ISA总线引脚定义
接口定义
119人已加入
ISA总线引脚定义
ISA 是 Industry Standard Architecture 的缩写
接口卡的外观
插槽的外观
引脚定义
引脚
定义
方向
说明
A1
/I/O CH CK
I/O channel check; active low=parity error
A2
D7
Data bit 7
A3
D6
Data bit 6
A4
D5
Data bit 5
A5
D4
Data bit 4
A6
D3
Data bit 3
A7
D2
Data bit 2
A8
D1
Data bit 1
A9
D0
Data bit 0
A10
I/O CH RDY
I/O Channel ready, pulled low to lengthen memory cycles
A11
AEN
Address enable; active high when DMA controls bus
A12
A19
Address bit 19
A13
A18
Address bit 18
A14
A17
Address bit 17
A15
A16
Address bit 16
A16
A15
Address bit 15
A17
A14
Address bit 14
A18
A13
Address bit 13
A19
A12
Address bit 12
A20
A11
Address bit 11
A21
A10
Address bit 10
A22
A9
Address bit 9
A23
A8
Address bit 8
A24
A7
Address bit 7
A25
A6
Address bit 6
A26
A5
Address bit 5
A27
A4
Address bit 4
A28
A3
Address bit 3
A29
A2
Address bit 2
A30
A1
Address bit 1
A31
A0
Address bit 0
B1
GND
Ground
B2
RESET
Active high to reset or initialize system logic
B3
+5V
+5 VDC
B4
IRQ2
Interrupt Request 2
B5
-5VDC
-5 VDC
B6
DRQ2
DMA Request 2
B7
-12VDC
-12 VDC
B8
/NOWS
No WaitState
B9
+12VDC
+12 VDC
B10
GND
Ground
B11
/SMEMW
System Memory Write
B12
/SMEMR
System Memory Read
B13
/IOW
I/O Write
B14
/IOR
I/O Read
B15
/DACK3
DMA Acknowledge 3
B16
DRQ3
DMA Request 3
B17
/DACK1
DMA Acknowledge 1
B18
DRQ1
DMA Request 1
B19
/REFRESH
Refresh
B20
CLOCK
System Clock (67 ns, 8-8.33 MHz, 50% duty cycle)
B21
IRQ7
Interrupt Request 7
B22
IRQ6
Interrupt Request 6
B23
IRQ5
Interrupt Request 5
B24
IRQ4
Interrupt Request 4
B25
IRQ3
Interrupt Request 3
B26
/DACK2
DMA Acknowledge 2
B27
T/C
Terminal count; pulses high when DMA term. count reached
B28
ALE
Address Latch Enable
B29
+5V
+5 VDC
B30
OSC
High-speed Clock (70 ns, 14.31818 MHz, 50% duty cycle)
B31
GND
Ground
C1
SBHE
System bus high enable (data available on SD8-15)
C2
LA23
Address bit 23
C3
LA22
Address bit 22
C4
LA21
Address bit 21
C5
LA20
Address bit 20
C6
LA18
Address bit 19
C7
LA17
Address bit 18
C8
LA16
Address bit 17
C9
/MEMR
Memory Read (Active on all memory read cycles)
C10
/MEMW
Memory Write (Active on all memory write cycles)
C11
SD08
Data bit 8
C12
SD09
Data bit 9
C13
SD10
Data bit 10
C14
SD11
Data bit 11
C15
SD12
Data bit 12
C16
SD13
Data bit 13
C17
SD14
Data bit 14
C18
SD15
Data bit 15
D1
/MEMCS16
Memory 16-bit chip select (1 wait, 16-bit memory cycle)
D2
/IOCS16
I/O 16-bit chip select (1 wait, 16-bit I/O cycle)
D3
IRQ10
Interrupt Request 10
D4
IRQ11
Interrupt Request 11
D5
IRQ12
Interrupt Request 12
D6
IRQ15
Interrupt Request 15
D7
IRQ14
Interrupt Request 14
D8
/DACK0
DMA Acknowledge 0
D9
DRQ0
DMA Request 0
D10
/DACK5
DMA Acknowledge 5
D11
DRQ5
DMA Request 5
D12
/DACK6
DMA Acknowledge 6
D13
DRQ6
DMA Request 6
D14
/DACK7
DMA Acknowledge 7
D15
DRQ7
DMA Request 7
D16
+5 V
D17
/MASTER
Used with DRQ to gain control of system
D18
GND
Ground
  • 相关推荐
  • 热点推荐
