电子钟VHDL设计
电子常识
2686人已加入
电子钟VHDL设计
电子钟VHDL设计
标签/分类:
1.系统设计要求
   (1)具有时、分、秒计数显示功能,小时为24进制,分钟和秒为60进制。
  (2)可以根据需要设置复位、清零、置位等功能。
2.系统设计方案概述
   根据系统设计要求,系统设计采用自顶向下设计方法,由秒计数模块、分计数模块、时计数模块、时间设置模块和译码模块五部分组成。
3.参考VHDL源程序
  (1)秒计数模块的VHDL源程序(second.vhd)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity second is
  port(clk,reset,semin:in std_logic;
        enmin:out std_logic;
        daout:out std_logic_vector(6 downto 0));
end second;
architecture rtl of second is
    signal count:std_logic_vector(6 downto 0);
    signal enmin_1,enmin_2:std_logic;
    begin
      daout<=count;
      enmin_2<=(semin and clk);
      enmin<=(enmin_1 or enmin_2);
      process(clk,reset,semin)
         begin
           if(reset='0')then
              count<="0000000";
              enmin_1<='0';
           elsif(clk'event and clk='1')then
              if(count(3 downto 0)="1001"screen.width/2)this.style.width=screen.width/2;" border=0>then
                 if(count<16#60#)then
                     if(count="1011001"screen.width/2)this.style.width=screen.width/2;" border=0>then
                        enmin_1<='1';count<="0000000";
                     else
                         count<=count+7;
                     end if;
                 else
                    count<="0000000";
                 end if;
              elsif(count<16#60#)then
                 count<=count+1;
                 enmin_1<='0';
              else
                 count<="0000000";enmin_1<='0';
              end if;
           end if;
       end process;
 end rtl;
仿真:
(2)分计数模块VHDL程序(minute.vhd)
library ieee;
entity minute is
  port(clk,reset,clks,sethour:in std_logic;
        enhour:out std_logic;
end minute;
architecture rtl of minute is
    signal enhour_1,enhour_2:std_logic;
    begin
      daout<=count;
      enhour_2<=(sethour and clk);
      enhour<=(enhour_1 or enhour_2);
      process(clk,reset,sethour)
         begin
           if(reset='0')then
              count<="0000000";
              enhour_1<='0';
                        enhour_1<='1';count<="0000000";
                     else
                         count<=count+7;
                         enhour_1<='0';
                     end if;
                 else
                    count<="0000000";
                 end if;
                 count<=count+1;
                 enhour_1<='0' after 100 ns;
              else
                 count<="0000000";enhour_1<='0';
              end if;
           end if;
       end process;
 end rtl;
仿真
(3)时计数模块VHDL源程序(hour.vhd)
library ieee;
entity hour is
  port(clk,reset:in std_logic;
       daout:out std_logic_vector(5 downto 0));
end hour;
architecture rtl of hour is
    signal count:std_logic_vector(5 downto 0);
        begin
      daout<=count;
      process(clk,reset)
        begin
           if(reset='0')then
              count<="000000";
                 if(count<16#23#)then
                    count<=count+7;
                 else
                    count<="000000";
                 end if;
              elsif(count<16#23#)then
                 count<=count+1;
              else
                 count<="000000";
              end if;
           end if;
       end process;
 end rtl;
仿真
(4)时间设置模块VHDL程序(settime.vhd)
library ieee;
use ieee.std_logic_arith.all;
entity settime is
        sec,min:in std_logic_vector(6 downto 0);
        hour:in std_logic_vector(5 downto 0);
        dp:out std_logic;
        sel:out std_logic_vector(5 downto 0);
        daout:out std_logic_vector(3 downto 0));
end settime;
architecture rtl of settime is
    signal count:std_logic_vector(2 downto 0);
    begin
    process(clk,reset)
         begin
           if(reset='0')then
              count<="000";
              if(count>="101"screen.width/2)this.style.width=screen.width/2;" border=0>then
                 count<="000";
              else
                 count<=count+1;
              end if;
           end if;
    end process;
    process(clk,reset)
        begin
           if(reset='0')then
              daout<="0000";
              dp<='0';
              sel<="111111";
            case count is
              when"000"=>daout<=sec(3 downto 0);
                         dp<='0';
                         sel<="111110";
              when"001"=>daout(3)<='0';
                         daout(2 downto 0)<=sec(6 downto 4);
                         dp<='0';
                         sel<="111101";
              when"010"=>daout<=min(3 downto 0);
                         dp<='1';
                         sel<="111011";
              when"011"=>daout(3)<='0';
                         daout(2 downto 0)<=min(6 downto 4);
                         dp<='0';
                         sel<="110111";
              when"100"=>daout<=hour(3 downto 0);
                         dp<='1';
                         sel<="101111";
              when"101"=>daout(3 downto 2)<="00";
                         daout(1 downto 0)<=hour(5 downto 4);
                         dp<='0';
                         sel<="011111";
              when others=>daout<="0000";
                           dp<='0';
                           sel<="111111";
            end case;
         end if;
      end process;
end rtl;
仿真
(5)译码显示模块的VHDL程序(deled.vhd)
library ieee;
entity deled is
port(num: in std_logic_vector(3 downto 0);
     led: out std_logic_vector(6 downto 0));
end deled;
architecture rtl of deled is
 begin
      led<="1111110"when num="0000"else
           "0110000"when num="0001"else
           "1101101"when num="0010"else
           "1111001"when num="0011"else
           "0110011"when num="0100"else
           "1011011"when num="0101"else
           "1011111"when num="0110"else
           "1110000"when num="0111"else
           "1111111"when num="1000"else
           "1111011"when num="1001"else
           "1110111"when num="1010"else
           "0011111"when num="1011"else
           "1001110"when num="1100"else
           "0111101"when num="1101"else
           "1001111"when num="1110"else
           "1000111"when num="1111";
  end rtl;
  • 相关推荐
  • 热点推荐
  • vhdl
