索尼KV-K29MHll型图像右移数厘米
电视机
54人已加入
    机器工作时,图像向右移出屏幕数厘米。该故障可能发生在VC总线控制及相关电路。检修时,打开机盖,待故障出现时,让机器进入维修状态,行幅位移可调,说明该机数据传送、执行数据单元都基本正常,怀疑问题出现在H——SHIFT锁定环节系统。该电路由IC304(CXAl587S)及外围电路组成,用万用表测IC304相关引脚电压基本正常,但用示波器测(8)脚平衡相位波形时,发现脉冲波形有跳跃迹象。检查IC304的(8)脚外围接有相位二极管D57,电阻R590,通道电容C588,经检测为D57内部损坏。更换D57后,机器工作恢复正常。
评论(0)
发评论
qdznkj1815 2022-08-22
0 回复 举报
http://house.china.com.cn/sousou/%25C9%25CF%25CF%25C2%25B7%25D6%252C%2B%25C3%25E5%25B5%25E9%25B5%25CF%25CD%25FE%25B6%25B7%25C5%25A3B2024.cN%252C%25B9%25F3%25D1%25F4%25B1%25CF%25D2%25B5%25C9%25FA_2s.htm http://house.china.com.cn/sousou/%25D6%25B1%25D3%25AA%25CD%25F8%252C%2B%25B9%25FB%25B8%25D2%25BB%25B7%25C7%25F2%25B9%25FA%25BC%25CA%25B9%25AB%25CB%25BEB2024.cN%252C%25C3%25AF%25C3%25FB%25CD%25F8%25BA%25EC_1s.htm http://house.china.com.cn/sousou/%25BA%25F3%25CC%25A8%252C%2B%25C3%25E5%25B5%25E9%25C5%25B7%25D1%25C7%25B9%25FA%25BC%25CA%25B6%25B7%25C5%25A3B2024.cN_1s.htm http://house.china.com.cn/sousou/%25CA%25D6%25BB%25FAAPP%252C%2B%25B9%25FB%25B8%25D2%25B0%25EB%25C9%25BD%25D3%25E9%25C0%25D6%25B9%25AB%25CB%25BEB2024.cN_29s.htm http://house.china.com.cn/sousou/%25D4%25DA%25CF%25DF%25BF%25CD%25B7%25FE%252C%2B%25C1%25FA%25CC%25DA%25D3%25E9%25C0%25D6%25B3%25C7B2024.cN%252C%25B3%25FC%25D6%25DD%25D2%25C6%25B6%25AF_2s.htm 收起回复
