO
MRF477   40        1.25    15     12.5-13.6   211-11/1  MO
MRF466   40        1.25    15        28       211-07/1  MO
BLW96    50         -      19        40       SOT121    PH
2SC3241  75         -      12.3      12.5     TO-45E    MI
SD1405   75        3.8     13        12.5     M174      SG
2SC3241  75         -      12.3      13.5     TO-40E    MI
MRF464   80        2.53    10        28       211-11/1  MO
MRF421  100       10       10     12.5-13.6   211-11/1  MO
SD1405  100        7.9     11        12.5     M174      SG
2SC2904 100         -      11.5      12.5     TO-40E    MI
SD1729  130        8.2     12        28       M174      SG
MRF422  150       15       10        28       211-11/1  MO
MRF428  150        7.5     13        50       211-11/1  MO
SD1726  150        6       14        50       M174      SG
PT9790  150        4.8     15        50       211-11/1  MO
MRF448  250       15.7     12        50       211-11/1  MO
MRF430  600       60       10        50       368-02/1  MO
50 MHz
MRF475    4        0.4     10     12.5-13.6   211A-04/1 MO
MRF497   40        4       10     12.5-13.6   211A-04/1 MO
SD1446   70        7       10        12.5     M113      SG
MRF492   70        5.6     11     12.5-13.6   211-11/1  MO
SD1405  100       20        7        12.5     M174      SG
VHF to 175 MHz
2N4427    0.7       -       8         7.5     TO-39     PH
2N3866    1         -      10        28       TO-39     PH
BFQ42     1.5       -       8.4       7.5     TO-39     PH
2SC2056   1.6       -       9         7.2     TO-41     MI
2N3553    2.5      0.25    10        28       79-04/1   MO
BFQ43     3         -       9.4       7.5     TO-39     PH
SD1446    4        0.25    12        12.5     M135      SG
2SC2056   5         -      13        12.5     T-40      MI
2N6541    7        1        8.4      28       144B-05/1 MO
MRF340    8        0.4     13        28       221A-04/2 MO
BLW29     9         -       7.4       7.5     SOT120    PH
SD1143   10        1       10        12.5     M135      SG
2SC1729  14         -      10        13.5     T-31E     MI
SD1014-02 15       3.5     6.3       12.5     M135      SG
BLV11    15         -       8        13.5     SOT123    PH
2N6542   20        3        8.2      28       145A-09/1 MO
MRF342   24        1.9     11        28       221A-04/2 MO
BLW87    25         -       6        13.5     SOT123    PH
2SC1946  28         -       6.7      13.5     T-31E     MI
MRF314   30        3       10        28       221-07/1  MO
SD1018   40       14        4.5      12.5     M135      SG
2N5643   40        6.9      7.6      28       145A-09/1 MO
BLW40    40         -      10        12.5     SOT120    PH
MRF315   45        5.7      9        28       221-07/1  MO
TP9733   50       10        7        28       145A-09/1 MO
MRF344   60       15        6        28       221A-04/2 MO
2SC2964  70         -       6.7      12.5     T-40      MI
BLV75/12 75         -       6.5      12.5     SOT119    PH
MRF316   80        8       10        28       316-01/1  MO
SD1477  100       25        6        12.5     M111      SG
BLW78   100         -       6        28       SOT121    PH
MRF316  100       12.5      9        28       316-01/1  MO
TP9386  150       15       10        28       316-01/1  MO
220 MHz
MRF207    1        0.15     8.2      12.5     79-04/1   MO
MRF227    3        0.13    13.5      12.5     79-05/5   MO
MRF208   10        1       10        12.5     145A-09/1 MO
MRF226   13        1.6      9        12.5     145A-09/1 MO
2SC2133  30         -       8.2      28       T-40E     MI
2SC2134  60         -       7        28       T-40E     MI
2SC2609 100         -       6        28       T-40E     MI
UHF to 512 MHz
2N4427    0.4       -      10        12.5     TO-39     PH
2SC2133   0.5       -      14        12.5     T-43      MI
MRF581    0.6      0.03    13        12.5     317-01/2  MO
2SC2133   1         -       4        12.5     TO-39     MI
2SC2133   1.4       -       6.7      13.5     TO-39     MI
BLX65E    2         -       9        12.5     TO-39     PH
BLW89     2         -      12        28       SOT122    PH
MRF630    3        0.33     9.5      12.5     79-05/5   MO
2SC2133   3        0.3     10        12.5     TO-31E    MI
BLW80     4         -       8        12.5     SOT122    PH
BLW90     4         -      11        12.5     SOT122    PH
MRF652    5        0.5     10        12.5     244-04/1  MO
2SC3021   7        1.2      7.6      12.5     TO-31E    MI
BLW81    10         -       6        12.5     SOT122    PH
MRF653   10        2        7        12.5     244-04/1  MO
BLW90    10         -       9        28       SOT122    PH
MRF654   15        2.5      7.8      12.5     244-04/1  MO
2SC3022  18        6        4.7      12.5     TO-31E    MI
BLU20/12 20         -       6.5      12.5     SOT119    PH
BLX94A   25         -       6        28       SOT48/2   PH
2SC2695  28         -       4.9      13.5     TO-31E    MI
BLU30/12 30         -       6        12.5     SOT119    PH
BLU45/12 45         -       4.8      12.5     SOT119    PH
2SC2905  45         -       4.8      12.5     TO-40E    MI
MRF650   15       15.8      5        12.5     316-01/1  MO
TP5051   50        6        9        24       333A-02/2 MO
BLU60/12 60         -       4.4      12.5     SOT119    PH
2SC3102  60       20        4.8      12.5     TO-41E    MI
BLU60/28 60         -       7        28       SOT119    PH
MRF658   65       25        4.15     12.5     316-01/1  MO
MRF338   80       15        7.3      28       333-04/1  MO
SD1464  100       28.2      5.5      28       M168      SG
UHF to 960 MHz
MRF581    0.6      0.06    10        12.5     317-01/2  MO
MRF8372   0.75     0.11     8        12.5     751-04/1  MO
MRF557    1.5      0.23     8        12.5     317D-02/2 MO
BLV99     2         -       9        24       SOT172    PH
SD1420    2.1      0.27     9        24       M122      SG
MRF839    3        0.46     8        12.5     305A-01/1 MO
MRF896    3        0.3     10        24       305-01/1  MO
MRF891    5        0.63     9        24       319-06/2  MO
2SC2932   6         -       7.8      12.5     TO-31E    MI
SD1398    6        0.6     10        24       M142      SG
2SC2933  14        3        6.7      12.5     TO-31B    MI
SD1400-03 14       1.6      9.5      24       M118      SG
MRF873    15        3        7        12.5     319-06/2  MO
SD1495-03 30        6        7        24       M142      SG
SD1424    30        5.3      7.5      24       M156      SG
MRF897    30        3        10       24       315B-01/1 MO
MRF847    45       16        4.5      12.5     319-06/1  MO
BLV101A   50         -       8.5      26       SOT273    PH
SD1496-03 55       10        7.4      24       M142      SG
MRF898    60       12        7        24       333A-02/1 MO
MRF880    90       12.7      8.5      26       375A-01/1 MO
MRF899    150      24        8        26       375A-01/1 MO
Japanese transistors sorted by frequency
Device  Freq     Vcc   Pin   Pout   VceO
type    (MHZ)    (V)   (W)    (W)    (V)
2N5070  30      28.0   1.2   25.0*    30
2N2876  50      28.0   2.0   10.0     60
2N5025  50      13.5   3.5   20.0     75
2N5687  50      12.5          1.5     20
2N5688  50      12.5          5.0     20
2N5689  50      12.5         10.0     40
2N5690  50      12.5         25.0     30
2N5847  50      12.5    .8    8.0     18
2N5848  50      12.5         20.0     24
2N5993  66      12.5   1.0   18.0     18
2Nl5O6  70      28.0          1.3     20
2N4932  70      13.5   3.5   12.0     25
2N4933  70      24.0   3.5   20.0     35
2N5071  70      24.0   3.0   24.0     30
2N5026  80      28.0   2.5   25.0     90
2N5992  88      12.5    .5    7.0     30
2N5102  136     24.0   6.0   15.0     50
2N5994  136     12.5   1.0   15.0     30
2N5682  150     27.0  15.0   90.0    120
2N3553  175     28.0   .25    2.5     40
2N3632  175     28.0   3.5   13.5     40
2N3924  175     13.6   1.0    4.0     18
2N3926  175     13.6   2.0    7.0     18
2N3927  175     13.6   4.0   12.0     18
2N4127  175     25.0   2.5   13.5     40
2N4128  175     24.0   6.0   24.0     40
2N4427  175     12.0    .1    1.0     20
2N5421  175     13.5   .12    1.0     18
2N5422  175     13.5   .31    2.0     18
2N5423  175     13.5   1.2    5.0     18
2N5424  175     13.5   4.1   13.0     18
2N5589  175     13.6   4.5    3.0     18
2N5590  175     13.6   3.3   10.0     18
2N5591  175     13.6  10.0   25.0     18
2N5702  175     12.5          1.5     18
2N5703  175     12.5          3.0     18
2N5704  175     12.5         12.0     18
2N5705  175     12.5         25.0     18
2N5913  175     12.5    .1    2.0     14
2N5995  175     12.5   .75    7.0     14
2N5996  175      5.3   5.3   15.0     18
2N6080  175     12.5    .3    4.0     18
2N6081  175     12.5   3.0   15.0     18
2N6082  175     12.5   6.2   25.0     18
2N6083  175     12.5   7.8   30.0     18
2N5109  200     15.0    .1   1.26     20
2N5215  200     28.0   3.1   10.0     70
2N5643  200     28.0   7.0   40.0     35
2N5943  200     15.0                  30
2N3137  250     20.0    .1     .4     20
2N5642  250     28.0   3.0   20.0     35
2N5947  250     20.0                  30
2N4073  300     20.0   .25            20
2N5641  300     28.0   1.0    7.0     35
2N3375  400     28.0   1.0    3.0     40
2N3733  400     28.0   4.0   10.0     40
2N3966  400     28.0    .1   10.0     30
2N3948  400     13.6   1.0    5.0     20
2N4040  400     28.0   3.0    8.0     40
2N4041  400     28.0   1.0    3.3     40
2N4440  400     28.0   1.7    5.0     40
2N5016  400     28.0   5.0   15.0     30
2N5090  400     28.0    .2    1.2     30
2N5637  400     28.0   7.0   20.0     35
2N5773  400     26.0          1.5     35
2N5774  400     26.0          8.0     17
2N5775  400     26.0         20.0     35
2N5918  400     28.0   1.5   10.0     30
2N5919  400     28.0   4.0   ll.0     30
2N5636  450     28.0   2.0    7.5     35
2N5644  470     12.5   1.5    1.0     18
2N5645  470     12.5   1.0    4.0     18
2N5646  470     12.5   4.0   12.0     18
2N5697  470     12.5          .25     18
2N5698  470     12.5          1.0     18
2N5699  470     12.5          3.5     18
2N5700  470     12.5         11.0     18
2N5701  470     12.5         20.0     18
2N4440
2N4428  500     28.0   0.7    .75     35
2N5635  500     28.0    .6    2.5     35
2N4429  1000    28.0    .3    1.0     35
2N4430  1000    28.0    .8    2.5     40
2N4431  1000    28.0   1.5    5.0     40
2N5922  1000    28.0   3.2    1.0     35
2N5932  1000    28.0   .79    2.5     35
2N5108  1200    24.0   .32    1.0     55
2NS108A 1200    24.0    .1    1.26    55
  * DENOTES PEP
The following is a brief list of filters and Freq.
(+7dBm LO, up to +1dBm RF)
 Type           Fequency
                lo/rf          if
GRA-1           5-500         DC-500
GRA-3        .025-200         DC-200
GRA-6        .003-100         DC-100
GRA-8       .0005-10          DC-10
SRA-1           5-500         DC-500
SRA-1TX         5-500         DC-500
SRA-1W          1-750         DC-750
SRA1-1          1-500         DC-500
SRA-2           1-1000         5-500
SRA-2CM         5-1000        DC-1000
SRA-3        .025-200         DC-200
SRA-5           5-1500        10-600
SRA-6        .003-100         DC-100
SRA-8       .0005-10          DC-10
SRA-11          5-2000        10-600
SRA-12        800-1250        50-90
SRA-2000      100-2000        DC-600
SBL-1           1-500         DC-500
SBL-1X         10-1000         5-500
SBL-1Z         10-1000        DC-500
SBL-1-1       0.1-400         DC-400
SBL-3        0.25-200         DC-200
TAK-5        .01-250          DC-250
TAK-5R       .05-200          DC-200
TAK-6         .5-600          DC-600
TAK-6R        .5-600          DC-600
TAK-7          2-1000          5-500
GRA-1           5-500         DC-500
SRA-1           5-500         DC-500
SRA-1W          1-750         DC-750
SRA1-1          1-500         DC-500
SRA-2           1-1000         5-500
SRA-5           5-1500        10-600
SBL-1           1-500         DC-500
TAK-6         .5-600          DC-600
TAK-7          2-1000          5-500
UHF and SHF gasfet data
 Type       Freq         Gain dB     NF dB         Idss          Gates
MGF1302      4.0GHz      11.0        1.4           50mA          1
MGF1402      4.0GHz      13.0        1.1           50mA          1
MGF0904A     2.5GHz      28.0          vds 8v                    1
MGF0905A     2.5GHz      38.0          vds 8v                    1
MGF0906A     2.5GHz      37.0          vds 10v                   1
MGF0907A     2.5GHz      40.0          vds 10v                   1
MFG1100      4.0GHz      12.0        2.5                         2
MGF1202      4.0GHz       8.0        1.4       osc up to 55GHz   1
MGF1203      4.0GHz      13.0        1.0                         1
MGF1302      4.0GHz      11.0        1.4                         1
MGF1303     12.0GHz       8.0        2.0                         1
MGF1304     12.0GHz       8.0        1.7                         1
MGF1305     12.0GHz       8.0        1.6                         1
MGF1402      4.0GHz      13.0        1.1  (2SK274) osc @ 70GHz   1
MGF1412      4.0GHz      13.0        0.8  (2SK275) osc @ 70GHz   1
MGF1403     12.0GHz      10.5        1.8  (2SK276) osc @ 90GHz   1
MGF1404     12.0GHz      10.5        1.6                         1
MGF1405     12.0GHz      10.5        1.4                         1
MGF1425     12.0GHz      10.5        1.4                         1
MGF3000     12.0GHz      12.0         S to KU band mixer         1
MGF1601      8.0GHz       8.0        150mW @ 8GHz low power amp  1
MGF1801    fmAx 45GHz 9dB @ 8GHz 200mW medium power (2SK279)     1
MGF1802    C to X band amp 1.5w power amp                        1
MGF2116    0.4W @ 12GHz  linear    7dB@12GHz                     1
MGF2117    0.4W @ 12GHz  linear    7dB@12GHz                     1
MGF2124      1W @ 12GHz  linear    6dB@12GHz                     1
MGF2124F   0.7W @ 14GHz  linear   5.5dB@14GHz                    1
MFG2124G   O.7W @ 14GHz  linear   5.5dB@14GHz                    1
MGF2148    1.6W @ 12GHz  linear     5dB@12GHz                    1
MGF2148F   1.2W @ 14GHz  linear   4.7dB@14GHz                    1
MFG2148G   1.2W @ 14GHz  linear   4.7dB@14GHz                    1
MGF2172    2.5W @  8GHz  linear   5.5dB@8GHz                     1
MGF2205    3.0W @  6GHz  linear   6.5dB@6GHz                     1
MGF2312    0.3W @ 14GHz  linear     6dB@14GHz                    1
MGF2324    0.6W @ 14GHz  linear   5.5dB@14GHz                    1
MGF2336    0.9W @ 14GHz  linear     5dB@14GHz                    1
MGF-X34M   2.3W @ 10GHz  linear     6dB@10GHz                    1
MGF-K30M   1.1W @ 14.5GHz linear  6.5dB@14.5GHz                  1
MGF-K33M   2.0W @ 14.5GHz linear    6dB@14.5GHz                  1
NE25137      1.0GHz      16.0        1.2           20mA          2
NE25139      1.0GHz      17.0        1.1           20mA          2
AFT10135     4.0GHz      13.0        0.5           100mA         1
AFT10236     4.0GHz      20.0        0.8           130mA         1
AFT10736     4.0GHz      20.0        1.3           140mA         1
AFT13136    12.0GHz       9.5        1.2           50mA          1
AFT13284     4.0GHz      15.0        0.7           50mA          1
AFT13484    12.0GHz       7.5        2.0           50mA          1
AFT13786    10.0GHz      16.5        osc           70mA          1
AFT20135     4.0GHz      12.0        1.1           100mA         1
AFT21186     2.0GHz      19.0        0.6           120mA         1
AFT26884    12.0GHz      18.0        2.2           50mA          1
AFT13036    12.0GHz      17.5        1.1           50mA          1
AFT13336    12.0GHz      17.5        1.4           50mA          1
AFT35076    12.0GHz      10.0        0.75          50mA          1
AFT35376    12.0GHz      10.0        1.0           50mA          1
AFT46101     4.0GHz      27.0                      330mA         1
AFT45101     4.0GHz      29.0                      600mA         1
AFT44101     4.0GHz      32.0                      130mA         1
Some brief data on hf devices 2-30 MHz
 Type       P [W]    Supply      Type       P [W]     Supply
MRF401      25       12V        MRF455      60        12V
MRF406      20       12V        MRF455A     60        12V
MRF412      80       12V        MRF458      80        12V
MRF412A     80       12V        MRF460      60        12V
MRF421      100      12V        MRF464      80        28V
MRF422      150      28V        MRF466      40        28V
MRF426      25       12V        MRF475      12        12V
MRF426A     25       12V        MRF476      3         12V
MRF427      25       50V        MRF477      40        12V
MRF428      150      50V        MRF479      15        12V
MRF429      150      50V        MRF485      15        28V
MRF433      12       12V        MRF492      90        12V
MRF435      150      28V        MRF492A     90        12V
MRF448      250      50V        PT9847      100       12V
MRF449      30       12V        SD1405      75        12V
MRF449A     30       12V        SD1407      100       28V
MRF450      50       12V        SD1452      80        12V
MRF450A     50       12V        2SC2290     80        12V
MRF453      60       12V        2SC2879     120       12V
MRF453A     60       12V        2SC2509     15        12V
MRF454      80       12V        2SC2097     85        12V
MRF454A     80       12V
SRF2072     65       12V        SRF3662     120        12V
SRF3775     75       12V        SRF3795     90         12V
SRF3800     110      12V
MRF454A     80       12V
SRF3800     110      12V
Some linear ic's and their function
 Type       Function
ADCO84      A-D converter
AN829       Dual attenuator
BDM1        Balanced mixer
CX7932      Delay circuit
MF10CN      Audio filter
4N25        Opto coupler
78S40       Dual baud rate generator
SO41P       Low power FM discriminator
SO42P       High level mixer
TL061       Low power fet op-amp
TL062       Dual version of TL061
TL064       Fet quad op-amp
TL071       Fet op-amp
TL072       Dual fet op-amp
TL074       QUAD fet op-amp
TL081       JFET op-amp
TL082       Dual jfet op-amp
TL084       Quad jfet op-amp
TBA120s     TV sound if fm
DG202CJ     SPST Analogue switch
mAX232      RS232 interface
MB3756      Stabilized power ic
MC3859      FM IF
DG300ACJ    Analogue switch
LM301       Op-amp
DG308ACJ    Quad analogue switch
M51304L     Mic amp
MB501       Divide by 64/65/127/128
MB501L      Surface mount version of MB501
MC145146P   PLL
NE542       Op-amp low noise
NE544       Servo driver
SL560C      Wide band amp
NE564       PLL FM
NE565       Low freq PLL
NE566       LF VCO/Generator
LM567       Tone decoder
NE570       Compander ie compression/expander
LM571       As NE570
NE592       Video amp
MV601       Infra red device
NE602AN     Mixer/osc
NE607       FM IF
PB571C      Prescaler
SL610       RF/IF amp
TA7230P     AF power amp 4w
TC4050      Buffer converter
TC5027      Counter
TC5036      Divider
Transistors parameters
2-30 MHz SSB Transistors
 type        Pin [W]    Pout [W]   Supply    Gain
MRF476       0.1        3.0 pep    12V       15dB
2N6367       0.36       9.0        12V       14dB
MRF475       1.2        12.0       12V       10dB
MRF432       0.125      12.5       12V       20dB
MRF433       0.125      12.5       12V       20dB
MRF406       1.25       20         12V       12dB
MRF460       2.5        40         12V       12dB
MRF421       10         100        12V       10dB
2N6370       0.62       10         28V       12dB
MFR432       0.125      12.4       12V       20dB
2N5070       1.25       25         28V       13dB
MRF401       1.25       25         28V       13dB
MRF427A      1.56       25         50V       13dB
2N5941       2.0        40         28V       13dB
MRF463       2.53       80         28V       15dB
MRF464       2.53       80         28V       15dB
MRF464A      2.53       80         28V       15dB
MRF422       15         150        28V       10dB
MRF428       7.5        150        50V       13dB
MRF428A      7.5        150        50V       13dB
14-30 amateur Transistors
MRF8003      0.025      0.5        12V       13dB
MRF8004      0.35       3.5        12V       10dB
MRF449       0.30       30         13.6V     10dB
MRF449A      0.30       30         13.6V     10dB
MRF450       4.0        50         13.6V     10dB
MRF450A      4.0        50         13.6V     11dB
MRF453       4.8        60         13.6V     11dB
MRF453A      4.8        60         13.6V     11dB
MRF455       4.8        60         13.6V     11dB
MRF455A      4.8        60         13.6V     11dB
MRF454       5.0        80         12.5V     12dB
MRF454A      5.0        80         12.5V     12dB
130-175 VHF FM Transistors
MRF604A      0.1        1.0        12V       10dB
2N4427       0.1        1.0        12V       10dB
MRF607       0.1        1.75       12V       12.5dB
2N6255       0.5        3.0        12V       7.8dB
2N5589       0.44       3.0        13.6V     8.2dB
MRF237       0.25       4.0        13.6V     12dB
2N6080       0.25       4.0        12V       12dB
2N5590       3.0        10         12V       5.2dB
MRF212       1.25       10         12.5V     9dB
2N6081       3.3        15         12V       6.3dB
MRF221       3.3        15         12V       6.3dB
MRF215       0.33       20         12V       8.2dB
2N5591       9.0        25         13.6V     4.4dB
2N6082       6.0        25         12V       6.2dB
MRF222       6.0        25         12V       6.2dB
2N6083       8.1        30         12V       5.7dB
MRF223       8.1        30         12.5V     5.7dB
2N6084       14.3       40         12.5V     4.5dB
MRF224       14.3       40         12.5V     4.5dB
MRF216       8.5        40         12.5V     6.7dB
MRF243       12.0       60         12.5V     7.0dB
MRF245       18.2       80         12.5V     6.4dB
Information on MMIC Amplifiers
 Type      Gain @ 1GHz  Noise dB    P dBm
MAR-1      15.0         6.0         1.5
MAR-2      12.0         6.5         4.5
MAR-3      12.0         6.0        10.0
MAR-4       8.0         7.0        12.5
MAR-5       7.0         6.5        18.0
MAR-6      16.5         3.2         1.5
MAR-7      12.5         5.0         5.5
MAR-8      22.5         3.3        12.5
MAR-0311   12.0         6.0        10.0
MAR-0611   16.5         3.2         1.5
MAR-0711   12.5         5.0         5.5
 Type    Freq               PL(W)    Supply   Case
BFQ42    VHF     175MHz     2        12.5w    TO-39
BFQ43    VHF     175MHz     4        12.5     TO-39 e case
BFS22A   HF/VHF  175MHz     4        12.5     TO-39
BFS23A   HF/VHF  175MHz     4        28       TO-39
BGY21    UHF     420-470    1.2      12       Module
BGY22    UHF     380-512    2.5      13.5     Module
BGY22A   UHF     420-480    2.5      12.5     Module
BGY23    UHF     380-512    7        13.5     Module
BGY23A   UHF     420-480    7        12.5     Module
BGY32    VHF     68-88      18       12.5     Module
BGY33    VHF     88-108     18       12.5     Module
BGY35    VHF     132-156    18       12.5     Module
BGY36    VHF     148-174    18       12.5     Module
BLV10    HF/VHF  175        8        12.5     SOT123
BLV11    HF/VHF  175        15       12.5     SOT123
BLV20    HF/VHF  175        8        28       SOT123
BLV21    HF/VHF  175        15       28       SOT123
BLW29    VHF     175        15       12.5     SOT120
BLW31    VHF     175        28       12.5     SOT120
BLW32    BAND4/5 860        .5*      25       SOT122
BLW33    BAND4/5 860         1*      25       SOT122
BLW34    BAND4/5 860         2*      25       SOT122
BLW60    HF/VHF  28/175    30pep     12.5     SOT56
BLW60C   HF/VHF  28/175    30pep     12.5     SOT120
BLW64    BAND/3  220        10*      25       SOT56
BLW75    BAND/3  220        14*      25       SOT105
BLW76    HF/VHF  28/108    80pep     28       SOT121
BLW77    HF/VHF  28/87.5   130pep    28       SOT121
BLW78    HF/VHF  28/150    100pep    28       SOT121
BLW79   VHF/UHF 175/470    2         12.5     SOT122
BLW80   VHF/UHF 175/470    4         12.5     SOT122
BLW81   VHF/UHF 175/470    10        12.5     SOT122
BLW82   UHF      470       30        12.5     SOT119
BLW83   HF        28       30pep     28       SOT123
BLW84   VHF      175       25        28       SOT123
BLW85   HF/VHF  28/175     30pep     12.5     SOT123
BLW86   HF/VHF  28/175     45pep     28       SOT123
BLW87   HF/VHF  175        25        12.5     SOT123
BLW98   BAND4/5 860        3.5*      25       SOT122
BLX13   HF      28         25pep     28       SOT56
BLX13C  HF      28         25pep     28       SOT120
BLX14   HF      28         50pep     28       SOT56
BLX15   HF/VHF  28/108     150pep    50       SOT56
BLX39   HF/VHF  28/175     42.5pep   28       SOT120
BLX65   VHF/UHF 175/470    2         12.5     TO-39
BLX66   VHF/UHF 175/470    2.5       12.5     SOT48/4
BLX67   VHF/UHF 175/470    2.5       12.5     SOT48/3
BLX68   VHF/UHF 175/470    7         12.5     SOT48/3
BLX69A  VHF/UHF 175/470    17        12.5     SOT48/2
BLX91A  UHF     470        1         28       SOT48/3
BLX92A  UHF     470        2.5       28       SOT48/3
BLX93A  UHF     470        7         28       SOT48/3
BLX94A  UHF     470        25        28       SOT48/2
BLX95   UHF     470        40        28       SOT56
BLX96   BAND4/5 860        .5*       25       SOT48/3
BLX97   BAND4/5 860        1*        25       SOT48/3
BLX98   BAND4/5 860        3.5*      25       SOT48/2
BLY33   VHF     175        3         28       TO-39
BLY34   VHF     175        3         13.8     TO-39
BLY35   VHF     175        13        24       TO-60
BLY36   VHF     175        13        13.8     TO-60
  * = Pk sync
Microwave Transistors for amateur use
 Type      Muf      Gain dB  Noise dB
AT00511    2.7GHz   12.5     1.8
AT41411    3.5GHz   16.5     1.4
AT41511    4.0GHz   16.5     1.4
AT41486    4.0GHz   17.5     1.4
AT01635    2.2GHz   22.0     3.0
AT42086    3.5GHz   17.0     1.4
AT60585    4.0GHz   17.0     1.4
AT60111    1.9GHz   11.5     1.4
AT60211    2.1GHz   14.0     1.5
INA02186   1.0GHz   30.0     1.8
INA03184   2.4GHz   25.0     2.6
INA10386   2.4GHz   25.0     3.8
VHF/UHF brief data
 Type     P    Freq      Gain dB    Type     P      Freq       Gain dB
MRF207    1    225MHz    8.2       MRF627    0.5    512MHz     10.0
MRF208    10   225MHz    10        MRF629    2      512MHz     8.0
MRF212    10   174MHz    9         MRF630    3      512MHz     9.5
MRF220    4    174MHz    12        MRF641    15     512MHz     7.8
MRF221    15   175MHz    6.3       MRF644    25     512MHz     6.2
MRF222    25   175MHz    n/k       MRF646    40     512MHz     4.8
MRF224    40   175MHz    4.5       MRF648    60     512MHz     4.4
MRF226    13   225MHz    9.0       MRF652    5      512MHz     10.0
MRF227    3    225MHz    13.5      MRF653    10     512MHz     7.0
MRF229    1.5  88MHz     10.0      MRF654    15     512MHz     7.8
MRF231    3.5  88MHz     10.0      MRF660    7      512MHz     5.4
MRF233    15   88MHz     10.0      MRF752    2.5    512MHz     8.0
MRF234    25   88MHz     9.5       MRF754    8      512MHz     6.0
MRF237    4    174MHz    12.0      MRF843    15     960MHz     7.0
MRF238    30   174MHz    9.0       MRF843F   15     960MHz     7.0
MRF239    30   174MHz    10.0      MRF846    40     960MHz     7.0
MRF240    40   174MHz    9.0       MRF873    15     960MHz     7.0
MRF240A   40   174MHz    9.0       MRF1946   30     174MHz     10.0
MRF245    80   174MHz    6.4       MRF1946A  30     174MHz     10.0
MRF247    75   174MHz    7.0       MRF2628   15     225MHz     12.0
MRF248    80   174MHz    11.3      SD1278-1  40     174MHz     8.0
MRF250    50   174MHz    4.4       2N3553*   2.5    174MHz     10.0
MRF260    5    174MHz    10.0      2N3866*   1      400MHz     10.0
MRF261    10   174MHz    5.2       2N4427    1      174MHz     10.0
MRF262    15   174MHz    6.3       2N5090    2      174MHz     13.0
MRF264    30   174MHz    5.2       2N5589    3      174MHz     8.2
MRF309*   50   400MHz    7.0       2N5590    10     174MHz     5.2
MRF314*   30   200MHz    10.0      2N5591    25     174MHz     4.4
MRF314A*  30   200MHz    10.0      2N5641*   7      174MHz     8.4
MRF315*   45   200MHz    9.0       2N5642*   20     200MHz     8.2
MRF315A*  45   200MHz    9.0       2N5643*   40     200MHz     7.6
MRF316*   80   200MHz    10.0      2N5646    10     512MHz     6.0
MRF317*   100  200MHz    9.0       2N5944    2.0    512MHz     9.0
MRF321*   10   500MHz    12.0      2N5945    4      512MHz     8.0
MRF327*   80   400MHz    7.3       2N5946    10     512MHz     6.0
MRF340*   8    200MHz    13.0      2N6080    4      174MHz     12.0
MRF492    70   50MHz     11.0      2N6081    15     174MHz     6.3
MRF497    40   50MHz     10.0      2N6082    25     174MHz     6.2
MRF515    0.75 512MHz    8.0       2N6083    30     174MHz     5.7
MRF555    1.5  512MHz    10.0      2N6084    40     174MHz     4.5
MRF557    1.5  960MHz    8.0       2N6097PNP 40     174MHz     n/k
MRF559    0.5  960MHz    8.0       2N6255    3      174MHz     7.8
MRF607    1.75 174MHz    11.5
     * =  28v  device
Mosfets
Power mosfets N-channel 1.5-30MHz
 Type      P out (W)   Pin (W)     Gain dB     Supply
MRF138     30          0.6         17          28V
MRF140     150         4.7         15          28V
MRF148     30          0.5         18          50V
MRF150     150         2.9         17          50V
MRF153     300         6.0         17          50V
MRF154     600         12          17          50V
MRF156     600         6.0         20          50V
Power mosfets AM/FM 2.0-150MHz
 Type      P out (W)   P in (W)    Gain dB     Supply
MRF134     5.0         0.4         11          28V
MRF136     15          0.75        13          28V
MRF136Y    30          1.9         12          28V
MRF137     30          1.9         12          28V
MRF141G    300         13          14          28V
MRF151G    600         5           17          50V
MRF171     45          2.8         12          28V
MRF172     80          8.0         10          28V
MRF174     125         15.8        9           28V
MRF175GV   200         8.0         14          28V
Power mosfets UHF 2-400MHz
 Type      P out(w)    P in (W)    Gain dB     Supply
MRF161     5.0         0.4         11          28V
MRF162     15          1.2         11          28V
MRF163     25          2.5         10          28V
MRF175GU   150         9.5         12          28V
Power Modules
VHH-UHF Power Modules pt1
 Type       Freq        P in       P out(W)  Class
PF0011      860-920      3mW       13        AB
SAU11       902-905     200mW      8         C
SAU12       870-915      1mW       8         C
SAU16H      450-470     150mW      5         AB
SAU16SH     490-512     150mW      5         AB
SAU17       870-915      1mW       8         C
SAU27AH(H)  490-512     200mW      32        n/k
SAU27M      450-490     200mW      32        n/k
SAV6        154-162     200mW      28        C
SAV7        144-148     200mW      28        C
SAV12       144-148     150mW      5         AB
SAV15       220-225     200mW      30        C
SAV16H      150-160     150mW      5         n/k
SAV16L      135-150     150mW      5         n/k
SAV16SH     174         150mW      5         n/k
SAV17       144-148     400mW      50        C
SAV22A      144-148     15mW       7         C
SAV24       144-148     400mW      50        C
BGY45B      148-175     150mW      28        C
K43         898-941     300mW      13        C
M57704EL    335-360     200mW      13        C
M57704L     400-420     200mW      13        C
M57704M     430-450     200mW      13        C
M57704H     450-470     200mW      13        C
M57704SH    490-512     200mW      13        C
M57704UH    470-490     200mW      13        C
M57706L     135-145     Gain 16dB  8         C
M57706      145-175     200mW      8         C
M57710A     156-160     200mW      25        C
M57713      144-148     200mW      10        AB
M57714      450-470     100mW      7         C
M57714EL    335-360     100mW      7         C
M57714M     430-450     100mW      7         C
M57714UH    470-490     100mW      7         C
M47715      144-148     200mW      10        C
M57716      430-450     200mW      10        AB
M57719      145-175     200mW      17        C
M57719N     142-163     200mW      10        C
M57719L     135-145     Gain 19dB  14        C
M57721M     400-450     10mW       7         n/k
M57726      144-146     200mW      40        C
M57726R     144-148     400mW      43        C
M57727      144-148     200mW      25        AB
M57729      430-450     600mW      30        C
M57729EL    335-360     200mW      30        C
M57729H     450-470     600mW      30        C
M57729SH    490-512     300mW      30        C
M57732      144-175     20mW       7         AB
M57732L     135-160     20mW       5         AB
M57735      50-54       200mW      10        AB
M47737      144-148     200mW      25        C
M57737R     144-148     200mW      25        C
M57739C     824-849     30mW       6         C
M57741L     148-160     200mW      25        C
M57741M     156-168     250mW      25        C
M57741H     164-175     300mW      25        C
M57744      905-915     400mW      13        C
M57745      430-450     300mW      25        AB
M57747      144-148     200mW      10        C
M57755      806-866     100mW      10        C
M57759      890-915     2mW        200mW     n/k
M57762      1240-1300   1000mW     20        AB
M57764      800-830     400mW      15        C
M57774      220-225     300mW      30        C
M57782      825-851     1mW        7         n/k
M57783L     135-160     50mW       7         AB
VHF-UHF Power modules pt2
M57785L     135-150     50mW       7         AB
M57785M     150-162     50mW       7         AB
M57785H     162-174     50mW       7         AB
M57786M     430-470     2mW        7         AB
M57787      1240-1300   10mW       3         C
M57788H     450-470     400mW      45        C
M57788L     400-430     400mW      45        C
M57788M     430-450     400mW      45        C
M57788MR    430-450     400mW      45        C
M57791      890-915     1mW        7         n/k
M57792      806-870     400mW      20        n/k
M57796H     150-175     300mW      7         AB
M57796mA    144-148     200mW      7         AB
M57797H     450-470     200mW      7         AB
M57797mA    440-450     100mW      7         AB
M67702      150-175      5W        60        n/k
M67703H     450-470     10W        50        C
M67703SH    490-512     10W        50        C
M67703UH    470-490     10W        50        C
M67705L     400-430     20mW       7         AB
M67705M     430-470     20mW       7         AB
M67705H     470-512     20mW       7         AB
M67709      430-470     10mW       13        C
M67709L     350-390     10mW       13        C
M67709SH    490-512     10mW       13        C
M67710H     150-175     50mW       7         n/k
M67711      1240-1300   1000mW     16        AB
M67712      220-225     200mW      30        AB
M67715      1240-1300   10mW       1.5       AB
M67723      220-225     20mW       7         n/k
M67727      144-148     500mW      65        AB
M67728      430-450     14W        65        AB
M67730L     175-200     300mW      30        C
M67736      935-941     5mW        15        n/k
M67742      68-88       500mW      30        C
M67743H     77-88       30mW       7         AB
M67743L     68-81       30mW       7         n/k
M67748H     150-175     20mW       7         n/k
M67748L     144-148     20mW       7         n/k
M67748LR    135-150     20mW       7         n/k
M67749M     430-450     20mW       7         AB
M67749MR    430-450     20mW       7         AB
M67754      824-849     1mW        6         n/k
M67755H     150-175     2mW        7         n/k
M67755L     134-150     2mW        7         n/k
M67760L     806-870     400mW      25        n/k
M67764      940-960     7mW        12        n/k
M67766A     820-850     4mW        10        AB
M67769C     890-915     1mW        15        AB
M67776H     896-941     4mW        8         n/k
M67776L     806-870     4mW        8         n/k
M67785H     160-230     30mW       7         AB
M67796      1240-1300   10mW       1.5       n/kCharacter (Serial Code) 100-999 Device for consumer or entertainment use Y## Industrial service (No letter Z), ## is a W## Registration number from 10_99
    2 SC 82DA
    1 23 4  5
  E P-gate thyristor
  F N-gate thyristor
  J P-channel FET
  K N-channel FET
starting with 11
50 MHz
VHF to 175 MHz
220 MHz
UHF to 512 MHz
UHF to 960 MHz
2N5943  200     15.0                  30
2N5947  250     20.0                  30
2N4440
  * DENOTES PEP
 Type           Fequency
                lo/rf          if
GRA-1           5-500         DC-500
SRA-1           5-500         DC-500
SRA-1W          1-750         DC-750
SRA1-1          1-500         DC-500
SRA-2           1-1000         5-500
SRA-5           5-1500        10-600
SBL-1           1-500         DC-500
TAK-6         .5-600          DC-600
TAK-7          2-1000          5-500
GRA-1           5-500         DC-500
SRA-1           5-500         DC-500
SRA-1W          1-750         DC-750
SRA1-1          1-500         DC-500
SRA-2           1-1000         5-500
SRA-5           5-1500        10-600
SBL-1           1-500         DC-500
TAK-6         .5-600          DC-600
TAK-7          2-1000          5-500
MRF454A     80       12V
SRF3800     110      12V
MRF454A     80       12V
SRF3800     110      12V
 Type       Function
BDM1        Balanced mixer
MF10CN      Audio filter
4N25        Opto coupler
TL071       Fet op-amp
TL081       JFET op-amp
MC3859      FM IF
LM301       Op-amp
M51304L     Mic amp
MC145146P   PLL
NE544       Servo driver
NE564       PLL FM
NE565       Low freq PLL
LM567       Tone decoder
LM571       As NE570
NE592       Video amp
NE602AN     Mixer/osc
NE607       FM IF
PB571C      Prescaler
SL610       RF/IF amp
TC5027      Counter
TC5036      Divider
MAR-1      15.0         6.0         1.5
MAR-2      12.0         6.5         4.5
MAR-3      12.0         6.0        10.0
MAR-4       8.0         7.0        12.5
MAR-5       7.0         6.5        18.0
MAR-6      16.5         3.2         1.5
MAR-7      12.5         5.0         5.5
MAR-8      22.5         3.3        12.5
  * = Pk sync
VHF/UHF brief data
     * =  28v  device
Mosfets
Power Modules
