接口定义
EISA总线引脚定义
EISA 是 Extended Industry Standard Architecture 的缩写,由 Compaq, AST, Zenith, Tandy 等公司开发。
接口卡的外观 |
| 元件面 |
|___________ ISA-16bit __ ISA-8bit __|
||||||||||| ||||||||||||||||||| A1 正面/B1 反面
| | | | | | | | | | | | | | EISA: E1 正面/F1 反面
C1/D1
G1/H1
A,C,E,G=元件面
A,B,F,H=线路面
引脚定义 |
Pin |
Name |
Description |
E1 |
CMD# |
Command Phase |
E2 |
START# |
Start Phase |
E3 |
EXRDY |
EISA Ready |
E4 |
EX32# |
EISA Slave Size 32 |
E5 |
GND |
Ground |
E6 |
KEY |
Access Key |
E7 |
EX16# |
EISA Slave Size 16 |
E8 |
SLBURST# |
Slave Burst |
E9 |
MSBURST# |
Master Burst |
E10 |
W/R# |
Write/Read |
E11 |
GND |
Ground |
E12 |
RES |
Reserved |
E13 |
RES |
Reserved |
E14 |
RES |
Reserved |
E15 |
GND |
Ground |
E16 |
KEY |
Access Key |
E17 |
BE1# |
Byte Enable 1 |
E18 |
LA31# |
Latchable Addressline 31 |
E19 |
GND |
Ground |
E20 |
LA30# |
Latchable Addressline 30 |
E21 |
LA28# |
Latchable Addressline 28 |
E22 |
LA27# |
Latchable Addressline 27 |
E23 |
LA25# |
Latchable Addressline 25 |
E24 |
GND |
Ground |
E25 |
KEY |
Access Key |
E26 |
LA15 |
Latchable Addressline 15 |
E27 |
LA13 |
Latchable Addressline 13 |
E28 |
LA12 |
Latchable Addressline 12 |
E29 |
LA11 |
Latchable Addressline 11 |
E30 |
GND |
Ground |
E31 |
LA9 |
Latchable Addressline 9 |
F1 |
GND |
Ground |
F2 |
+5V |
+5 VDC |
F3 |
+5V |
+5 VDC |
F4 |
F5 |
F6 |
KEY |
Access Key |
F7 |
F8 |
F9 |
+12V |
+12 VDC |
F10 |
M/IO# |
Memory/Input-Output |
F11 |
LOCK# |
Lock bus |
F12 |
RES |
Reserved |
F13 |
GND |
Ground |
F14 |
RES |
Reserved |
F15 |
BE3# |
Byte Enable 3 |
F16 |
KEY |
Access Key |
F17 |
BE2# |
Byte Enable 2 |
F18 |
BE0# |
Byte Enable 0 |
F19 |
GND |
Ground |
F20 |
+5V |
+5 VDC |
F21 |
LA29# |
Latchable Addressline 29 |
F22 |
GND |
Ground |
F23 |
LA26# |
Latchable Addressline 26 |
F24 |
LA24# |
Latchable Addressline 24 |
F25 |
KEY |
Access Key |
F26 |
LA16 |
Latchable Addressline 16 |
F27 |
LA14 |
Latchable Addressline 14 |
F28 |
+5V |
+5 VDC |
F29 |
+5V |
+5 VDC |
F30 |
GND |
Ground |
F31 |
LA10 |
Latchable Addressline 10 |
G1 |
LA7 |
Latchable Addressline 7 |
G2 |
GND |
Ground |
G3 |
LA4 |
Latchable Addressline 4 |
G4 |
LA3 |
Latchable Addressline 3 |
G5 |
GND |
Ground |
G6 |
KEY |
Access Key |
G7 |
D17 |
Data 17 |
G8 |
D19 |
Data 19 |
G9 |
D20 |
Data 20 |
G10 |
D22 |
Data 22 |
G11 |
GND |
Ground |
G12 |
D25 |
Data 25 |
G13 |
D26 |
Data 26 |
G14 |
D28 |
Data 28 |
G15 |
KEY |
Access Key |
G16 |
GND |
Ground |
G17 |
D30 |
Data 30 |
G18 |
D31 |
Data 31 |
G19 |
MREQx |
Master Request |
H1 |
LA8 |
Latchable Addressline 8 |
H2 |
LA6 |
Latchable Addressline 6 |
H3 |
LA5 |
Latchable Addressline 5 |
H4 |
+5V |
+5 VDC |
H5 |
LA2 |
Latchable Addressline 2 |
H6 |
KEY |
Access Key |
H7 |
D16 |
Data 16 |
H8 |
D18 |
Data 18 |
H9 |
GND |
Ground |
H10 |
D21 |
Data 21 |
H11 |
D23 |
Data 23 |
H12 |
D24 |
Data 24 |
H13 |
GND |
Ground |
H14 |
D27 |
Data 27 |
H15 |
KEY |
Access Key |
H16 |
D29 |
Data 29 |
H17 |
+5V |
+5 VDC |
H18 |
+5V |
+5 VDC |
