接口定义
ECP并行口引脚定义图
ECP 是 Extended Capabilities Port 的缩写,外观同并行口,是 25 针母插座:
引脚定义 |
Pin |
Name |
Dir |
Description |
1 |
nStrobe |
Strobe | |
2 |
data0 |
Address, Data or RLE Data Bit 0 | |
3 |
data1 |
Address, Data or RLE Data Bit 1 | |
4 |
data2 |
Address, Data or RLE Data Bit 2 | |
5 |
data3 |
Address, Data or RLE Data Bit 3 | |
6 |
data4 |
Address, Data or RLE Data Bit 4 | |
7 |
data5 |
Address, Data or RLE Data Bit 5 | |
8 |
data6 |
Address, Data or RLE Data Bit 6 | |
9 |
data7 |
Address, Data or RLE Data Bit 7 | |
10 |
/nAck |
Acknowledge | |
11 |
Busy |
Busy | |
12 |
PError |
Paper End | |
13 |
Select |
Select | |
14 |
/nAutoFd |
Autofeed | |
15 |
/nFault |
Error | |
16 |
/nInit |
Initialize | |
17 |
/nSelectIn |
Select In | |
18 |
GND |
Signal Ground | |
19 |
GND |
Signal Ground | |
20 |
GND |
Signal Ground | |
21 |
GND |
Signal Ground | |
22 |
GND |
Signal Ground | |
23 |
GND |
Signal Ground | |
24 |
GND |
Signal Ground | |
25 |
GND |
Signal Ground |
